Liquid Sheeting
RE: Liquid Sheeting
ORIGINAL: jbdismukes
<script type="text/javascript">titleAndStar(67,115,0,false,"","")</script>
am unable to track down the product you describe. Can you provide the brand name and department where it would be listed at Home Depot online?
Jack
Jack
The other thing is to use this stuff over polyester (ladies) slip material. Forget the glass. This slip material is a buck a yard in wally mart and is some strong stuff and lighter than the lightest glass out there.I use it to make jets and it holds up for that. I am not talking about EDF foamie jets.
My Feedback: (221)
RE: Liquid Sheeting
Liquid Sheet would be an improvement over that product. I am familiar with it being a carpenter. This new product is also a two part coating, but is much faster and less messy. The odor is far less offensive as well. Although it is still recommended for well ventilated areas, it has kind of a sweet smell.
Contrary to what has been reported, when applied according to the instructions, it sands and feathers very well. I will say, it feathering is needed, give it a couple more days to cure. It can be roughed up for paint in 24hrs, but is harder in a couple more days. For fuel proofing, I still like good old 5 min epoxy cut with Denatured Alcohol. Plenty of working time, but still drys to the touch in about 20 mins. No need to baby sit the drips for hours.
RE: Liquid Sheeting
ORIGINAL: ram3500-RCU
My Feedback: (221)
RE: Liquid Sheeting
ORIGINAL: tunakuts3d
Is this stuff (liquid sheeting ) Epoxy , polyester, poly ureathane or what?
Paul
Paul
#31
RE: Liquid Sheeting
Paul
Paul
However, I don't believe it makes a hil o' beans difference what the chemistry is, if it works right in our models, and is lightweight. It apparently accepts spray can paint which is always a good thing. But the solvent in spray can paint like Krylon or rustoleum is only somewhat aggressive.
Acceptance of aircraft dope or epoxy paint like KlassKote, or PPG PolyU paints, would have to be tried to determine. If it's a true acrylic coating, it will accept these solvents. However, some of the materials he uses under the coating, may not like the solvents used in those paints.
I'd say proceed with caution if you are doing a foam project as described in the videos and want to use dope as the finish. Hopefully it will work fine
#32
IL
RE: Liquid Sheeting
After looking at the instructions on the web site , I notice that this is a two part formula, A resin and a catalyst, mixed in equal parts.So this tell's me that It cure's by a chemical reaction not by evaporation of a solvent or by absorbing moisture .In fact the user is cautioned to be sure there is NOMOISTURE present in the mixing container or on the mixing and applicator tool's. There are a lot of two part compound's out there and some are more suitable for certain application's than other's and each can have differing reaction's to various solvent's or chemicals.Knowing ahead of time what you're working with could help avoid disasters and unforeseen results or Redo's. I'm saving my money till I get better information.Maybe I should ask for a M.S.D.S.
Paul
Paul
#34
My Feedback: (221)
RE: Liquid Sheeting
States in the instructions that room temp must be above 70deg. and humidity above 35% for proper curing. He also states in his tutorial on line that in extremely dry conditions, one can boil a pan of water in the room to bring the humidity up. Humidity is not an issue for me in Ohio, but it may be in some places. It cured just fine within the projected time frame. So far, the product has worked just as WOW says it will, for me. Just giving me assessment thus far having used the stuff. I'm always looking for new and better ways to do things. Invention marches on, and I'm glad it does.
#35
RE: Liquid Sheeting
What does it smell like?
#36
My Feedback: (221)
RE: Liquid Sheeting
ORIGINAL: croatiablu
$20 for 8 oz mixed... Find out what it is or what it is close to in chemistry and use something similar. What does it smell like?
#37
RE: Liquid Sheeting
Honestly, I like the Idea that he is an American company and after meeting both him and his wife when I was in Florida, I saw his enthusiasm for the hobby and the builder, so I am happy to support him with purchases. I was so impressed with the stuff and the planes he had on display that were done with it, I ordered 3 batches when I got home. He sold out at the show. His 80" Marauder is very cool, but I may pull the trigger on the B-17. I have always wanted an RC Fort.
$20 for 8 oz mixed... Find out what it is or what it is close to in chemistry and use somethingsimilar. What does it smell like?
8oz mixed for $20 is steep.
#38
IL
RE: Liquid Sheeting
I dont mind paying a premium price if the product is unique and offer's advantages over some similiar type products.However I want to know what the product is made of so I can make comparisons and decide if it's truly unique or just a packaging and marketing method to sell something that is available at a lower cost.
paul
paul
#40
RE: Liquid Sheeting
ORIGINAL: glazier808
I bought two myself Ram, looks like a great product, and I can't wait to use it.
I wouldn't buy my planes from Walmart, why should I cheap out now? I don't feel it's overpriced for what it is.
How far does this go interms of coverage? I have a plane that would be a candidate for this but it is roughly 70" long and 60 wing span. All balsa. I think it might be prohibitively large for batches so small (8oz).
#41
RE: Liquid Sheeting
The instructions say that you dont want to go back over areas you have already applied it to. This tells me(mind you I have not used mine yet)that you dont need several coats like you would with epoxy. It settles out and you just feather out the finish. I would bet, if applied correctly, the product would go further than you think it would. You would'nt want a heavy build up anyways! Thin, strong and just enough flex not to be brittle.
#42
RE: Liquid Sheeting
How far does this go in terms of coverage? I have a plane that would be a candidate for this but it is roughly 70'' long and 60 wing span. All balsa. I think it might be prohibitively large for batches so small (8oz).
#44
NJ
RE: Liquid Sheeting
Ram3500 the main question for me is , how far does the 8oz go. No one seem to answer that. For example can some one tell me they did a Ziroli Stuka with 8oz or 10oz or maybe some other GIANT SCALE over 80". Because I could get water base poly and 10 yds of polyester for that price and do a few giant scale planes with it. SOO can someone please give us an idea how far 8 oz will go on a 80 + inch plane. Your personal experience.
#45
My Feedback: (221)
RE: Liquid Sheeting
Several posts have been made regarding coverage. I think the subject has been covered. It is a new product and I'm sure we will get more feedback. But don't be fooled by the 8oz number. It goes a long way, as does resin. It flows nicely, as far as I have seen, and accepts Krylon and Rustolium paints. These I have used so far. Here are the repairs I made to my P-38, finishing it off with LS, Rustolium primer for the Grey, and Krylon camo for the green. Used maybe an once of A and B.
#47
RE: Liquid Sheeting
I watched the video.
I think this guy is onto something!
For foam, it seems to be a great way to create a finish that could be detailed. And as the gentleman said, you cannot tell it's a foam model when his product is applied.
Obviously, glass and resin, even epoxy based, will create more work than necessary for these small models. Weight also?
Larger models could be balsa sheeted followed by LS.
I have an electric project in mind and I'll definately give this product a try.
Please view the video. You will see that this modeler does a great job with his product. I also like his use of aerosol cans. I did go and sell my compressor. [sm=bananahead.gif]
#48
RE: Liquid Sheeting
I have followed many of Fahim's (wowplanes) threads on rcscalebuilder and he covers the liqquid sheeting process very well. It is not something he just buys off the shelf and re-bottles. He worked for a couple of years perfecting what is now called liquid sheeting. He is an honest guy and will answer all of your questions if you ask him. Most of what I have read on this thread is from guys who have no idea of what liquid sheeting is. An 8 oz. order if applied correctly will cover a 62" model with 2 coats. It can be applied directly over balsa and will produce a hard surface than can be sanded and painted. The liquid sheeting when applied over balsa will be flexible and not crack (within reason).
Aaron D.
Aaron D.
#49
My Feedback: (221)
RE: Liquid Sheeting
ORIGINAL: CGAV8R
I have followed many of Fahim's (wowplanes) threads on rcscalebuilder and he covers the liqquid sheeting process very well. It is not something he just buys off the shelf and re-bottles. He worked for a couple of years perfecting what is now called liquid sheeting. He is an honest guy and will answer all of your questions if you ask him. Most of what I have read on this thread is from guys who have no idea of what liquid sheeting is. An 8 oz. order if applied correctly will cover a 62'' model with 2 coats. It can be applied directly over balsa and will produce a hard surface than can be sanded and painted. The liquid sheeting when applied over balsa will be flexible and not crack (within reason).
Aaron D.
Aaron D.
#50
RE: Liquid Sheeting
Aaron,
My fellow Floridian, you have me convinced!
And yes, I have a good feeling about the guy also, my guess is he "is" one of the good guys. Well, he does offer those rivets like I do also. [sm=bananahead.gif]
