Reload this Page >
Heinkel HE 72 build
Heinkel HE 72 build
Old 01-25-2011, 05:08 PM
  #51
desilejf
My Feedback: (20)
Default RE: Heinkel HE 72 build
Casey this is what the clevis looks like, this is a really big one and the aluminum actuator rod is 3/16 threaded for 4 40. Apparently I have both metric and Standard threads in these clevises. The smaller units I used on the ME ailerons are 3mm and I had to silver solder the 3mm to a 2 56 pushrod but there isnt that much stress even at speed, not like elevators for sure.
Old 01-25-2011, 05:11 PM
  #52
desilejf
My Feedback: (20)
HUMMMMHHH I dont post much anymore because I build airplanes and fiddling with this is like work.
Old 01-26-2011, 06:08 AM
  #53
glazier808
glazier808's Avatar
That's just what I need! Perfect! Looks nice!
Casey
Old 03-16-2011, 01:15 PM
  #54
norm
Joining the thread, like to keep up with this kind of work.
Normand
Old 03-23-2011, 06:02 AM
  #55
desilejf
My Feedback: (20)
I have started to cover the wings after a few weeks of getting my Super Chipmunk ready to fly.
The gloved leading edge on the wings was done with balsa, when I got to the center section I decided it would look better done in fliteskin, replicating the actual center section metal covering. I used .007 fliteskin and applied that with Pliobond contact cement, basicly I applied the bottom first because it is flat and has the mounting tabs for the cabine struts. Once that was secure I simply applied the contact cement to the rest of the structure and rolled it right around the leading edge.
Today I will get the wiring done for the wing tip lights and then cover the center and my right wing panel and start to do some rib stitch replicating what was done in the 30's. Scale rib stitch made up some 1/4 inch spaced material for me to use in the prop blast area. The first two stitches on each wing panel were also at the 1/2 interval, 1/4 inch on a 1/4 scale airframe, followed by the standard 1/2 inch spacing.
Old 03-23-2011, 06:04 AM
  #56
desilejf
My Feedback: (20)
Perhaps a picture will show up this time.
Old 07-20-2011, 12:29 PM
  #57
desilejf
My Feedback: (20)
Finally getting back on track with this airframe after completeing several others now I really have to burn the mid nite oil for WBOR.
Old 07-23-2011, 06:28 AM
  #58
glazier808
glazier808's Avatar
Looking forward to seeing this beauty!
Casey
Old 12-27-2011, 08:58 AM
  #59
desilejf
My Feedback: (20)
WOW its late December and I have been remiss on this airframe so I will try to get moving again. Hope everyone had a great Christmas and the New Year get a few of these birds off the bench and in the air.
Old 12-27-2011, 09:03 AM
  #60
glazier808
glazier808's Avatar
I was just thinking of your build, hows everything? Give me a call when you get a min, I seem to have misplaced your number.
Casey
Old 12-27-2011, 09:12 AM
  #61
desilejf
My Feedback: (20)
Hi Casey: Well I have finished the paint work on my 1/4 scale Aerona Razorback, my Speedster and am now building the Struck Boomer Bus from Oct 1940 Air Trails Magazine. Boy they had to really work hard in those days, the fuselage is 1/8 inch balsa soaked and rolled onto a broom stick, then removed glued and a 3/16 keel is shoved down the middle of that as the stiffener. The Boomer is based on the Bowlus Baby Albatros. Jerry Nelsons dad and Harley were very much leaders in the sailplane world after the war. 22 oz all up with 57 inch double gull wing. How they did all this with model airplane cement is beyond me, super glue is even a pain in places. Ordered some silk for this and it is terribly expensive to get the Japanese stuff from Brodak but this wouldn't look good in anything but dope.
Old 02-21-2012, 03:11 PM
  #62
desilejf
My Feedback: (20)
Casey I lost track of your 109 thread, can you send me a link?
Here is my Aeronca
Old 02-21-2012, 06:17 PM
  #63
glazier808
glazier808's Avatar
http://www.rcuniverse.com/forum/m_95...m.htm#10962754
dang, You've been busy!!!
Casey
Old 04-30-2014, 08:39 AM
  #64
FlyerInOKC
FlyerInOKC's Avatar
Ambitious but definitely worth building! Subscribing!
Old 04-30-2014, 12:13 PM
  #65
desilejf
My Feedback: (20)
The lights are all in and center section is done, used G10 to replicate the aluminum in that are. Starting to rib stitch now. I need to order a qt of nitrate black from Acft Spruce to get this thing into silver quickly.
