3pks with my truggy question
IN
Does or should the PK-FSM2.4G transmitter module LED on top light up or should it stay on? Im talking about the module that goes on top of the Transmitter. My R603F receiver LED is lighting up RED but the LED on the PK-FSM2.4G transmitter module is dark. I cant get the servos to move. No surprise tho, i know nothing about this radio, only just got it and this is the first time trying to use it. I am new to 2.4 tech. For the record I have the following setup. Can someone please help me get this working? Oh and yes there are batteries in the TX charged 100% thanks. I have the dial set to 0. I have tried re-seating the module. Its to late to call futaba and wont be anyone there till monday. I was just putting in my electronics into my 8ight-t now im crying
3pks Transmitter
R603F receiver
3pks Transmitter
R603F receiver
ON, CANADA
RE: 3pks with my truggy question
power on your Tx & Rx then press & hold the "bind" button on the Rx the light should go solid green, VOILA!
i had the same problem to with mine when i first got it, then i read the manual and it was all good lol
IN
What i am talking about tho is the module on the TX (Transmitter) It has a bind button but when i press it nothing happens, it stays dark. the RX (receiver) tho works np. I am thinking the TX 2.4ghz module is bad right outta the box.
ON, CANADA
when everything is up and running the module should have a solid green light on and the Rx should have the same green light, if no green light's on you did not "bind" them correctly.
if you are having issues reffer to the pamphlet that came with your module or receiver there is a 2 or 3 step E Z P Z explanation how to do it.
you need to press & hold the bind button for a few second's 'till the light switche's from red to green
IN
problem is the LED light on the TRANSMITTER (tx) never comes on. Receiver (rx) light is RED which means its not receiving any signal. i am thinking the TX module is bad. Ill check again when i get home to see.
ON, CANADA
make shure your batts are fully charged. power on the Tx then the Rx. press & hold the bind button. both light's should go green, DBL check by operating the steering/brake's.
IN
thanks for all the info, ill check more once i get home with it, at work now. I am hoping i dont have to call futaba and send it in, which is what im thinking is going to happen. I wonder if the local hobby store i bought it at will just exchange it or will make me call futaba if something is wrong
