Official Thread for X1 CRT .5 Truggy
#1051
RE: Official Thread for X1 CRT .5 Truggy
Hi guy's i have just got myself a mini hyper st and i am wandering what diff oil weights to put in it?I have some 3000,5000 and 7000 here for my 1/8th buggy but was wandering it thats to thick for a car the hypers size?Thanks for any info and i know this is the crt.5 thread but they are virtualy the same and cant find an official mini hyper thread.
#1052
ORIGINAL: martin34
Any suggestions for good bashing tyres? Iam struggling getting grip with the os 18 tz and 18t clutch bell.
#1053
CA
i was thinking about putting a dynamite .12re w/side carb in my new crt.5, any thoughts? second whats a good clutch set up(flywheel, shoes, springs, and bell) and where do i find one? third can i use regular size servos w/out the extended chassis? thanx, 1cougar1
#1054
ORIGINAL: 1cougar1
#1056
CA
whats the diff between the picco .12 3 and 7-port engines? second would you recomend one of those picco's or a ofna jammin .12? thanx, 1cougar1
#1059
I think it has. They died out very quick. Not many seem to be running them anywhere. Iam gunna bash tomorrow with mine. They are very tuff. Great fun with an os18tz ripping. Id still prefer to bash with a 1/8th scale trug due to the ground clearance.
#1060
ORIGINAL: pigpen1
here's a couple of pics of my crt.5 with a picco .12 7port
#1061
PA
yeah 16mm big bore front buggy shocks from a jammin buggy with assoc.softest front buggy springs....on the rear
and revo shocks with jato silver springs on the front ......it handles like a dream
#1064
ORIGINAL: NitroBurn1
Has the crt .5 been discontinued?
I remember it being hard to find parts like C-hubs except from ebay chop-shops, then the SCRT came out and it was like BAM parts support, and some aftermarket parts overnight.
#1065
My Feedback: (27)
I have been wanting to get one of these trucks for I while now and I just came across this deal today. I don't want to spend much money so this looks like I pretty good deal for a kit to mess around with. I will just need to find an engine for it! Thought I would share.
http://www.nitrohouse.com/Car-Kits-N...duct_info.html
#1066
I just picked up 2 of these kits. My son and i are going to put them together. So far so good, but what servos would you guys suggest for this car. I have the servo's that came with my Spektrum radio's, S200(?). Will these work or should i order different ones.
#1067
CA
The nylon gears in theSpektrumservoswon't hold up for the steering. Something like this will do.
http://www.amainhobbies.com/product_...tal-Gear-Servo
#1068
That is a bargain at $80 a kit from Nitrohouse. They are strong kits. I hammer mine and it doesnt break anything.
I have Hitec 645mg servos in mine, work great. The os18tz i run is bonkers in a crt.5. Keeps flipping even with a wheelie bar.Probably better off with a 12 or 15 size engine.
The only thing is being small you cant bash it on alot of rough ground. I will probably sell mine soon and go back to a 1/8 scale truggy.
#1071
My Feedback: (27)
Depends on your gearing. The diffs have a 3.25:1 ratio, the stock spur is 46T and the stock clutch bell is 13T. The stock tires are 3.5 inches in diameter. so if your engine is doing 30000 rpm the car is doing 27mph on stock gearing. if you are getting 35000 rpm you will see 31MPH. If the engine manages to get to 40000 you could see 36mph. go to a 18t clutch bell at 35000 rpm you will be doing 43mph.
I have hit 70.2mph (with the GPS) with mine but I am running a Werks B6 .21 and custom gearing.
#1072
ORIGINAL: yakfish
Ive hardly touched mine over last few months. I miss the 1/8 scale truggy that can bash over rougher ground. I mite go back to 1/8.
Currently i think mine has around a 17 or 18 tooth clutch bell, badlands tyres and an os 18. Cant keep the front end down. I used the stock tyres on the road when i first got it to test it out and they went bald in minutes with the os18.
Did you have to do much to fit the 21 in?
