hot bodies lightning stadium pro-r promlem thread
RE: hot bodies lightning stadium pro-r promlem thread
Dunno, the only think I break on mine is the body mounts. Shocks seem pretty good to me and the mounts are solid 4mm thick and are not exposed like buggy shock towers.
Theres a few aftermarket shock mounts out that might put extra pressure on them. (??)
CA
i have the lsp pro with the aluminum arms and the shock ends (the plastic part of the shock not the aluminum part) break so easily i want to get aluminum ones but i dont know where to get them or know of a site for the lsp.
please help
thanks
please help
thanks
#32
ORIGINAL: AmiT d
hey can u guys tellme good and bad stufdf about the stadium 10.. i already got it
If you already bought it you'll find out for yourself
#37
Only real complaint is the front diff covers, they break/crack fairly easily, the problem of having alloy arms puts a lot of strain on them (some LSP at my club have gone back to using plastic arms). Although they are a cheap part ($10) they take ages to swap over, the entire front end has to be dissassembled, looking at at least 1-2 hours of tedious work to do it.
Other than that its a good Truggy
#38
At the motocross track or the rc track? I will proply start racing at the rc track because I can't race my dirtbike because I on medical for my shoulder.
#39
TN
my axe rossi mamba pulls the wheels all the way down the straight away about 2-3 inches off the ground but here are some pics of mine before I did some suspension tuning to it(I just got it a week ago)
#41
TN
lsp pro-r is the full race version then the others are I am guessing rtr versions correct me if I am wrong
#42
Lots of subtle differences it would appear from looking on the HB website, the R is the kit version, no engine/electronics and comes with lots of the parts that would be considered hop ups on the Pro RTR. Carbon Fibre radio & centre diff plate, alloy hinge pin holders instead of plastic, clear body, yellow wheels etc.
If you've already got an enigne and radio gear it's no problem, if not you need to budget for these when buying.[8D]
#43
CA
my lsp has alloy hinge pins holders, bu not the carbon fiber radio tray or center diff,i've upgraded my front chassis brace and have put 23 mm hexes with proline bowties on dishes, and have put high torque servos, wing mount, and an axial 28.........would i be able to race this i have never raced before but really want to get into it all i need now is a good radio/recever could you guys give me some idea on what radio i should get i dont want to spend 500 buck or anything like that.
thanx
thanx
#44
can annyone tell me where to get the new aluminum rear hub carriers from the lightning pro evo?i need to get em for my lsp.i love my lsp.its so sick.but i would like to get the hub carriers and no one knows where to get them.
#45
NY
heres mine. its the pro R. the only thing i had trouble with is i stripped out the hub carrier. first time out it took first place in the B main!!! luv it!
i have the axial .28 engine, associated MG steering serve, XP3 radio system. let me know what you think of the pics
