If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 36 of 40 FirstFirst ... 263435363738 ... LastLast
Results 876 to 900 of 979
  1. #876
    coalminer's Avatar
    Join Date
    May 2008
    Mansfield, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Tamiya Nitrage 5.2, The Offical Thread
    Hi again Chad.
    If its a bit more punch your after then you may want to look into a different pipe. Many folk swear by the Jammin JP4 pipe for this engine and quite right so, but to be honest in my opinion the Ofna Mutilator pipe is as good as the JP pipe for half the price or less. I have the Ofna Mutilator pipes fitted to both my Nitrages. There is a little bit of messing around to do with the front end mounting , but any one with a little modelling skill should be able to sort it out, I had to use a welding rod and bend it to suit to use as a mounting spring , they have been on for a few years now and no problems. The Mutilator pipe will still give me the top end speed with the added bottom end grunt with it, this Mutilator pipe is intended for this 32 engine.
    Coalminer
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #877
    Atomika's Avatar
    Join Date
    Apr 2009
    Council Bluffs, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Simon,
    Good to know man, I'd thought about a new pipe but wasn't sure. It makes sense tho. Considering the price it's worth getting. Thanx again for your help.
    Jealousy is the tribute mediocrity pays to genius
  3. #878
    Join Date
    Nov 2011
    Cape TownWestern Cape, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have managed to find out what the issue with the failsafe was.  Almost embaressed to say .. but it was battery related!  The battery power was getting low and that was causing the failsafe to kick in.  I did try and change the batteries initially but they were obviously not strong enough.
    There is, however, an issue with the receiver - which you program the failsafe it saves your settings but the moment you switch it off and on again those settings disappear and it's back to default settings.
    I am going to look to get an upgraded radio and receiver anyhow so it's not a trainsmash.
    Just ordered a set of ProLine Power Stroke shocks for Nitrage - can't wait to try them out!
  4. #879
    Join Date
    Aug 2005
    roodepoort, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys, just thought i'd share my Tamiya's.
    The one I run has got a two speed, front brake, anti roll bars, pull start, TNX springs and upgraded servos, and she runs great...
    The other one has got every Hop Up from Tamiya as well as titanium turnbuckles everywhere and stiffer shocks.
    I have removed all play in the steering and suspension and they are both tight and slop free now.
    I love them because they are Tamiya, very unique and they really do run very well.
  5. #880
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  6. #881
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
ID:	1724264   Click image for larger version.
  7. #882
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hope u guys dont mind the pics.
ID:	1724284   Click image for larger version.
  8. #883
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
ID:	1724286   Click image for larger version.
  9. #884
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last pics...
ID:	1724290   Click image for larger version.
ID:	1724291   Click image for larger version.
ID:	1724292   Click image for larger version.
ID:	1724293   Click image for larger version.
  10. #885
    The Collector1's Avatar
    Join Date
    Aug 2007
    Brooklyn,Queens, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, great pics and nice twins. I have a question how do the X-cons work for you? I thought about getting some for mine but I have not ran mine in a while since I got a E801XT but I still love it
    Avante2011,Tundra,TT01,Amax,Blackfoot,MB,Hilux Racer,Durga,TA01,02,03,Nitrage5.2,959,E801XT,801X, RC8 Family,and alot more
  11. #886
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Collector1, I have no idea how the X cons run yet.
    But they do look pretty good.
  12. #887
    Join Date
    Nov 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very nice pics Plopes!
  13. #888
    Join Date
    Aug 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks guys
  14. #889
    Join Date
    Nov 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I took the Nitrage for a run this weekend at the local field.  I noticed that when i try and start it using the electric starter, the flywheel is not turning over even though the nut is turning.
    Essentially the starter is just turning the nut and the engine isn't turning over so it wont start.
    Any ideas as to what i have broken?  And how to repair it?
    Thanks.
  15. #890
    Atomika's Avatar
    Join Date
    Apr 2009
    Council Bluffs, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @ Plopes, Those are sick!! well done.
    @ Jumpman, Sounds like its your one way bearing. If you have a starter box or know some one who has one you can get by with that, other wise you jus need to change out the one way, its an easy fix & only bout $15. Look in ur user manual and it will tell you how to change it out.
    @ Everyone else, I managed to some how crack my damned gas tank the other day. Anybody know of where to get one for a decent price or another tank that will fit in there?
  16. #891
    Join Date
    Nov 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply Atomika, but upon close inspection i noticed that i had my facts wrong.  I tested it again at home and noticed that the flywheel was turning perfectly when i try and start it.
    However, there was no compression.  So i took off the heat sink and had a look at the piston and sleeve.  In the middle of the piston there is a hole!!
    So i have destroyed my engine somehow.  All i can think is that perhaps i was a little bit too hard on full throttle for too long.  I had run in the motor, it wasn't running too lean, ample air.  Maybe i pushed it too hard.
    Anyhow ordered another piston and sleeve.....then will see from there!
  17. #892
    sparksy82's Avatar
    Join Date
    Sep 2011
    mount gambier, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hay can i ask how much did it cost you for a new piston and sleeve ?
  18. #893
    Join Date
    Nov 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I paid Aus $140
    Very ouch.
  19. #894
    Join Date
    Feb 2012
    Otego, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mornin all, I am a total noob and have just purchased 2 Nitrages (hard to beat at $229)! I have read thru this entire thread and I am looking for some help. I would like to have a small selection of spare parts and also possibly install front brake and different shocks. Any answers to the following questions would be quite helpful.
    1 - What oils should I have on hand for gear boxes,shocks, etc.
    2 - What spare parts should I plan on having - a bunch of noobs racin with slight bashing, mostly outdoors.
    3 - Is there an online source for one-stop-shopping or will I have to buy from multiple sources? Checked many sites out but not a clue yet, I have tried to find shocks but have had no luck.
    3 - What parts are interchangable with other models to allow modifications?
    All in all it sounds like a great bunch of peeps here. I am lookin forward to sharing my journey into Nitraging !!! Oh, BTW - this is a great new hobby to start at the age of 63 !!!
    -Goat-
  20. #895
    Join Date
    Feb 2012
    Otego, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I found this post earlier and just had a question regarding the "CVD's" .
    ORIGINAL: qaiz
    Here you go
    Original : Nauticar
    i got:
    1) 2speed tranny
    2) jp4 pipe (is it quieter than the jp3?)
    3) roadrage tires (mine will be mostly on road)
    4) stabilizer set (BUT THESE WERE ALREADY IN THE KIT! )
    5) front brake (THESE ARE INCLUDED IN THE KIT TOO!! )
    6) fuel indicator (Tamiya bling lol)
    7) Tamiya failsafe
    8) futaba 9351 (steering) and 9452 (throttle) servos
    9) futaba r152je receiver module
    10) front and rear cvds (Tamiya)
    11) front and rear drive shaft cvds (Tamiya)
    12) Tamiya+duratrax fuel filters (read from one post that tamiya didnt include these!think it was you who mentioned this)
    13) Tamiya aluminum heat sink (really looks good!)
    And the Nitrage Kit too obviousely lol.
    Are these part of the kit(included in the shaft bag), or do they have seperate part numbers? I'm somewhat confused on this one cvds are listed on two seperate lines( #10 & #11). I'm trying to get a list of spare and or replacement parts together so once again, any help would be greatly appreciated.
    -Goat-
    NVM - found manual an answered my own question!!
  21. #896
    Atomika's Avatar
    Join Date
    Apr 2009
    Council Bluffs, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @ jupman
    Ouch dude, thats a bummer. Yeah these don't like to run balls out full throttle for long distances. I found that out the hard way as well. I managed to ream out the lower loop of my con rod which in turn punched holes in my crank case. It was $66 all together to replace both parts so it wasn't too bad. & jus fyi the Ofna Force .32 is the exact same motor & the parts are much cheaper than the Tamiya ones.
    @Goat
    Welcome to the highly addictive and expensive but incredibly fun hobby of RC. Buy'n 2 Nitrages was a good idea. You'll save money in the long run for sure. Out of all my rc's (I have 7) I'd have to say the Nitrage it's the most durable & reliable.
    As for parts since you have a whole other truck to part from you oughta be in good shape for awhile.
    Since I've had mine I've replaced:
    The con rod & crank case (as I stated above that was from driving it to hard & too hot)
    3 lower shockmounts
    1 rear A arm
    & I now need a new gas tank.
    Both my rear shocks leak as well.
    Get a temp gauge for sure. Don't let your engine get to hot. Also you'll want to get some high temp sealant (I used silicone gasket sealant for cars) and seal your engine. Here's a good vid showing you how: http://www.youtube.com/watch?v=rncdYL-PBL4
    Always use after run oil or WD40 after every use & also be sure to leave your piston in the down position after running. Leaving it at the top can cause binding as when the engine cools down the the crankcase will shrink, binding the piston to the top.
    Be sure to clean and re oil your air filter after every run. I use the k&n red oil (the recharger kit for full size cars) Its fairly cheap and lasts forever.
    Have shock oil of some sort. Since mine leak often I've jus used some old transmission oil I had lying around and it seems to work fine.
    Get some shoe goo and coat the inside of the body. This helps to prevent cracks and if it does crack it keeps the pieces in place.
    A fuel filter is always a good idea and inexpensive
    Check the screws on the underside of the chassis after runs & locktite them as needed.
    Be sure your fail safe is working and always have full batteries. Its not fun to watch your Nitrage take off at full speed across a parking lot or bash its way across your local track.
    There are a few interchangeable parts. The Ofna Mutilator shares the same motor so pipes for that will work on the Nitrage.
    The shock springs from the TNX will work on this & the tires are the same.
    & fuel wise I run Byron's Gen2 Nitro 20% Lube 12%
    Thats bout all I got. Hope it helps. Have fun!!!
  22. #897
    Join Date
    Feb 2012
    Otego, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply Atomika, the information is really appreciated. Actually, one of the Nitrages is for my neighbor but we are pooling our resources to buy extra parts. Just a couple quick questions about your reply..
    re"> I haven't been able to locate TNX springs, is there a site you know of that has them?
    re"> What is "shoe goo" ?
    re"> You mention Nitro 20% Lube 12%, the only fuel I can get locally says 20%. Should I be looking for a specific brand or is that something you have to blend yourself?
    Thanks again, can't wait til next week when my Nitrage arrives !!!!!
    -Goat-
  23. #898
    Join Date
    Nov 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    @goat : with regards to shocks, people have recommended Proline Powerstroke Shocks. I bought a set off eBay.  I haven't had a chance to fit them yet and test, but a lot of people recommend them. I will let you know how I find them once they are installed.
  24. #899
    Join Date
    Feb 2012
    Otego, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info jupman, I look forward to see how they work for ya.
    -Goat-
  25. #900
    Tech Head's Avatar
    Join Date
    Oct 2008
    Temora. South West Slopes.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just thought I should pass this on: http://www.ausrc.com/forum/showthrea...Tamiya-Nitrage
    It's $150 RTR, great for a second runner or for spares. It's not mine, It has had no replies since the 9/2/2012 so it could go cheaper.
    Backyard Race Tracks rule!
    2WD Buggies, not for chickens!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
