ESM FW D-9
#1351
RE: ESM FW D-9
ORIGINAL: STICK MODE
Dave dident you pack out the 52 off the firewall due to the short standoffs ?
dave
#1352
RE: ESM FW D-9
ORIGINAL: n8622t
It looks to me like a Slimline muffler which I think has the best sound for the 50cc range...I have the Jtec equivalent and they dont have the deep sound of the Slimline.
You are right, it is a Slimline muffler, not a JTEC. I use a JTEC (larger) on my TF GS P-47. In that case, I need to trim a little bit off the engine box.
As for the Dora, I willshorten the exhaust pipes a little. Will post a few pictures with the fuselage upright and cowling in place in a couple of days. It looks as though the appearance will be quiteOK. I have not tried the Slimline muffler ona 50cc before, so I am currious about the sound.
#1354
My Feedback: (8)
RE: ESM FW D-9
Not a thing wrong with that P47 I am going with a similar set up since yours looks so good. DA50 and a slimline. How is the firewall since you cut out the bottom section? You gonna need to reinforce in any way? What about the open fuse section...idea...take some thin balsa and wet one side so it will curve along the grain for you, then lay it in the opening from the firewall to the front of the fuse. Work it in and glue it. Piece the ends in then come back and trim it off...thin epoxy and paint it. It will help channel the heat away from the muffler and engine and keep hot air out of the fuse. Hope this helps since you already worked out how my engine is going on
#1355
RE: ESM FW D-9
ORIGINAL: n8622t
Thanks for the suggestion for closing the gap. I am stillthinking about various alternatives for how to do it.
#1356
My Feedback: (82)
RE: ESM FW D-9
ORIGINAL: n8622t
Hey Alex I want the set that is ready to install....you have any coming?
ORIGINAL: iflytailies
1/5 scale Fw-190 instrument panel kit #3022 and side panel kit #3022/1-5
#1357
RE: ESM FW D-9
Friends,
My EP 50cc Dora project is just finishing up.
Has anyone considered the heavy fixed toe-in which occurs when the Sierra mains are installed? Should still handle OK but more than I would build in. Could not see any way to adjust the axles on the legs.
Regards,
Doug Andre
Regards,
Doug Andre
#1358
RE: ESM FW D-9
Doug better toe in than toe out it can be ajusted but its a magor as i have my self changed that aspect and would advise any one not to go there what i found is that they are so well built its a like a rubicks cube just finding out how they are assembled is hard
#1360
RE: ESM FW D-9
Mine has very very little toe in.
When I was opening up the factory retract rails I was paying very close attention to the angles, one of the those being toe in. This does mean that my retracts do not sit parrallel to the original cutouts. Just trying to get the sierra mains into the wheels well's will drive you to adjust these angles as it is.
She tracks very nicely on the ground.
dave
dave
#1361
RE: ESM FW D-9
Thanks to all.
I will leave them alone. I went to great lengths to cut the mount plates and position the legs and wheels in the best possible position.
The quality of the Sierra gear is fantastic and is worth the extra effort.
Regards,
Doug Andre
Regards,
Doug Andre
#1364
My Feedback: (43)
RE: ESM FW D-9
ORIGINAL: mike day
i am looking to find who selling the sisT190 d9 in the united states if any body knows ill aprechate the info. ?
http://www.vogelsang-aeroscale.com/warbirds.html
#1369
RE: ESM FW D-9
ORIGINAL: Ramstein44
Plan B!!
Sierras temporaryly installed. I placed at the bottom of the retract three 3/8th pieces of maple and two pieces in front to get the proper or close to distances. I like this better for all the reason I mentioned prior, I can place a larger wheel and I can get another retract unit for $109.
I'll keep the other ESM gear, repair it and use it as a fixed gear for the second D9 if that time ever comes.
Plan B!!
I am working on installing the Sierra tail retracts now. You wouldn't happen to have a picture or two of the actual mounting of the tailwheels showing the maple pieces glued into place?
Cheers
#1373
RE: ESM FW D-9
Friends,
Does anyone know of a source for Luftwaffe aircraft stenciling or decals such as fuel type, no step warnings, lift here and tire pressures?
I take them for granted on my small scale plastic models. I would love to discover a dry-transfer set for 1/5 th scale.
Regards,
Doug
Regards,
Doug
