Your TRUGGY and your setup
#76
PA
TRUGGY : Serpent 811 Cobra Truggy Electric Conversion (Using Serpent kit)
STR SERVO : Hitec 7950TH
Motor: Tekin T8 4038 2000kv
RADIO : Futaba 4PLS
WHEELS: Whatever I have
RADIO : Futaba 4PLS
#77
OFNA / HoBao Hyper 10TT
Motor: 3650M EZrun 4300kv
ESC: HW EZrun 35A
Servo: Hitec 5625
Tires: ProLine Gladiators
Diff Fluids F/M/R: 5K/5k/3k
Shocks: 30wt fluid. Moved lower shock mounting to outside hole F&R.
Droop: Lowered front end a couple mm
Mods: Removed rear sway bar. Added T-Bone Racing front & rear bumpers (stopped suspension arm breakage). Replaced steering knuckles and rear hub carriers with billet aluminum units from Integy. (The pieces are actually pretty good)
My first Truggy! And first 4wd. Nice size for my smallish work bench. Wow, is 4wd so much easier to drive! My buddy got one too (we've been racing each other with Evaders) and our door-to-door, lead-swappin' racing has gotten SO much better and more fun! We're both running the EZrun setups, which are surprisingly powerful enough to push the cars over 35mph. Indeed, this system is spec'd for this car. May one day get another Castle ESC to see what my old Castle motor would do in it. LOVE this car tho.
ESC: HW EZrun 35A
Servo: Hitec 5625
#78
That's a nice looking little truggy EXT2Rob. Glad I'm not the only who considered putting led's on a truggy, haven't gotten around to it though. No pics of mine right now but here's the specs
Losi 8ight-t 2.0
Losi electric conversion kit
Tekin RX8 Gen1
Tekin T8 2000kv Truggy motor
Hitec HS-7955TG servo
Losi tires and wheels right now
15k/100k/10k F/C/R diff fluids
I love brushless 1/8 scale stuff, the power is so much fun. Buggies and truggies are just so precise and nimble which adds to the fun. The throttle response of the sensored Tekin setup is so smooth. It gets run mostly on 4s around the yard but I throw in a 5s once in a while to make it more mental.
Losi 8ight-t 2.0
Tekin RX8 Gen1
#79
Thanks, Maj! It's small compared to the other truggies here, but I liked that it was about the same scale as the Evaders I learned on, so it didn't take up my whole work space, and, it uses the same motor system I used in the Evaders, same wheel sizes, and same battery packs. I really like that the thing is designed just like the 8th-scale trucks, with sturdy aluminum shock towers and suspension arm hinge-pin retainers, aluminum chassis and motor mount, and aluminum shocks with rubber boots. It's really tough in that regard. I did find that it needed T-Bone Racing front and rear bumpers. Kept breaking suspension arms in bad crashes. Once the bumpers were installed, no more breakage. Bought the car as a roller from Nitrohouse for $189, fully assembled, minus electronics. (I think it's about $220 now.) I'm impressed with the OFNA / HoBao quality.
Yeah, the lights are pretty cool for when we reach the end of our race day and twilight is setting in. The lights really help with being able to judge the car's attitude in the murky light. My race buddy made us each a custom light set and wire harness. It's usually the most fun battery pack of the day!
#80
Your welcome. I've been tempted by the 10tt many times. But big 1/8 power systems is what I know and love, it's hard to stray from that. The 4wd is probably making you feel the same way.
I used to think lights were cheesy, then I put a set on for my nephew and drove it. They provide a useful reference point in any light but they are cool come dusk.
#83
Afternoon all,
I'm in the UK and about to start rebuilding my X1CRT Pro after its been stored in boxes for the last 15 years. I'm replacing all the bearings, o-rings, gaskets etc. My question is i cant seem to find a definitive answer to what diff oil i need to put in my diffs. The Hong Nor instructions state to use 5000 (not sure if its Wt or cSt) in the F/C/R diffs. I need to buy some more diff oil but obviously unsure of whats to buy as from reading through this thread there lots of different setups and variable. I filled in my current setup below....the items which are TBC are items im looking ofr some guidance and opinions on if possible.
Thanks in advance
TRUGGY : X1CRT Pro
THR SERVO : Blue Bird BMS 660
STR SERVO : Blue Bird BMS 660
MOTOR : RB WS7 2 3X
Pinion/Spur: 13/62
RADIO : Futaba Megatech T2PL
WHEELS : TBC
DIFFS F/C/R : TBC possible 7000, 10000, 3000
SHOCKS F/R : Stock inc oil
RIDE HEIGHT : Stock inc oil
Thanks in advance
TRUGGY : X1CRT Pro
MOTOR : RB WS7 2 3X
Pinion/Spur: 13/62
WHEELS : TBC
#84
Hey mate!
Hope you're doing ok during this global crisis.
Diff oil just needs to be thick enough to prevent them from unloading too much when the wheel or wheels loose traction. How thick depends on several factors: your driving style, surface conditions, and the vehicle itself. I'd suggest starting with 5000wt in all three diffs, then seeing how the car behaves. I have two HoBao 10th scale cars, the Hyper TT and the SCT. My track is dirt/clay, kinda bumpy, but fast, with different radius turns. I run 5000 in the front diffs, 7000 in the rear, 10,000 in the center, although I could probably do with 8000. If your rig tends to wheelie and your front tires balloon, a thicker center diff would help. I'll attach a picture of a page from RC Car Action magazine you can download that explains what different weights do in which diff and how it affects the car's action.
#85
Hey
Yeah managing to stay safe and well at the moment, hope the same applies to you! Very strange times at he moment!
That's much clearer thanks, my only concern now is would i be OK purchasing the 5000cSTt oil which seems to be how most of the suppliers in the UK measure it rather than WT
Cant post links yet but a couple of UK websites are advertising diff oil as 5000cSt......modelsport and wheelspinmodels. Whereas the Ofna 10233 stuff from amazon is labelled as 5000wt
Should these be the same thickness?
#86
RC Car Action magazine to the rescue again! Sort of..
https://www.rccaraction.com/silicone...wt-versus-cst/
They dont go as high as the thousands, but one could assume it's scalable. Google is your friend.
It's weird the different shock and diff oil viscosity ratings. It sucks local hobby shops are like dinosaurs. Can't go and browse, ask questions...but then, that's why these forums are here. 😃
#87
Cheers again, i'll have a look see if is can continue the scale into the thousands haha!
Believe me ive done nothing but google for the last couple of days haha, i'll persist and see what else i can find.
