Reload this Page >
Foam Core wing retract install
Old 03-25-2011, 02:33 PM
chistech
Default Foam Core wing retract install
Hello all,
Throughout the years all I've ever done was construct built up wings and I am unfamiliar with installing retracts in foam core wings. I will be starting a Jemco hellcat and possibly a P47 and could use some ideas. I understand there was supposed to be a additional set of instructions with the Hellcat for the retract install but my kit didn't have them in it. Does anyone have a copy of those?
Thanks in advance,
Ted
Old 03-25-2011, 03:10 PM
All Day Dan
All Day Dan's Avatar
Default RE: Foam Core wing retract install
Ted, Here's what I do. Dan.
ID:	1584086   Click image for larger version
ID:	1584087   Click image for larger version
ID:	1584088   Click image for larger version
ID:	1584089   Click image for larger version
ID:	1584090   Click image for larger version
Old 03-25-2011, 03:15 PM
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
ORIGINAL: chistech
Hello all,
Thanks in advance,
Ted
I don't have the Hellcat, but I have built the P-47 and have the retract plans somewhere. I'll see if I can find them. It has been awhile.
My method differs a little from the previous post. I like to spread the load over a greater area by adding a hardwood sq stock to the mounting blocks running parallel to the cord to the leading edge, and a couple inches aft of the gear. This spreads the torque force out, in the event of a hard strike to the mains. This is cut into the foam and flush with the surface, then sheeted over. Very strong.
Old 03-25-2011, 03:37 PM
All Day Dan
Gary, That sounds interesting. Please post some images if you have them. Dan.
Old 03-25-2011, 04:11 PM
ram3500-RCU
My Feedback: (221)
ORIGINAL: DAN REISS
Yea, that is the problem, I didn't document that build like I do now. It was many years ago. I'll see what I can find from more recent work.
Old 03-25-2011, 04:20 PM
Dash7ATP
Dash7ATP's Avatar
Hi guys,
Both posts regarding the retract installiation in foam core wings will no doubt work. I have to agree with Gary in the need to spread out the loads to abosrb the torque to the rear in a hard landing. I'm  sure the box installiation will work just fine on most normal landings, but it appears to me that the loads of a hard landing will be mostly shear between the vertical walls of the box and the foam and against the top skin.
Last year I finished my Yellow Aircraft P-47.  I was concerned about the load distribution in the foam core and did a major modification of the gear mounting pads to increase the affected area as much as I could. You can see this in my build at the following site.  Comments welcome.
Dash
http://www.rcuniverse.com/forum/m_8836329/tm.htm
Old 03-25-2011, 04:26 PM
ram3500-RCU
My Feedback: (221)
Yes, another method I have used is to use ply to make ribs fore and aft of the 'box', and epoxy these into slots in the foam, and to the 'box', prior to sheeting. This gives the box no where to go, and virtually makes it impossible to twist it out of the wing. The foam, by itself, just can't give enough support to prevent this from happening, if the unspeakable occurs.
Old 03-25-2011, 05:01 PM
fockewulf37
My Feedback: (102)
Here are my videos showing one way to do it....
http://www.youtube.com/watch?v=H66GwhIL5P4
http://www.youtube.com/watch?v=JEfBNuGatHQ
Ty
Old 03-25-2011, 05:09 PM
All Day Dan
Dash, Thanks for that thread. It will help me during my next build. I have switched from epoxy thickened with micro balloons to secure my plywood box to Gorilla glue since I was never able to get a good fit. It bonds great to the plywood and foam and does not need to be any stronger than the foam since the whole wing is foam. My method has survived some very bad landings with no damage. During the really terrible landings, the half inch Robart strut will bend and the box stays intact. During the controlled crashes, the strut bends, the gear gets distorted and the box breaks with damage to the top wing skin, etc.. It is not too much work to cut out the damaged box and replace it with a new one using a lot of Gorilla glue. And of course, the repair to the wing. But, I would survive better if the force was spread some more over the bottom of the foam. I like your method and may use a plate similar to yours that is secured to my type of plywood box. Dan.
Old 03-25-2011, 05:13 PM
ram3500-RCU
My Feedback: (221)
These are great videos. All I would do different is to make the ends of the box oversize in length to spread that torque load over more of the foam area. Here again, this only takes a slice in the foam the thickness of the ply, and epoxy. It would also be the contour of the foam top and bottom.
A good whack could twist out what you see, IMO.
All Day Dan
Great videos, Ty. The ideas keep flowing in. Dan.
Old 03-25-2011, 05:18 PM
fockewulf37
My Feedback: (102)
Thanks Guys,
I did not show it but I usually cut the ribs back further into the wing to carry the load over a bigger area. But i have not ever torn the gear out even as small as this area is. you would really have to slam it down to break it out...
Ty
Old 03-25-2011, 08:35 PM
91zulu
Yes Chistech watch TYs videos, that man can build his ***** off. He has some very good stuff on youtube. You cant go wrong with his method especially with using glass cloth beneath the wing skins.
Old 03-25-2011, 08:50 PM
ram3500-RCU
My Feedback: (221)
ORIGINAL: fockewulf37
Thanks Guys,
Ty
You haven't seen some of my landings I guess.
Old 03-25-2011, 11:06 PM
BadSplice
BadSplice's Avatar
I am working on a Jemco P-47, and I have been scratching my head about the retract install. This will be my first foam core wing. The p-47 gear retracts inward, but also somewhat aft. When extended, the legs lean down and Forward... How does one go about figuring out what angle to install the mounts in the foam so that the gear will operate in the right way, and the wheel will end up straight when extended, and flush with the wing when retracted?
Old 03-26-2011, 04:38 AM
ram3500-RCU
My Feedback: (221)
ORIGINAL: BadSplice
There was an option set of drawings for the kit, (the retract sheet) which showed those very details. I'm looking for the drawing I have. It has been a long time ago, but I never throw plans away. Also, I can take some pictures and measurements on my plane, that would surely help. Give me a couple days. Others may be quicker. We'll see. These were popular kits in the day. Very detailed and nice to build.
Old 03-26-2011, 05:05 AM
invertmast
My Feedback: (23)
invertmast's Avatar
Instead of boring you guys with words, i'll just do pictures and yall can ask questions if necessary afterwards
Old 03-26-2011, 05:08 AM
ram3500-RCU
My Feedback: (221)
You da man!!!! Perfect.
Old 03-26-2011, 06:55 AM
All Day Dan
Excellent! Dan.
Old 03-26-2011, 10:35 AM
invertmast
My Feedback: (23)
invertmast's Avatar
Now for the boring words, since i have some time to write them
All of the ribs and gear plate are 1/4" 5-ply aircraft plywood. They are laminated w/ 1 layer of 3k carbon cloth on each side w/ each layer of cloth oriented 45* to the other. The ribs are notched to fit into the semi-spar, and the gear-plate slides into place in the slots in the false ribs.
The Gear plate has an additional piece of 1/4" thick x 1/2" wide aircraft ply doubler in the area of the landing gear bolts.
the Plywood "semi-spar" that runs the parallel to the span of the wing is 1/8" 5-ply aircraft ply w/ lightening holes cut into it and rests roughly 1/8" below the surface on the top and bottom.
I replaced as much of the foam core that was removed back into the wing before it was sheeted. I used Hysol to glue the wood parts to each other, and Gorilla Poly-U glue to glue the wood parts to the foam. the Wing also had the leading edge installed BEFORE sheeting the wing. the reason for this, is I designed the gear structure to use the leading edge as part of it. So in order for the forward mount to transfer stress to the leading edge and the LE to transfer stress to the rest of the wing, the sheeting was placed over the leading edge, so the LE is sandwiched by the wing skins and the skins transfer the load to the rest of the wing from the LE.
The only thing i would do different, is make the gear plate approximately 1" longer in span that what is shown in the photo's and move the outboard false rib out with it as well.
Old 03-26-2011, 10:50 AM
chistech
Man, you guys are the bomb! I'm glad I asked. I kind of thought that would be the way to install but I wanted to listen to others tried and tested techniques. I will be starting after I get done with an older Nick Z designed 50 sized P-47 all balsa job. I'm hoping to get three planes all built so my buddy can paint all at the same time. Thanks for the info and keep it coming. Got to love these forums.
Ted
Old 03-26-2011, 02:52 PM
ram3500-RCU
My Feedback: (221)
ORIGINAL: invertmast
All of the ribs and gear plate are 1/4'' 5-ply aircraft plywood. They are laminated w/ 1 layer of 3k carbon cloth on each side w/ each layer of cloth oriented 45* to the other. The ribs are notched to fit into the semi-spar, and the gear-plate slides into place in the slots in the false ribs.
The Gear plate has an additional piece of 1/4'' thick x 1/2'' wide aircraft ply doubler in the area of the landing gear bolts.
the Plywood ''semi-spar'' that runs the parallel to the span of the wing is 1/8'' 5-ply aircraft ply w/ lightening holes cut into it and rests roughly 1/8'' below the surface on the top and bottom.
The only thing i would do different, is make the gear plate approximately 1'' longer in span that what is shown in the photo's and move the outboard false rib out with it as well.
Nice description pal. Don't see anyone having problems after all this. The only tricky part is getting the angle and cant correct. Some trial and error is sometimes needed for this, if you don't have detailed plans.
Old 03-26-2011, 03:13 PM
invertmast
My Feedback: (23)
invertmast's Avatar
ORIGINAL: ram3500-RCU
You aren't lying with that one my friend! Especially when it comes to a FW-190, or any of those other odd landing gear jobbies (spitfire, ME109, etc). Luckily the plans for my short-kit had the dimensions for where the rail should be from the wing skin, and how far from the trailing edge the axle should be. Unfortunately, most plans that i have seen do not do such a nice job of making the builders life easy.
Old 03-26-2011, 03:23 PM
ram3500-RCU
My Feedback: (221)
For sure on the plans. The Jemco was pretty good, but even our P-47 Meister plans left a lot for the builder to figure out, and they are what I would call above average otherwise.
Old 03-26-2011, 08:19 PM
BadSplice
BadSplice's Avatar
Thanks for the info, and the great pictures! I think I have a pretty good handle on how to go about it.
