KMP T-28C
Old 04-11-2012, 05:02 PM
  #251
wherewaldo
Default RE: KMP T-28C
hey i must of missed something ...what  web site has the perfect take off and landing of the T-28?....I mean the kmp T-28?....if you can ...Magnum RC ...can you send me the link to this site....because i have not seen it yet!....regards,thanks
Old 04-11-2012, 09:00 PM
  #252
Magnum RC
Magnum RC's Avatar
The video is on KMP's website. Find the T-28 and click on it and scroll down, it is right there piloted by Enzo
Old 04-12-2012, 01:26 AM
  #253
wherewaldo
Yes i have seen that video many times ...thats one of the reasons i purchased this plane in the first place!
unfortunately that is the only version out there...and Enzo is kmp professional test pilot !...this is the only kmp T-28 out there  with video evidence
the rest are esm versions  or other manufactures...I wonder why that is?.....just saying.
oh we have about 400ft of grass runway at our field manicured fairly short and level...i hope this is enough room for this plane to rotate
Old 04-12-2012, 08:50 AM
  #254
Greenfuelboy
My Feedback: (60)
I had a KMP T-28 last year that flew great. I lost it due to a Hitec radio issue I had three good flights with it before it locked out. I fly Futaba now.
The plane will stay on the ground until you want it to take off. Have no fear of it it is a nice thing. It tracked straight down the run way I had no problems. Use a metal wheel on the nose gear, my robart plastic wheel cracked on the second flight. The runway is bumpy grass where I fly. I added a one inch block under the nose gear they were too low to the ground. My 20x12 three bladed prop would not clear the ground with out the added block plus the plane looked like it was going down hill with out the block. This was on the older one piece wing version. It was nice you could proceed to take off with the engine at full power until it was up to speed with out worry of the plane trying to lift off by it's self. I would give a little elevator after going full power on the ground and it picked right up. I was using a BME 50 cc classic engine with a custom motor mount I made from aluminum. The run way at our field is 600 feet long and I started my take off at the start. I used a little more than half the runway to take off for the first flight. If you use about 400 feet and not try to rush take off on your first flight you will be fine. After you get a feel for the plane you will be ok and I am sure you will use less runway for your next flight. I may have needed a 22x10 prop it might have been better for my engine but I did not have the ground clearance. I would not use a enging smaller than a 50cc with this plane. Once your in the air it fly's nice, it would fly fast and you could slow it down too. It was a gentle flyer with graceful turns and the 15mph wind that day did not affect it. The plane was a little fast on landing with out flaps. A little better with to land with the flaps. I purchased another one to replace the one I lost but I sold it to a guy who needed a wing two weeks ago. I might buy the new version after I finish my Sea Fury. Another plus with the 50cc engine you do not need nose weight I used my two receiver packs for balance by moving them about a inch behind the fuel tank. They were two 4000mah 2 cell lipos.
Old 04-12-2012, 07:19 PM
  #255
wherewaldo
hey thanks for the info... i have a 55 aerovate I was going to use ....but am going to install an asp 400...roughly 64cc 5 cylinder radial.....this is about a 6lbs engine with the keleo exhaust ring it fits nicely in the cowl ....cool sounding engine ..thats why i am using it..i know its over kill for the size of the plane but i am reinforcing the nose gear.....if you did not have to use any weight with your 50cc gaser...and i know my engine is heavier do you think i am going to have to put weight in the tail?....i don't want to do that ...what do you think?...heres a pic of the engine
ID:	1749597   Click image for larger version
ID:	1749598   Click image for larger version
Old 04-12-2012, 08:18 PM
  #256
Greenfuelboy
My Feedback: (60)
I did not use the tail hook or add the extra servo in the rear of the plane. I used a larger air tank just for extra air pressure it was over kill. I think if you used the tail hook option and extra servo for the tail hook you would have a little extra weight in the tail. I had my air tank on the side and not ran down the middle of the servo tray. I made sure the middle was open that way I could useVelcrobattery straps and the two 4000mah 2 cellliposand voltage regulator could move almost anywhereby sliding the battery'sforwardand back. I wanted them in the center of the plane. I had to take the wing off to check the balance a couple of times to finally slide thebattery'sto the forward to the right spot. I then marked the balance point for the battery's with a permanent marker so I could just install them after they were recharged. In my case I was oneinchfrom the fuel tank. I used a 2000mahNIMH4.8 volt battery for the engine's ignition it was on top of the fuel tank.I will weigh my engine, ignition and 2000mah 4.8 volt battery tomorrow to get a weight for you.
Old 06-01-2012, 02:38 PM
  #257
SAM-RCU
Anyone else get their T-28 in the air yet?
Old 06-01-2012, 05:04 PM
  #258
wherewaldo
hopefully in the next few weeks!
Will have video footage
Have you flown yours?
Old 06-01-2012, 08:55 PM
  #259
cloud_master
Mine is still going together.  It may not be done for quite some time at my current rate.  I'm in boat mode at the moment.
Old 06-03-2012, 04:48 AM
  #260
SAM-RCU
I haven't had a chance to get mine finished. Hope to have it ready by fall. Scott
Old 06-10-2012, 03:20 AM
  #261
wherewaldo
hey guys ...here's a pic of the finished plane...she looks great ...but with the engine that has been installed ...asp 400 5 cylinder radial has me a bit concerned.. she comes in around 26lbs total weight!
any opinions ?
thanks[img]finished%20t28%20023[/img]
Old 06-12-2012, 04:07 AM
  #262
wherewaldo
heres a small clip of the engines first run...
http://www.youtube.com/watch?v=jn6Qy...ature=youtu.be
Old 06-13-2012, 04:55 PM
  #263
sodbuster 1
sodbuster 1's Avatar
Hey Waldo,
I hope you reinforced that nose wheel set up extremely heavy duty.
I just picked up one of these planes from a guy that landed it kind of hard
and the end result was a torn out front gear which pretty much destroyed that 1/2"
thick plywood floor it gets mounted to.
This plane had a much lighter engine up front and a little over a pound of nose weight.
Don't think it could have weighed more than 22lbs....
Old 06-13-2012, 04:57 PM
  #264
sodbuster 1
Can anyone tell me if they used either a DA or DL/DLE and what length spacers they used?
Old 06-14-2012, 01:39 AM
  #265
wherewaldo
i added another 3/4 in to the original 1/2 in of wood ....to give me a bit more clearance for the 20*10 i am swinging
I hope hat will also give it enough strength to take the extra weight of the engine....or i better hone my skills and land her smooth!
Old 07-10-2012, 07:12 AM
  #266
cloud_master
What's the latest and greatest with this bird?  Someone has to have flown this revision 2 build by now?   Mine is still in progress, as I have been building some smaller electric models at the moment..........
Old 07-10-2012, 09:59 AM
  #267
wherewaldo
hopefully 1 week this Sunday!...have had other projects as well
engine runs great just doing the final balancing, final weight is about 26lbs, kind of heavy for this plane ,but i have a lot of power up front....
will have video evidence
Old 07-18-2012, 07:49 AM
  #268
cloud_master
Any updates?  I'm building an E-flite Extra 300 32e, then i'm back to the Trojan.  Hoping to get the good word that this thing will fly!!
Old 07-18-2012, 04:28 PM
  #269
flytaildragger
My Feedback: (8)
flytaildragger's Avatar
I have observed "Green Fuelboy" purchase and own his T-28 and was there when he flew it. He had a 50cc engine in the nose and it also weighed in. Anything less than a 10 pitch prop on a lower rpm engine is not a good thing though. It found the sweet spot when he installed the 22x10 propeller. The aircraft will not take flight on it's own. The tricycle landing gear keeps it pasted to the runway no matter how fast your takeoff run is. You must rotate the plane when up to takeoff speed. Make sure you are moving fast before liftoff and then pull back on the elevator. Yes, it has flown, I know of two who have successful flights with it.
Old 08-29-2012, 05:59 PM
  #270
Jyjkoz
What happened ..No more T-28?  It has been removed from KMP website
Old 01-23-2013, 01:37 PM
  #271
cloud_master
I heard KMP lost their line with the Chinese factory.
On that note, my bird is still in progress.  Any further notes or flights on this bird with the revision 2 wing?
Old 01-23-2013, 08:57 PM
  #272
panhndl
My Feedback: (10)
Mine is all but finished. I have the electric retracts, a Mintor 50 cc engine on front and can maybe finish in the next 10 days or so.
Old 04-29-2014, 10:07 AM
  #273
cloud_master
Anyone get the version two with wing halves in the air? Mine is still sitting. Starting to get the bug to get it together. Have a brand new DA-50 that's been sitting on the shelf for three years waiting for this airplane.
Hope to hear some successful stories of flying this thing.
Old 04-30-2014, 06:40 AM
  #274
pilot lite
Default kmp-t28
mine is ready to go, engine runs great (55cc gas) . i guess i will be the first one. there was alot of concern about this plane. (wing tube to short,cg not right,) this plane needs plenty of ground speed before lift off. mine sits a little nose down. plenty of ground speed and a LITTLE!!! back stick. don't jerk it off the ground and it will fly great.
Old 04-30-2014, 12:02 PM
  #275
cloud_master
When is the maiden day? Can't wait to hear how it went. I'm working on an electric pattern airplane, but when that is finished i'm back on the Trojan.
