fuel tubing?
fuel tubing?
does the length of fuel tubing have an effect on a truggy performance wise? i got my truggy with almost a foot of fuel tubing from tank to carb, should i cut it and rerun the tubing?
RE: fuel tubing?
The only thing that it helps with having long fuel line is in a roll over. It will stay running longer on its lid then with a shorter tube. If you got a primer bulb you can cut shorter because of the extra fuel in the bulb. So no it does not hurt performance. Just helps in roll overs.
ON, CANADA
RE: fuel tubing?
You know what I shortened my fuel line to only 2 inches on my ST-1 and test ran it today, even when it flips it ran didn't rev lean!! Ran so perfect NEVER seen this truck so perfect with the mach 427. Maybe my fuel line had a air leak? Still runs fine! !
RE: fuel tubing?
Eric I have the sportwerks V2 in my st1 and its a rocket for sure. I like this setup very much. I also just bought a Axail 28 and just got it brok in. This is also a beast. Very much like the V2/427 but better bottom end. Now I just need to figure out which one Im going to race and which one for backup.
ON, CANADA
RE: fuel tubing?
Are you running a 15T bell? I am with a mach 427 with 15T bell and it is VERY fast off the line and still catches redline way to fast. I plan on going to a 16T. The axial .28 is .10hp faster and has much better torque.
http://youtube.com/watch?v=NdiMAReoRKQ
I am still running stock pipe as well! Clutch is cool as well! Stock clutch just 1.0mm springs.
RE: fuel tubing?
thanks guys, what about the position of the fuel line, if i just used a 4 inch long line and run it straight from tank to carb, would it cause more fuel draw into the carb due to acceleration?
ON, CANADA
RE: fuel tubing?
With a longer fuel line, dont you have to make sure that theres enough preassure.?
If not I have a 40 FT spool of fuel lining, its going completely in lol. Ill get an extra fuel tank
PA
RE: fuel tubing?
FL
RE: fuel tubing?
ORIGINAL: qaiz
I've heard that keeping your tubing from the top of tank to the exhuast helps keep a consistent pressure in the tank.
And i've heard people use a long fuel line so when they flip they have extra fuel to keep it running..but who cares when you a nicly designed tank that eliminates that need
