CEN MG10 TR
RE: CEN MG10 TR
i have a CEN MG10 TR, it has a small piece of lexan bolted through the rear lip of the tray. you should be able to easily bolt a new wing to that lip using the original bolts
RE: CEN MG10 TR
another tip with the MG10... Glue some off-cuts of lexan or any plastic off-cuts across the inside of the shell... my first decent roll over and the shell just fell apart. i now have it glued together and reinforced with lexan off-cuts from the shell i got for my on-road
RE: CEN MG10 TR
ORIGINAL: yeatesy
RE: CEN MG10 TR
I have been told that it isn't really a truggy... more like a stadium truck... but it goes pretty well... just be careful with the sleeve inside the cylinder, i needed to de-burr the transfer ports as out of the box, the piston seized against the tops of the ports. Here's some pics of the wing that it came with... just held on with 2 small bolts.
also, cut a bit out of the shell at the exhaust... mine melted a bit in that area
sorry... not sure how to post pics on here... the first 4 pics on this photobucket album are of the MG10TR wing..
http://s80.photobucket.com/albums/j1...e/RC%20Action/
