Bought everything I need for my BCE PJX conversion!
1 x OFNA Differential Gaskets (3) (Jammin X1) (OFN40011) = $3.39
1 x OFNA 1/8 Off Road Air Filter Elbow (Black) (OFN10139) = $3.39
1 x Mugen Universal Joint Pin (For C0263) (MUGC0265) = $4.29
1 x OFNA CNC Alumimum Center Diff Posts (4) (Jammin X1-CR) (OFN40595) = $15.49
1 x OFNA 1.0mm Black Clutch Springs (3) (Jammin X1) (OFN10102) = $4.29
2 x OFNA Brake Cam (1) (Jammin X1) (OFN40547) = $15.50
1 x JR Servo Mounting Grommets (20) (JRPA225) = $3.39
1 x Kyosho Light Weight 50T Center Spur Gear (ST-R) (KYOIFW167) = $24.99
1 x Team VTX 2.4mm x 6.2mm Silicone Fuel Line (4') Clear (VRX-FL4TCL) = $4.29
1 x Dynamite Black Universal CVA Shaft Boots (Tmaxx, MBX5, TTR) (4) (DYN7687) = $5.25
1 x OFNA 2mm Brake Adjuster Knobs (2) (Jammin X1) (OFN36140) = $1.69
1 x OFNA 1.1mm Gold Clutch Springs (3) (Jammin X1) (OFN10101) = $4.29
2 x Hot Bodies 43T Spiral Conical Gear (Lightning Stadium) (HBSC9010) = $29.98
1 x Dynamite Max-Life Aluminum Clutch Shoe Set (DYNP5180) = $16.99
1 x Racers Edge 2000 Degree Heat Shield Tape (RCE1510) = $2.59
1 x Ace R/C Eyelets (0.3mm) (12) (ACEAQ1494) = $2.59
1 x Hot Bodies Universal Center Shaft (130mm) (Lightning Series) (HBSC8169) = $16.99
1 x Hot Bodies Rear Center Universal Shaft (Lightning Series) (HBSC8061) = $14.99
1 x Ultimate Products Dual Fuel Filter Mounting Bracket (Jammin X1-CR) (UPDFB2001) = $8.49
1 x OFNA Large Aluminum Stone Fuel Filter (Jammin X1-CR) (OFN40099) = $8.49
1 x Pacer Z-Poxy 5 Minute Quick Shot (1oz) (PAAPT36) = $4.19
1 x OFNA Large Fuel Bottle with Aluminum Spout (OFN10157) = $10.49
1 x OCM Newage 3x3mm Grub Screw (10) (OCMCRL-0013) = $1.29
1 x Team Associated Factory Team Green Slime (ASC1105) = $2.19
VA
RE: Bought everything I need for my BCE PJX conversion!
Sounds like it won't be long now. Keep us updated on your progress.
Did you decide on a motor mount yet? Let me know if that vented flywheel
is going to work out. Thats going to be one sweet rail-rider. Ha!Ha!Ha!
QC, CANADA
ORIGINAL: IL2mSturmovik
How much total has this conversion cost you?
GA
I am gonna guess almost $360 when its all said and done.
I was looking at doing it when I had my Jammin CRT but teh $ drove me off, and now I have an 8T I am really digging
Oh, sorry guys. Didn't see that question.
Here's my Amain receipt:
Order Total: $207.10
1 x HBSC8169 Hot Bodies Universal Center Shaft (130mm) (Lightning Series) $16.99
1 x ACEAQ1494 Ace R/C Eyelets (0.3mm) (12) $2.59
1 x RCE1510 Racers Edge 2000 Degree Heat Shield Tape $2.59
1 x DYNP5180 Dynamite Max-Life Aluminum Clutch Shoe Set $16.99
2 x HBSC9010 Hot Bodies 43T Spiral Conical Gear (Lightning Stadium) $29.98
1 x OFN10101 OFNA 1.1mm Gold Clutch Springs (3) (Jammin X1) $4.29
1 x OFN36140 OFNA 2mm Brake Adjuster Knobs (2) (Jammin X1) $1.69
1 x DYN7687 Dynamite Black Universal CVA Shaft Boots (Tmaxx, MBX5, TTR) (4) $5.25
1 x VRX-FL4TCL Team VTX 2.4mm x 6.2mm Silicone Fuel Line (4') Clear $4.29
1 x KYOIFW167 Kyosho Light Weight 50T Center Spur Gear (ST-R) $24.99
1 x JRPA225 JR Servo Mounting Grommets (20) $3.39
2 x OFN40547 OFNA Brake Cam (1) (Jammin X1) $15.50
1 x OFN10102 OFNA 1.0mm Black Clutch Springs (3) (Jammin X1) $4.29
1 x OFN40595 OFNA CNC Alumimum Center Diff Posts (4) (Jammin X1-CR) $15.49
1 x MUGC0265 Mugen Universal Joint Pin (For C0263) $4.29
1 x OFN10139 OFNA 1/8 Off Road Air Filter Elbow (Black) $3.39
1 x OFN40011 OFNA Differential Gaskets (3) (Jammin X1) $3.39
1 x HBSC8061 Hot Bodies Rear Center Universal Shaft (Lightning Series) $14.99
1 x UPDFB2001 Ultimate Products Dual Fuel Filter Mounting Bracket (Jammin X1-CR) $8.49
1 x OFN40099 OFNA Large Aluminum Stone Fuel Filter (Jammin X1-CR) $8.49
1 x PAAPT36 Pacer Z-Poxy 5 Minute Quick Shot (1oz) $4.19
1 x OFN10157 OFNA Large Fuel Bottle with Aluminum Spout $10.49
1 x OCMCRL-0013 OCM Newage 3x3mm Grub Screw (10) $1.29
1 x ASC1105 Team Associated Factory Team Green Slime $2.19
Add $26 for the pinions and another $26 for the MBX5T mount and another $136 for the BCE chassis, steering plate, and top plate
VA
It costs around $230 to biuld the BCE-PJX. That includes all the parts needed
to do the small diff conversion, longer center shafts, motor mount and BCE
chassis. Add another $100 if you want the cnc center diff mount. Also a few
of us had to use Mugen flywheel and flywheel nut.
Is it worth it? YES!!! That's why I own two of them. You just won't
beleave how these things handle now.
GA
$395, I was under by $35. I bet its the shiznizz though, lol.
I was gonna do it when I had my CRT, but then I saw a very slightly used 8T RR for $200
My little brother has my CRT now and loves it.
Did any of you guys that did teh BCE chassis consider teh RC-Innovations extended chassis?
I wouldn't consider that chassis. BCE is the only way to go with the extended chassis. What're you gonna do if that extended CVD that's included with the Innovative breaks? They don't sell replacements, and the only place I've seen them sold is in the UK.
I just bought a jammin X1 CRT. It came with the bce pjx chassis uninstalled. while trying to install the spur gear assembly with a 62 T spur gear it would'nt work without hiting the servo tray . So I put a 48 T spur gear on it and it fits. Now im having trouble installing the motor because the cluch bell is hitting the spur gear mount and not allowing the gear itself to contact the spur gear. Do you have any ideas for a cluch bell that will work with thi upgrade????? Also the universal shafts that you ordered on your list , work with this upgrade???
