CARF-Models P-47 Thunderbolt
#101
RE: CARF-Models P-47 Thunderbolt
No disagreement on any of your points over CARF kits ..... they are that stunning that personally I'd give up my 'left one' to be able to have one.
Where I sit is that I'm still needing to learn a lot re building not having built one previously, and still feel I need to get a lot more stick time on smaller (60-120 sized) warbirds before risking taking to the skies with such an amazing aircraft - as in my opinion, even though it makes sense to me that they should be easier to fly than the smaller ones re their scale (god knows that's true for RC heli's), I feel one should be a very proficient scale flyer to give justice to such an aircraft, and I'm not - YET!
So for now, I'll wait to build my kit, enjoy and follow your builds with great enthusiasm (and a little envy if I'm honest), and keep in mine that old theory of "one step at a time".
Eodcdrfl (12-15-2020)
#102
Hello Richard.
I'm building the P47 but I have two problem.
Do you have pics of the tailgear mount because there is no munt to adapt the Sierra tail gear to the Internal Mount....?
Do you Have also a pics showing the connection beetween the flap to the flap pushrod's?
Thanks a lot.
Best regards.
Philippe
Thanks a lot.
Best regards.
Philippe
#104
THnaks a lot richard.
Could you give me the dimension of the Tail gear mount? and the location of the hole?
Thanks a lot.
Best regards.
Fifou
Thanks a lot.
Best regards.
Fifou
#105
My Feedback: (156)
Fifou,
I am sorry, but I cannot provide that information as it is too difficult to get inside the plane to acquire.
You should have received the tail gear mounting adapter plate (plywood) with the kit. IF you did not, get in touch with your CARF dealer and obtain the plate.
The flap clevisis were missing in my kit, but CARF sent them to me.
#106
My Feedback: (156)
P-47 fans:
Mine is getting close to DONE. Will likely be flown before all paint, detail and weathering is completed.
Balance is very, very close to perfect. Engine run up needs to be performed, along with prop check for proper pitch/rpm.
A bit more retract exercise, then it's up, up, and away
Builders Manual is at 105 pages. After first flights, I can close the book (literally) on the manual and make it available to CARF.
#108
My Feedback: (156)
ONE SERVO per surface, with the exception of elevator, which uses ONE SERVO for both elevator halves.
If you want to save yourself some grief, use JR8611s all the way around. All servo pockets and mounting holes are cut for this servo.
The 8611 is bullet proof. Probably a bit overkill for this bird, but I suggest you take no chances/cut no corners.
I am using Hitec 7955TG servos all around simply because I am a rebel at heart
Seriously, I arranged with Hitec long before I realized the pockets were all cut for JR.
I have used the 7955TG on my last 3 giant scale aircraft, including IMAC and 3D types, and they perform great.
For simplicity sake, if I were to do it again, I would just go with JRs.
#110
Hello Richard.
Thanks for all your information.
Do you have pics of the ajustement of the part n°7 (in your first post) in the cowl?
Can you explain where goes the 4 phenolic parts n°25.
Thanks a lot.
Best regards.
Philippe
Thanks a lot.
Best regards.
Philippe
#115
Hello Tnkas for your answers Richard.
I'm building mine folowing your information thanks a lot.
One more point I have a question
You have use the Comp ARF pneumatic set. In this there is 2 air cylinders. Could you give me the spec of this please?
Are they there
[link=http://www.robart.com/products/38-x-1-stroke-air-cylinder]1'' cylinder[/link]
or there
[link=http://www.robart.com/products/38-x-12-stroke-air-cylinder]1/2'' cylinder[/link]
Thanks a lot.
Best regards.
Fifou
Are they there
or there
Thanks a lot.
Best regards.
Fifou
#116
Looks great Richard, and to be fair I (personally guys) feel that that 'Bonnie' scheme is one of the best ways to really show off the Razorback lines ....
#117
My Feedback: (156)
The P-47 pneumatic kit comes with the Robart 165 (NOT the 165s)
http://www.robart.com/products/38-x-...e-air-cylinder
#119
Hi, Richard
Which throws do you use for the flaps, ailerons and elevators?
Where is your CG placed?
CARF Pilot
CARF Pilot
#120
My Feedback: (156)
Balance and Flying
The airplane balances at 25% of cord at the wing root. Measure back from the leading edge 15.5 cm - This is the correct location of the Center of Gravity. Achieve the proper CG by shifting components inside the aircraft. Battery Packs are generally the heaviest items inside the aircraft; they can be positioned to achieve balance. A “worst case scenario” will require the addition of nose or tail weight to arrive at the proper CG.
DO NOT FLY UNTIL CORRECT CG HAS BEEN ACHIEVED!
Control Throws
Ailerons and Rudder are mechanically limited by the aircraft structure and should be set for maximum travel without binding. Flaps should be set for maximum deflection, assuming the flap pushrod is on the outermost hole of the flap servo control horn (as pictured in the manual). Flaps should also be set up on a proportional channel on your radio so that any flap setting can be dialed in. Elevator travel is set to 2 cm up and 2 cm down.
Control Throws
#121
My Feedback: (156)
P-47 fans:
Things are getting exciting as mine continues to come to life (amazing what a bit o' paint will do)[8D]
Only 3 more stars and bars and one more black fuselage band and all the painting is DONE!
Some additional weathering (which, btw, NEVER FRIGGIN ENDS!!!) and the kill markings, and she will be officially ready to christen and launch!
#123
ORIGINAL: RichardGee
P-47 fans:
P-47 fans:
REGARDS
JOHN
#124
Hi Richard
Great work!
I can't wait to hear your report on the maidenflight, I hope you will be posting a video or two! It's flying season over here in the high north, so I will not be starting my build in earnest until the fall sometime.
Cheers
#125
My Feedback: (156)
A "wash" not so much in the Dave Platt method, but yes, I will be spraying a very thinned mixture of dirt and grime shaded paints over various areas and working them into the nooks and crannies.
A conventional wash will not work well, however, until the main body panels have been roughed up a bit, either via Scotch Brite pad or very fine wet dry sandpaper. The wash just will not adhere evenly to the glossy surface.
Weathering will remain a work in progress for some time to come, but in the meantime, main areas of painting and first flights can be accomplished and Builders Manual COMPLETED.
