Are all Top Flite warbirds stand off scale?
#51
My Feedback: (-1)
RE: Are all Top Flite warbirds stand off scale?
ORIGINAL: ARUP
If you are building for non-competiton, then 'no worries' if you build it the way you want it to look. If someone has negative comments then let them know you will glady exchange yours for theirs and they can 'fix' it! If building for competition then find 'good' documentation, understand the 'rules of engagement' in scale competition, compete, learn and have fun. Personally, I'm not 'into' competition because they are all 'pretty'. Just like beauty pagents... most of the contestants are very attractive- not too many unattractive ones!
The way I see it, the most accurate WarBird is one that has all the grease, grime, bangs, dings, & weathering just like in the
battle field. and thats how I'm going tobuild mine."factory fresh" does nothing for me.
right now I'm doing all the hydraulic, electrical, etc lines behind the instrument panel. 99% of the people who see my P-40
won't even notice.. lol. heres some pics of parts not found in any plans.
this is for my Top Flite Gold Edition KIT. still have to make it more presentable
here the instrument panel with gunsight
and with a working gunsight light
#52
My Feedback: (49)
Speaking of Realism check out these models ... They may not be capable of flight but are unbelieavable, just the same ... http://rojasbazan.com/video.htm
#53
ORIGINAL: dvs1
The prop is static which i know they didnt use uncuffed till after the war, will probably switch out for cuffed.
Here is some of the pics I have of the doors. The only problem is the inner doors should have a slightly closer gap of about 3/8 of an inch. You cannot do
that with a Top Flite mustang without completely rebuilding the landing gear mounting structure and moving everything inboard. Since mine is not 100% scale it did
not matter that much.
#54
The spinner is also Aerotech. It is scale 5.5 inch however. My cowl is by Spychalla and was made to scale proportions.
Just in case the question arises. So far options are Aerotech scale spinner and prop, guns, drop tank pylons, inner and outer gear doors, and small cast resin scale
accessories. Canopy is functional sliding but is the Original Aerotech made for their composite mustang, some time was taken to build up the fuselage to make it fit perfectly.
They now have one specifically designed for the Top Flite mustang.
Gear is Sierra, and wheels are also Aerotech.
As said earlier cowl is by Spychalla.
Cockpit is Dbalsa
Aluminum is Aerofoil by Meister scale.
Most of the options took little time to install, Even the Gear doors took very little time. Probably spent more time measuring and marking everything
right then actual cutting and installation.
To be perfectly honest before I started this project I really wanted the Aerotech mustang but didnt want to spend the cash. I had The Top Flite Mustang partially assembled
and just figured it made more sense to just modify it to what I wanted. Its still not finished however, still awaiting some paint, dry stencil markings, servos and mounting engine.
I also decided to run all control rods internally instead of externally.
Cockpit is Dbalsa
#55
OK just take down the Chandelier above the front door and hang the P-51 there. Looks great. would you sell it to me for $200 shipped? Sorry.
