help with axial .28 in my hellfire
I have installed a axial .28 in my hellfire. it runs outstanding but the problem is that when i apply the brakes it stalls out. I like tuning myself but I am not to experienced. Can anyone help this problem. I have even messed with the idle. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ON, CANADA
RE: help with axial .28 in my hellfire
your problem is more than likely the adjustment of the linkage from the servo to carb, it took me a good 1/2hr the other day to get mine right. i was having the same issue as you are describing....
you gonna have to play around with it untill it's right, make shure it's kinda clean and pop the air filter off so you can see where the slide is and what's happening to it when you apply throttle/brake
