What hex driver size do I need to remove my losi 8ight t fuel tank?
CA
Sorry to ask but I'm not sure what hex size driver I need to remove my fuel tank. I tried all but none seem to fit. I don't know if Im using the right tool in the first place.
Thank you for your help.
MB, CANADA
RE: What hex driver size do I need to remove my losi 8ight t fuel tank?
ORIGINAL: Losi Driva
you will need a (imperial) 3/32" hex wrench.
partially right...but wrong......5/64 or a 2mm will work for both the screws that hold the tank posts......there's no point to pull the tank off the posts....so remove the screws from the bottom of the chassy and pull it that way.
MB, CANADA
ORIGINAL: mrramirez
thank you, I will try from under the chasis.
If the screw's have ANY dirt or grime in them they will also be a little more challenging to get the Hex all the way in....I suggest taking a Scratch all or something Sharp and pointy and Gouging the screw head's first....it will guarentee the hex is in there good.
