Lightest truggy tire
MB, CANADA
RE: Lightest truggy tire
premount..No......Panther is By FAR the lightest truggy combo available.....3.8 Gator's.
here's a little weight chart for refference.
http://www.rctech.net/forum/attachme...ire-weight.doc
CA
I'm running AKA City Blocks but I dont use the AKA inserts, With the Ofna inserts the AKA is lighter than the Gators..if you weigh both (just the tires..no inserts) the City Blocks are lighter than the Gators. Plus if you move the tire around on the rim when you balance you end up needing less weight..takes a bit more time but the end result is well worth it.
