secound hand nitro problems
hi all
i recently got a secound had duratrax evader st
i replaced its motor and clutch bell berings and shoes
but when i start it up and place it on the ground the clutch starts slipping
and it will some times stall or when i give it some throttle it wont realy move just rev slightly
and stall. theres also alot of fuel coming out of the exaust.
im completely new to all of this so any help will be great thx
RE: secound hand nitro problems
yea i thought it might be to rich
yup a brand new motor and no i havent been able to break it in yet cos i havent been able to get it running properly
TX
Lean it out just enough so that it stays running and go through the break in. After you run a few tanks through it, start leaning it more and more until it's right. There are several different methods to break in a motor. I suggest you research them and find what works best for you. I personally use the heat cycle method and it has worked great for me.
I was going to suggest the heat cycle method also. When in doubt, lean it out so you can reach your 200 degree mark. If you have a stand or some 2X4's handy, why not idle a couple tanks through since it sounds like you're still in the early, early stages.
