Just put BIG BORES ON MY MONSOON!
FL
Just installed big bore shocks onto my monsoon! Can't wait to test it out. Here are some pics of my monsoon and of the big bore shocks.
FL
RE: Just put BIG BORES ON MY MONSOON!
I took them off of my Robitronic mantis. They bolted right up but I still used the shock mounts on the towers from my mantis instead of the monsoon because the monsoon has the shock cap mounted on a bushing instead of a ball joint so I thought it would be better. You can find sets of 4 big bores on ebay, alot of them for sale are for the new Hyper st pro and are a good price and should fit too. They are the 14mm big bore shocks and not the new 16mm that are out on some new stuff.
FL
ORIGINAL: hkenvy91
no ! these are big bores!! kyosho bb's
Also I am in the process of selling some stuff to get the new ST-RR too. That thing is awesome!
Redcat nick as far as a link I am assuming a link to buy the shocks complete as a set of 4? I will try and find a link for you.
PA
no, these are big bore . i dont think they get any bigger than this
FL
ORIGINAL: Redcat Nick
Do you have a link. just figured that since you have them it would be easier than trying to find them
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPJF0&P=7[/link]
CT
i made mine, they are the aftershock shocks. i cut the shock shaft and the shock bodies to fit, the shaft you need to retap it so the ball end can screw back on. it was simple once you got all the measurements. but before you start and cut a good pair of shocks, make sure they will fit. the shocks after they were fit to size i only have about less than a mm before they rub the axles.
FL
You have those on a thunder tiger? I thought you had a LST2? That is awesome! Never seen another brand truggy with the losi shocks before. Do they work good for you?
CT
so far all i can do is watch the weather [:'(] untill it warms up a bit i cant break her in . but i can drop it at 6 ft and it dosent bottom out...... much
conneticut ! yeah id say you guys are done up there runnin till it gets warmer! that suxs!! atleast we are still getting some warm days to race out here
FL
Just ran my monsoon tonight and the bigger shocks made a big difference over the rough stuff, it was alot smoother and also the thinner shock fluid felt good too.
CT
lol tell me about the CT weather, snow and ice storms over here in the norwich area, I hate the weather around here! Good thing my warhead is in pieces for its impending engine swap to a Sportwerks .26 v2 and monsoon is in pieces for maintenance and modifying or i might be really mad lol
