Reload this Page >
SisT FW-190 A8 Schwarze 8
Old 10-26-2012, 09:17 PM
  #676
Chris Nicastro
Chris Nicastro's Avatar
Default RE: SisT FW-190 A8 Schwarze 8
I also have the Saito 300 twin dual carb but Im leaning more towards a gas engine like the FG 57 version. Id like to see this combo run before I decide to keep or sell the engine. I wonder if it has enough power to fly the plane with authority not just put-put around.
Old 10-26-2012, 09:38 PM
  #677
fw190d9
fw190d9's Avatar
Guys, the G62 has more than enough power to fly the Sist 190 with authority, A g45 would fly it fine too. I use a three blade prop to slow mine down a bit. I have around 70 or so flights on mine now and it has held up well. Some tips to increase durability are to exchange the aluminum down links on the gear for steel ones, Darrell should be able to supply them. Any side loads on landing will bend the aluminum ones badly. I also layered the inside of the spinner cone with a layer of carbon fiber as the fiberglass spinner is very thin and will flex around the cut outs for the prop blades. I built wood elevators and rudder and covered with fabric and used Robart hinges as the stock hinge pin will work in the beginning but will quickly wear out from vibration and get sloppy. I just took delivery of the Sist 1/4 scale 190 A. So look for a build thread over on RC scale builder sometime soon.
E
Old 10-26-2012, 09:39 PM
  #678
glazier808
glazier808's Avatar
Nice!
have you picked a scheme yet Evan?
Casey
Old 10-26-2012, 09:49 PM
  #679
fw190d9
fw190d9's Avatar
No, not yet. I might do "Blue 13" again, but haven't decided yet. I will probably use my moki 250 in it tho. I gotta finish Dornier no2 first.
Old 10-26-2012, 09:51 PM
  #680
glazier808
glazier808's Avatar
I must admit, of all the builders out there...you are the one builder that I wonder "what is he's doing this year"
lol
Casey
Old 10-27-2012, 08:49 AM
  #681
BobH
Freind of mine also got the 1/4 scale Sis-T. Moki powered too. It's got to be an impressive looking/flying plane.
Will be looking for your build Evan over on RCSB.
FYI, there's a gent in South Africa flying his Sis-T with the Saito 300 twin. He told me that it flyies it just fine.
Old 10-27-2012, 12:57 PM
  #682
esacco
My Feedback: (30)
All the amazing advice is priceless! Evan.... thanks for the head's up on the gear scissors. I will call Sierra and order those right away.
On your 190A what was your final flying weight?
Thanks!! Eric
Old 10-27-2012, 01:43 PM
  #683
kwik
kwik's Avatar
Blue 8 here is a Sist scale 1/5 with a Zenoah G-62; (The other one is a Platt, just like invertmast's; With a Laser 300 V)
http://www.youtube.com/watch?v=ciylGo790mc&feature=plcp
Affa is going to put a Saito FG-57 in his Sist A8.
The Platt with the Laser 200V again;
http://www.youtube.com/watch?v=TKqp8zCW3Wg&feature=plcp
Old 10-27-2012, 01:54 PM
  #684
fw190d9
fw190d9's Avatar
She's a bit porky at 30.2 lbs, but flies just fine at that weight.
E.
Old 10-27-2012, 02:13 PM
  #685
Reverend
Reverend's Avatar
Hey guys,
greetings from Austria Thanks for all the good information in this thread!
I am currently restoring a used and damaged SiSt FW-190A8 I purchased from a guy who cartwheeled it on landing. For power I spoke to Stephan Siegemund and I am using my FS400AR. After some work on it the engine is putting out just over 4HP, thats a bit more than the G45, and according to Stephan it will be more thank perfect for the plane. I am trying to save as much weight as possible though and am looking towards 26.5lb tops. Some tweaks so far are throwing out the servos from the tail feathers (saves 10,8oz) and redoing the rudder from Balsa (saves 12,3oz).
Rev
ID:	1815369   Click image for larger version
ID:	1815370   Click image for larger version
ID:	1815371   Click image for larger version
ID:	1815372   Click image for larger version
ID:	1815373   Click image for larger version
ID:	1815374   Click image for larger version
ID:	1815375   Click image for larger version
Old 10-27-2012, 02:18 PM
  #686
kwik
kwik's Avatar
Perhaps the following small changes would help on the Sist 1/5 scale A8 final weight;
-Redo rudder AND elevators using balsa and be super-fixated on weigth when doing so.
-Select a light weight tail-wheel solution.
Old 10-27-2012, 02:28 PM
  #687
vertical grimmace
vertical grimmace's Avatar
ORIGINAL: esacco
Thanks!! Eric
Careful here. I think Evan is referring to the down lock here and not the oleo (scissors?). I can see why the down lock might be an issue if made from aluminum. In fact, I saw one of Evans fail at the WBOTR a couple of years ago. I will have to think of this mod as I am putting this gear in my 1/5th Andersen TA 152. I will have to look at all of the other issues about these gear as well. The tail wheel retract included. While the Sierra seem to be the best thing going, they are not without their faults, it seems.
Old 10-27-2012, 09:23 PM
  #688
Reverend
Reverend's Avatar
ORIGINAL: kwik
kwik,
I am a bit reluctant in making the elevators from balsa just yet. i know of two guys who fly the FW with a seidel 7-70. That engine weighs about the same as the fs-400AR and they both need 500g of lead in the nose. I have saved just the equivalent to that in the tail and I want to check the CG before I have to put lead in the back as there is not much space under the cowl for batteries and stuff with the radial installed. I do have everything here to make them CNC milled by a friend.
rev
Old 10-27-2012, 09:26 PM
  #689
invertmast
My Feedback: (23)
invertmast's Avatar
My 1/5 190 (not a sist, but the same size) took 4.5 pounds (2,040 grams) of lead in the nose to balance it with a seidel in it
Old 10-27-2012, 10:10 PM
  #690
Reverend
Reverend's Avatar
ORIGINAL: invertmast
wow, thats a LOT! the G62 guys I have talked to need about that but with a much lighter engine...
I have watched your videos on youtube, big complement on the details. I habe taken quite some ideas from your focke wulf. eg the hinged cowl doors!
rev
Old 10-27-2012, 10:12 PM
  #691
invertmast
My Feedback: (23)
invertmast's Avatar
Yea it is allot. And everything i could possibly fit infront of the cg is infront of it
Old 10-28-2012, 04:23 PM
  #692
BadLemon
My Feedback: (37)
BadLemon's Avatar
Does anyone know it the 1/5 kits are will be available in future? I see E got a 1/4 kit, just 5K is to far out of my price range. I think I'd die if I crashed it.
Old 10-28-2012, 11:14 PM
  #693
dvs1
dvs1's Avatar
You might check with Vogelsang Aeroscale, They still have them listed on their website but I have no idea of the availability.
And 5 K is pretty much only airframe, retracts and scale accessories. Thats not including the Moki that is a possible engine combination and the cost of electronics. Definately the best 1/4 scale FW-190 out there but unless I am discovered by a long lost rich relative it will be forever out of my reach.
Old 10-28-2012, 11:53 PM
  #694
ticketec
ORIGINAL: dvs1
Wow, I was wondering just how much they really were going for.... unfortunately, I'm with you with on this one DVS1, not in my price bracket at the moment [&o]
dave
Old 10-29-2012, 05:06 AM
  #695
kwik
kwik's Avatar
ORIGINAL: ticketec
ORIGINAL: dvs1
dave
Dont forget that 1/4 scale WWII warbirds are pretty big planes.....Back in the times the designers sort of concluded that 1/4 scale was okay for WWI birds, and 1/5 was okay for WWII planes. In the mean time the world has moved on, and in many cases we find that 1/5 is a bit small for even WWII planes.
Therefore, I buildt Roy Vaillancourts ( Vailly Aviation) Fw 190; It is scale 1/4.5, in other words just in between 1/5 and 1/4.
I find 1/4.5 to be a rather nice size for the Focke Wulf. If I'm not mistaken, Petraush (Also Vogelsang, me thinks) is 1/4.5.....but is isexpensive too.
ESM's big 109 is scale 1/4.5....Maybe ESM one day will come with a 1/4.5 Focke Wulf too. Lets face it, a plane of that size, with the Sist or Petrausch detail level and quality of parts is bound to cost mucho dollares.
Old 10-29-2012, 07:20 AM
  #696
BobH
I have a friend who has the 1/4 190 from Sis-T. I haven't had a chance to see it yet but I am looking forward to it in the future.
I also know that Stephan has been trying to sell all the molds etc for the 1/5 sized planes. No luck so far in that department. It's a large investment I'm sure.
Old 10-29-2012, 07:24 AM
  #697
invertmast
My Feedback: (23)
invertmast's Avatar
Hey bob,
You buy em, ill mold them
Old 10-29-2012, 07:32 AM
  #698
BobH
Thomas you would do a great job I'm sure!! Problemo is that Stephan wants Major$$$. I wouldn't live long enough to break even! lol
Old 10-29-2012, 07:36 AM
  #699
invertmast
My Feedback: (23)
invertmast's Avatar
Lol. Yea i can imagine, if someone wanted to buy my F14 molds, it would take a big chunk of change. Any idea what stephan is wanting for the 1/5 molds? I would think $10-15,000 would be about right if he has all the cut files for the structure, templates etc.
Old 10-29-2012, 07:37 AM
  #700
BobH
I don't know what he wants?? You can email him though at his Sis-T web site. You're a young guy.. you have time!! Tell your wife I said it was ok! laffs
