Tire wear
FL
Tire wear
What do you guys find with tire wear? Racing on hard packed clay. Do you find that softer or harder compound tires wear faster?
I've been told that softer tires wear less because the tread lays over. What do you guys experience?
RE: Tire wear
If the tread is laying over, then I'd say you're using the wrong tread pattern. For example, I would imagine the tread on an M3 BowTie on a bluegroove track would lay over like you describe and I would also venture to say that traction would be inconsistent.
PA
RE: Tire wear
softer deffinitly wear faster on my Touring car. on these, i think softer wear fast, medium-hard wear to fast for me... but i dont have $80 to spend on tires every month.
FL
RE: Tire wear
Thats what I was thinking, but others seem to say. Even say a crimefighter tire with a soft compound, that letting the tread lay over gives more tire on the ground and doesn't wear the top of the tread down as fast. Where as using a harder compound the tread stays vertical and you wear the top of the tread down faster.
I just don't really have the dough to experiment with this. 80 bucks a set is ruff
RE: Tire wear
ORIGINAL: slayerphonics
My thought is that it probably doesn't wear fast like you say and keeps the edges clean, but it sure wouldn't be using the tire to it's full potential. I'm switching from BowTies/Crimefighters to CityBlocks/I-Beams because I hear that they wear so much better. Plus, Proline foams are crap. I may try the Revolvers too. But again, I don't have a money tree out back to pay for all these damn tires.
MB, CANADA
RE: Tire wear
everything boils down to the kind of dirt...the amount of traction....and the temp.....there's alot of factor's when choosing a compound to run in the dirt.....Scott Huges has a good grasp on the concept of which tire/compound for which track.....ive read a couple of his article's and it all makes sence.
RE: Tire wear
I've been looking into trying some AKA tires this year but I can't figure out what size tire it its. Are they 3.7(lpr). I need to know before I order them because I already have the wheels I'm going to run.
MB, CANADA
RE: Tire wear
ORIGINAL: losi101
yes they are 3.7 LPR sized tires....If you need zero off go with the aka wheels....if 1/2 off is whats needed....go losi lightweight or i guess you can use proline...im just not a huge fan of anything proline.
RE: Tire wear
Awsome. I used to run those blue groove wheels 1/2 offsets but they only come in the MTR size. I moved on to something LPR so i could have more tire choices.
