8ight T RTR Engine Q?
Can I put my Mach 427 engine on the lowered engine mounts and run a starter box with it? Currently it sits quite high and I am assuming this is due to the roto start plate on the back that requires additional height. Is there a blanking plate of some type also?
RE: 8ight T RTR Engine Q?
http://www.amainhobbies.com/product_...oducts_id/4331
Buy some smaller mounts, a 35mm flywheel, and that.
Many thanks UG0TB4NN3D, my LHS have ordered me this part today although losi tech told them that they have never tried this plate on the Mach 427.
Will any 35mm flywheel fit into the 8T? Also will I need to modify the chassis for the wider wheel?
ON, CANADA
ORIGINAL: Nordy
