HS 5625 servo good for throttle?
GA
I am setting up an Eight T , I have a 5625 hitech servo already. Is this servo a good choice?
Thanks, Chas
ps. I will be running 6Volts.
Thanks, Chas
MO
RE: HS 5625 servo good for throttle?
I do not have any experience with that servo, but it looks a lot better than the cheap JR I am running. With proper EPAs and linkage setup, it has lasted 1 gallon on my RTR 8ight-B and then put in my 8ight-T which has over a gallon on it. It is all setup.
You don't need anything special on the throttle. I spend BIG on steering servos, but not on throttle. My current favourite budget throttle servo is the HPI SF2 (about 100oz in and .16 transit). It has good torque and reasonable speed and it's cheap. Doesn't eat the receiver pack too bad either. The best throttle servo you can get in my opinion would be either the ACE DS1313, or the futaba 9451.
That hitec you selected isn't bad for the price.
