ESM FW D-9
Old 06-15-2014, 05:00 AM
  #2701
hellcat56
My Feedback: (21)
hellcat56's Avatar
this is Rustoleum flat white
all colors are Rustoleum
never tried to do camo spray cans
Name:	small white 1.jpg
Old 06-15-2014, 06:12 AM
  #2702
vertical grimmace
vertical grimmace's Avatar
Originally Posted by 70 ragtop
Thanks guys
I'm OK spraying it, I just don't have colors to have HD, or Lowes match. Do you have them match a picture, or spray samples and have them match that? I sprayed samples, what did you uses for the samples. Seems to be a lot a variations in shades within a RLM#. Outright different colors on a bunch
Or go to the hobby store and buy the RLM color you want from a Model masters bottle. Paint your own chip, then take that in. Getting the paint to match is actually really easy. Then you can get the sample bottle of latex mixed for like $3
Old 06-15-2014, 02:02 PM
  #2703
Warbird AL
My Feedback: (10)
http://www.hobbylinc.com/htm/tam/tam86505.htm http://www.hobbylinc.com/cgi-bin/s8....t_s=RHG&mfg_s= I have used these on my 109's and my 190. They are pretty close and are flat
Old 06-15-2014, 02:18 PM
  #2704
Dowmer
Dowmer's Avatar
Warbird,
Those are great paints but at 3oz per can you would be buying a lot of them for a 50cc bird. They do have accurate colors though. Personally, I like the convenience of being able to go down to he HW store at anytime to get whatever color I like for 3$.
Old 06-15-2014, 04:30 PM
  #2705
70 ragtop
My Feedback: (24)
Thanks Guys
Warbird Al, have you used those colors?
Jason
That is an EXPENSIVE book! What is the Mongram book you are referring to? As far as spraying, I have everything to spray, restored/painted sereral cars, but my sons crap has completely taken over my shop since we moved, so I guess I'm just being a little lazy.
Honestly, I have never sprayed latex paint. Only time I did was house paint with a Wagner power painter, with a huge tip, and it was most certainly not a flat, as is smooth, finish. Do you have to use a bigger nozzle in your gun for latex, or just thin it way down? Does it layout flat, or does it have a lot of texture? Seems to be the way things are going, so I guess I need to give it a shot
Ran across this thread where he used the Kylon camo colors, which is what brought me back to rattle cans for this plane. I think it looks pretty darn good. I read it as he emptied the cans into another container, tweaked the colors and sprayed with airbrush. My airbrush is too fine to do a big plane like this, maybe a combo of airbrush and touch up gun, or may be able to backtape the camo patterns and spray it right from the cans??
http://www.rcgroups.com/forums/showthread.php?t=1908599
Old 06-15-2014, 05:07 PM
  #2706
vertical grimmace
Thanks Guys
Jason
Latex sprays wonderfully, through a touch up gun or an airbrush. Thin it down to milk consistency with windshield washer fluid. Yes, the blue stuff. Add some Floetrol to it that you get at HD also. This helps it to lay out really smooth. This is the way to go. Cheap, user friendly. It is the only way I finish my warbirds now. This FW 190 D was finished just this way.
Old 06-15-2014, 05:18 PM
  #2707
Dowmer
Dowmer's Avatar
Ragtop,
the books are expensive and seem to be going up. The Monogram book is out of print. Merrick book Vol I is out of print too. Everything seems to be crazy expensive. If you can get a used copy it would be the most affordable. VGs idea would be the best. Use Modelmaster or Tamiya paint to make your paint chip samples then take it in to the the HW store and have your colors matched.
I use a touch-up gun. Thin the paint with water, or some use alcohol, flotrol, or windex to make it smooth and flow out.
Roy Vaillencourt has a great article written about latex usage.
http://www.vaillyaviation.com/docume...tspart1web.doc
VG, nice FW......
heres a pic of my FW D9 using Valspar latex color matched. BTW, use exterior paint since it is more UV tolerant.
Old 06-15-2014, 06:24 PM
  #2708
thunder21
thunder21's Avatar
A picture of the label on the HD mixed samples would help us guys who don't have the color chips.
Here is the sample I got from HD of the original green paint on the ESM D9. It's a perfect match.
Old 06-15-2014, 09:13 PM
  #2709
70 ragtop
My Feedback: (24)
Good info guys...thanks
Your planes look great!
Old 06-17-2014, 04:16 AM
  #2710
Warbird AL
My Feedback: (10)
Yeah, they are pretty expensive when you need several cans for a larger airplane. I am not talented much in the mix n spray area so I use the rattle cans. These paints work well and look good. On my ESM 190 D9 I had to do some repairs and they are real close to the original colors. The dark green for some reason came out somewhat shiny, I havent hit it yet with flat clear. The light blue and grays are awesome. I used the blue on the CMP 109 and it looks great.
If your plane is a gasser you don't need to fuel proof the paint.
Dowmer, I love those colors on your 109. Nice work
Vertical , that is a nice paint job too. What shade of blue is that on the markings?
Old 06-23-2014, 03:48 PM
  #2711
vertical grimmace
Thanks. The blue was just a bottle of latex I found at the local craft store, that looked like it matched my picture. I was not taking it really serious, just tried to get it close. The craft stores are great for small amounts of latex. You can mix and match them to get what you want before you make a chip and take it to Home depot.
Old 06-26-2014, 04:44 PM
  #2712
vertical grimmace
Some pics from a warbird meet this past weekend. The FW 190 sure is a sweet plane in the air. Lost a magnet on my hatch, and it popped open mid flight!
ID:	2009057   Click image for larger version
ID:	2009058   Click image for larger version
Old 06-27-2014, 07:51 AM
  #2713
Warbird AL
My Feedback: (10)
Nice!
Old 06-27-2014, 08:43 AM
  #2714
corsair183
VG,
Thanks for posting the pics of your great looking Focke Wulf 190 D9...BTW what spinner are you using?
Old 06-28-2014, 06:51 AM
  #2715
70 ragtop
My Feedback: (24)
Dgiatr
Curious about your experiences with Fiala props? I placed an order for a couple 3 blade props about a month ago, and have hear nothing back from them
Understand the 3 blade props are manufactured as order, and I'm OK with waiting, if I know they are being made. Three emails over the past few weeks all unanswered, and never got a PP invoice
Wondering if you order directly from them? How long did it take, and did you receive a pay pal invoice from them and pay that, or did you just send them money? I'm a little hesitant to send funds if they won't confirm the order, or answer emails
BTW, how's the painting process coming along?
Old 06-28-2014, 09:07 AM
  #2716
dgiatr
dgiatr's Avatar
Dgiatr
i ordered directly from them once. i payed after receiving a paypal money request. and as far as i remember i didnt have any serious delays, all the other times i got fiala props from my local rc model store.
i didnt start painting my esm fw 190 d9 yet cause i am doing a little practice with my cmpro bf 109 repainting with my new airbrush . i have never used an airbrush before so i prefer to do a little practice in another plane for the first time. i havent finished my bf 109 yet, it still needs exhaust painting and some weathering........
ID:	2009539   Click image for larger version
ID:	2009540   Click image for larger version
Old 06-28-2014, 11:31 AM
  #2717
70 ragtop
My Feedback: (24)
OK, thanks
Curious if your local hobby shop stocks three blade props? I'm looking for 19x16s for a P-38, and a 24x16 for the Dora
109 is looking good!
Old 06-29-2014, 07:13 AM
  #2718
vertical grimmace
Originally Posted by corsair183
VG,
It has the Skyshark spinner. This is a smaller D9 than the ESM. I need to re paint the spiralschnauze. It got scuffed up, so I painted over it.
Old 07-02-2014, 09:22 AM
  #2719
dgiatr
dgiatr's Avatar
OK, thanks
70 ragtop, i asked my local hobby shop for the props you need but he doesn't seem to have them. sorry.
what about fialla props, any news;
Old 07-02-2014, 10:53 AM
  #2720
70 ragtop
My Feedback: (24)
No, not a peep. I called, but no one there spoke English, and I cant find anyone around here who speaks Czech. Next time your at the hobby shop, would you mind asking about 18x14x3 props?
I really like the higher pitch options they offer, thinking they would be a good fit on an electric.
Old 07-03-2014, 01:10 AM
  #2721
LDM
My Feedback: (15)
Try Esprit Models, there online store sells giant 3 blade props
Old 07-08-2014, 09:34 PM
  #2722
dgiatr
dgiatr's Avatar
Mission accomplished!!
i am quite satisfied with the result after my first contact with an airbrush.
My CMPRO BF 109 F repainting has finished! (although there are still some details to take care of -change place of the pilot, kill marks on the rudder, nose-guns) but i will not spend time with that model anymore.....Now its time to put some color on my fw 190 d9!
https://www.youtube.com/watch?v=eLWJXhD73ew
Old 07-09-2014, 09:44 AM
  #2723
dgiatr
dgiatr's Avatar
photos......
ID:	2012859   Click image for larger version
ID:	2012860   Click image for larger version
ID:	2012861   Click image for larger version
ID:	2012862   Click image for larger version
Old 07-09-2014, 01:58 PM
  #2724
Dowmer
Dowmer's Avatar
Dgiatr,
real nice paint job! I think you will do a great job on the D9. Too bad you have the muffler hanging out the left side of the 109. She still looks nice though.
Old 07-09-2014, 07:15 PM
  #2725
70 ragtop
My Feedback: (24)
Looks good dgiatr!
You all know what I'm going to ask....wait for it.......wait for it..............
Dgiatr, what kind of paint did you use?
No I haven't tried the Latex yet, BUT, as the weather was the pits over the holiday weekend, I got quite a bit done on the Dora. The motor is mounted, tail feathers and tail wheel done, fuse servos in, and tail rigged. Finishing up the "homemade" main gear prior to fitting the wing to fuse. As the summer months are upon us, and time is short, just going to focus on putting it together and putting some flights on it as is. So many cool paint schemes to choose from, I what to enjoy painting it, and not feel rushed
Keep posting those pix, keeps the rest of us ( at least me) motivated to get this one done!
