Storing Epoxy Resin
Storing Epoxy Resin
The last time I bought some West System epoxy I was forced to buy a larger quantity than I would have liked due to no stock of smaller bottles at my local supplier.
The resin itself seems to last OK but I have had the hardener go off before.
Now that the temps are rising in our part of the world with summer arriving I am wondering what is the best way to store the resin and hardener? I do have a fridge in my workshop which I use to store my CA adhesives and other essentials ( such as beer!!! ), should I store the resin and/or hardener in there?
My workshop is a steel shed with a dark blue roof and temperatures regularly reach well over 100 degrees F in there.
Cheers
Mick
Cheers
Mick
RE: Storing Epoxy Resin
I have just had to abandon the shed as the temp hit 36 deg C (>95F) and storing resins and glues through summer in such a condition is always a concern.
I have an old fridge in the shed, set at minimum temp (or maximum, whichever way you look at it), not cold but just keeping things cool.
That is where I store all volatiles, including paints, thinners, resins, fillers, etc, etc.
It has saved me a lot of wasted chemicals in the past few years, and is worth every penny of it's meagre running costs.
ORIGINAL: mboland
That sounds like a good idea but it does not suit the beer I keep in the shed fridge!!!!!!!!!!!
Will the epoxy store alright at the very cold temp of the beer fridge?
FL
Hmm, I have had a gallon of resin and two quarts of hardner in my garage for three years. All have the pumps on them and I just used some a week ago, was just like the day I opened it. And we get some temps in Florida, 90's+ and tonight's going into the 20's.[X(]
Here's West's take on cold and hot, and long term storage.
http://www.wessex-resins.com/westsys...e-bonding.html
SC
I have used WEST products for years in boat repair and the cold weather has never been a problem. Once I has a situation where the boat would be moved outside int zero degree weather during cure time of the epoxy. So I called WEST & they told me that it was okay in that if the product got very cold, curing would stop and then continue when the ambient temp returned to normal. And this is exactly what happened! It is a great product use their pumps and you can't go wrong.
I'm building top fuel funnycar for one of the better teams and I'm using West Epoxy to install all of the 'tin' mounts and the hatch railing as well as a few other modifications. I also use the 610 epoxy adhesive in the caulking gun tubes. The stuff is very strong and easy to apply if you warm it up a bit. It's 65 in the shop and the stuff is a bit thick in it's natural state. I just hange a drop light in the cardboard box that I keep the cans and tubes stored. I use a heat lamp in the areas I'm working on. The resin wets so nice. It actually flows by itself. You really don't have to completely wet it out. It spreads more or less by itself. It's really nice when you are working overhead under the body.
As far as storing it West said about the same as previously noted. Don't get it too cold. Just leave the pumps in the containers. That's hard to do after tossing a bunch of polyester out after a month or so.
