HELP with spektrum DX 2.0 radio please.
CA
I bought a use 8ight t with the spektrum radio. The truck started nicely but the wheels don't move. I played with the throttle radio settings a little but now the wheels started spinning way to fast. Please help, I don't now what settings to use? Does anyone have any stock settings that I can start with. FYI I reset the radio to stock settings but the car still doesn't move. I'm confused with this radio please give me some tips. Thanks
RE: HELP with spektrum DX 2.0 radio please.
Have you read the throttle addendum and made sure all your linkages are set correctly?
http://www.losi.com/ProdInfo/Files/L...e_Addendum.pdf
Have you gone through the truck to make sure everything is put together correctly according to the manual?
You may have to reasign the reciever to the transmitter. I think this is how it goes.... First turn on the controller then the receiver, Press the green lit button on the back of transmitter then hold down button on reciever until it flashes or vice versa, can't remeber wich way but this may need to be done
CA
thanks guys. I will will read Losi's linkage, and try to fix the radio and receiver
Any more ideas welcomed, thanks.
WA
And if you didn't get a manual with your DX 2.0 here's a link for that.
http://www.spektrumrc.com/ProdInfo/F...20ManualHR.pdf
