TP Sea Fury
RE: TP Sea Fury
DLE 20, go gas, save money on both fuel, and baby wipes for all the goo glow motors are a dying breed with the new smaller petrols appearing gets a pitts style muffler, good to go
RE: TP Sea Fury
I AGREE !
DLE 20 would be perrrrrfect for the business end of this Sea Fury for a gasser..........
less money, less mess less expensive to run, good solid, reliable gasser.
Saito 100 if your a glow burner..........
RE: TP Sea Fury
i need to come and live with you guys, gas is pushing £7.50 stirling a gallon here,thats about$11, but even here, i would still loose the farting 4 strokeour glow fuel is still a LOT more expensive than gas though
My Feedback: (60)
AZ
RE: TP Sea Fury
The gasser would be a good choice simply because the airplane builds notoriously tail heavy and you will need the weight up front anyway. Then there is the additional perks of cheap fuel and user friendly operation. Last, but certainly not least in my book, the ability to use just about any sort of finish without the need to be glow fuel resistant.
CA
RE: TP Sea Fury
ORIGINAL: alanc
NY
RE: TP Sea Fury
I use an O.S. 1.08 with an APC 16 x 8 side mounted with a pits muffler. All that fits inside the cowl to keep the scale looks. I also use a McDaniels glow driver and 6 volt 2000 mah pack mounted on the firewall. With all that, I still had to add weight to the nose - 10 oz. All fueled up it weighs a little over 14 lbs. I ended up using the Robostrut ready 100 degree Robart retracts (I think 632?) that are capable handling 12-24lb aircraft. By far it is the best flying warbird I have...it flys fast and still slows down for landing. Have fun, its a great airplane!
