spitfire with a differance
RE: spitfire with a differance
i see its not considered a proper warbird unless its going 150 flat out, with a weed whacker up front, can you guys not even see the techonolgy in this airfix size machine, that flies? i am in wonderment that a 1/72 scale spitfire can be built, and flown with radio, i look in awe at the new parkzone offering of a 20inch span mosquito, and think? WHAT THE************ the techonolgy we so much take for granted simply staggers me, does it not you guys?
must admit, the profile bit does look silly, it should be within the realms of possibility to form a scaleish fuzz in foam, that vid of the kingfisher is amazing, wonder just how small it will go? will be spy in the shape of a simple Bee ever be done? meanwhile, i have ordered the parkzone 20inch span mosquito, couldnt resist
It looks pretty good in the air. I suppose full fuselage would cost slightly more to produce, and would be more fragile.
Building a full fuselage one should be quite feasible, on your own too. Just have to miniaturize the building process...
I suppose much of the warbird crowd enjoys small scale details in their planes. Including lots of small details in a tiny aircraft might be a challenge.
