dummy R-2800 Pratt & Whitney
My Feedback: (221)
RE: dummy R-2800 Pratt & Whitney
ORIGINAL: Glacier Girl
Dang Gary, Beautiful workmanship.
No wonder the P-38 turned out so well.
AL
Amazing skill and imagination Ram - and I really had to grin when I read your coment about the Ambroid. My wife used to make me shut the door and I was always a little goofy when I came out. I remember we had everything all pinned and straight and added the glue before going to bed (long cure time). Sometimes in the morning you faced a disaster if something came unpinned during the curing process. Again, beautiful work.
My Feedback: (221)
ORIGINAL: JPate147
My mom didn't like the smell, and later my wife liked it even less. Guys these days don't know how good they have it.
hey Ram..................................[:-]
If you could?...... I would like to see some nice close up's of the spark plug wires especially by the spark plug area... photo's of what tools and hardware you used
My Feedback: (221)
ORIGINAL: 77chickenhawk
#31
My Feedback: (221)
Nothing special in tooling. I used an Exacto knife, razor saw, dikes, my trusty Makita cordless drill, a Dremel with the thin cutting wheel, and a couple different size pliers. Most all the work was done in hand.
Oops, I forgot the crank case and housing. They were made with the help of a band saw, and a disk sander.
#33
Gary,
This is one of the most informative threads I have seen in awhile. Very well done and timely as I am about to build the dummy radial for my Yellpw P-47. I have the Aerotech kit which has the nice center casting, the cylinder and the round housing that holds it all together. I will just need to follow what you did for details and I will have a nice looking dummy radial.
Can you tell me more about bending the circular wire guide? You said you filled the tubing with sand and bent it around the form. Can you supply any details or points on how to do that so I will not go through 25 pieces of tubing to get 1 finished part!
Also I went to the wow planes site. Can you tell me more about the Liquid sheeting? I see you can get a nice metal looking finish with it Curious how you use it to obtain fillets and it general workijng prperties.
John B.
John B.
#34
My Feedback: (221)
ORIGINAL: John Baligrodzki
Gary,
John B.
Gary,
John B.
When drilling the holes for the spur tubes, I tried using a pilot drill, but found it caused the full size to grab. I wound up using the correct size very slowly, and it worked just fine. I glued the spurs in with think CA, running it in first, then placing the small tubes into it. Made a nice strong joint. The top cowl bolt is right in between the two top cylinders, so I cheated just a bit and rotated this ring so as to make room for my allen wrench in the center of these jugs. Otherwise the top spur would have been right in the way of installing the cowl. Good to look ahead for things like this when doing your dummy design.
The LS is a nice product that seals whatever you paint it on. It can be painted over foam and then coated with whatever type of paint you like. In this application, it fills the corners and joints with a little material that rounds these areas out and nicely simulates the soft fillets of casting. It is dry to the touch in about an hour, and ready to paint over night. It sands nicely as well. Balsa, painted with LS, and then sanded, will look like metal when painted, no grain showing. Sometimes it takes two coats, but it is light. Much easier than glassing in this case. It is a two part mix and has a working time of about 20 min.
#36
IL
Ram, I noticed you mentioned the drill bit grabbing when you were drilling into the plastic. If you grind a flat on the cutting lip of the drill so it scrapes rather than slices into the plastic it wont grab as it breaks thru the exit side.Grinding the flat can be tricky on really small bits. Found this site that pretty much explains it.
http://www.bertram31.com/proj/tips/drill_acrylic.htm
Paul
Paul
#37
My Feedback: (221)
ORIGINAL: tunakuts3d
Paul
Paul
#40
Gary,
Here are a couple pictures of mine so far. I still neeed to add the magnetos and some more detail before I airbrush it with siver and gold. The decal will be last. What else am I missing? I like this engine because it is 3D. I modified it but it was a Williams brothers basic kit to start with. This will be for the Corsair if I end up getting the DLE 222.
#41
My Feedback: (221)
ORIGINAL: NCIS
Gary,
Gary,
#42
My Feedback: (221)
A few of my reference pictures for various details. Accessories and various parts evolved and changed over the production run, so a wide range of appearances is what you find on these details. Also, restored engines don't always look like the original productions because of the way they are painted. I tried to find pictures of original in service engines for the paint. Good close ups of restored engines are good for the accessories and other details.
#44
Gary you are simply amazing. You have skills beyond my imagination. I'll ship my dummy radial to you if you can work your magic on mine for me!!!
Barry
Barry
#45
My Feedback: (221)
ORIGINAL: NCIS
Barry
Barry
#46
Gary,
I'm not in any hurry and as long as I get it back by Christmas I'll be happy. Email me with your address and I'll ship it off to you. When your done just let me know how much I owe you OK?
Thank you,
Barry
[email protected]
Thank you,
Barry
[email protected]
#47
My Feedback: (221)
ORIGINAL: NCIS
Gary,
Thank you,
Barry
[email protected]
Gary,
Thank you,
Barry
[email protected]
There is another option, if you like. I can build the engine on a 1/8" ply just large enough for the dummy. Then you can add whatever you need around it, when you get things ready to install. As I type, it seems this is the best in this case. We had the luxury of having the plane on hand. The latter will work fine. You won't see the perimeter in the cowl anyway, or not much anyway. I will need the size of the cowl though. I'll figure the correct scale. Should be a little easier being larger.
Gary
PS. I'll add construction pictures to this thread as I work on it so you can keep tabs on the progress, and yell at me if you don't like something.
#48
I'll go with option 2 so I can make it fit after your done and you send it back. I can tell you now it fills the front of the cowl. This dummy is the biggest Williams Brothers ever made. I will also send the exhaust stacks if you want to go to the trouble of installing them.
Thanks for accepting such a tedious project for me.
#49
My Feedback: (221)
ORIGINAL: NCIS
Option 2 is good. It will be easy to center it on your engine.
#50
Gary,
I emailed you with the tracking number from UPS. It should be there by Friday at the latest. It went out early this afternoon. Can't wait to see when you get a chance to start on it. I'm really looking forward to pictures as you go. You are an outstanding friend for doing this for me!
