CARF F4U-1 Corsair build thread
Reply
Old 10-06-2017, 05:28 AM
  #3601
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Painted on. They aided in runway line up as the vision over the nose was not very good.
ram3500-RCU is offline
Old 10-07-2017, 05:07 PM
  #3602
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Best way to clean the mold release and prepare the surface for paint?
LtMash1A is offline
Old 10-07-2017, 08:47 PM
  #3603
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use denatured alcohol, and then Prep Sol from the local auto body supply house.
Old 10-08-2017, 05:18 PM
  #3604
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Gary. Did you abrade the surface with anything like a Scotch Brite Pad?
LtMash1A is offline
Old 10-09-2017, 04:38 PM
  #3605
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes. I use 400 grit.
Old 10-10-2017, 06:59 PM
  #3606
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
enjoy.
Old 10-11-2017, 09:43 AM
  #3607
GeorgiaFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by ram3500-RCU View Post
where did you get the lights from? Link?
GeorgiaFlyer is offline
Old 10-11-2017, 12:55 PM
  #3608
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The lights are our own design. We sell them as a complete kit for the CARF Corsair. Here are a couple pictures of what is included. Each color of LED has a different voltage. Each of our lights is regulated at the bulb for the the correct voltage to protect from an overvolt. The formation lights are built with special lenses of the correct color, in addition to the colored bulbs. We are not taking any orders until we get caught up with all existing orders. Another 2 or 3 weeks should clear out all outstanding orders for any of our offerings.
Old 10-11-2017, 12:59 PM
  #3609
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pictures
ID:	2240913   Click image for larger version
ID:	2240914   Click image for larger version
Old 10-11-2017, 01:03 PM
  #3610
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more pictures
ID:	2240919   Click image for larger version
ID:	2240920   Click image for larger version
Old 10-22-2017, 06:04 PM
  #3611
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by txcnguy View Post
So I see from this thread that a significant amount of nose weight is required. I did my CG yesterday at our clubhouse and found that without weight, or the canopy installed yet, I am already nose heavy. To qualify this, in my build I moved all the batts to the front as much as possible. My thinking here was if I need weight I might as well have it as useful weight. I'm using a Powerbox Mercury with two 5800 mah hard plastic case lipos. In addition a 5000 mah batt for the gear, and another 3500 mah for the ignition and pump. So in total 4 batts moved far to the front.
I used a Xicoy CG meter for this. Measurements shown in pic.
I used CG as 10mm in front of main spar as per CARF manual.
The weight addition point for the CG meter was taken as the front lip of the cowl if I needed to add weight there.
Total weight as shown was 22kg. 48.4 lbs.
Any comments on this, I just want to know on the models that needed a lot of nose weight where were the batteries located and what size were they?
I found that using the XiCoy System that I did not need to add any nose weight as well. Mine came in at 50.6 pounds. I used four Power Box Batteries, all mounted right behind the firewall. The XiCoy tells you to make sure the plane is level. I have gotten a lot of different opinions on just what level is. I used a lazer to draw a line down the fuse perpendicular to the firewall. My reasoning is that on the 3- view the datum line level shows a definite downward slope to the nose. Someone suggested that
level is 0 incidence on the wings. To me this throws the tail way up in the air. Anyway, I was wondering if you have flown yours yet and if you found the XiCoy to be accurate. Also what did you do to determine level.
LtMash1A is offline
Old 10-22-2017, 06:29 PM
  #3612
txcnguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi.
After I used the Xicoy, on this thread someone suggested I should do CG with wheels up as this is normal flying. So I couldn't use the Xicoy with wheels up. What I did was similar to you. I marked the CG location with 1/4 in masking tape on the wings near the gear. I took two jack stands and strapped two dowels with some foam and positioned them at the tape marks. Then I took a laser level and set it up from center of nose prop hub to center of tail extension. You know that round extension at the far most rear. At this level it took about 3 lbs in the cowl ring to get CG right. Since I wasn't able to find steel powder, I used round fishing lead weights inside the cowl ring with epoxy resin. Lead is 30% more dense than steel btw. I haven't done the maiden yet but from experience it looks like to me the CG is about right.
So try it again with wheels up.
Dan
txcnguy is offline
Old 10-22-2017, 06:37 PM
  #3613
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let's make this easy. The CG should be 6 1/2 to 6 5/8 aft of the front of the wing saddle. Set your CG there and see what you get. Confusion persists when setting it in relation to the spar. As most know, we have built many of these, and all required at least 4lbs of additional weight forward of the CG, regardless of component location.
Level. Level is when the plane will hold a position or attitude without tipping down fore or aft. I don't worry about the datem line. In reality, fuel quantity, gear possition, trim positions, even sliding the canopy open will shift the virtual CG. Our balance point works in real life. It is proven. The worst thing you can do is leave the ground tail heavy. Please be careful where you establish your CG point. With two servos in the tail, a scale cockpit, paint, and not even going overboard with scale detail aft of the cockpit, with all radio and fuel system as far forward as possible, a Moki and scale Solo prop, with wood blades, and the gear UP, you WILL require around 4lbs of additional weight. If you use the CF prop blades (not recommended), it will take less ballast. Really.
Old 10-22-2017, 07:04 PM
  #3614
txcnguy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gary.
As I mentioned before to you, I used two really heavy 6000 mah sealed Lipos far forward as useful weight, a 5000 mah Lipo for Gear, and a 3500 mah for ignition. All far forward. So my extra batt weight offsets the one pound less at the nose ring. My CG mark was at the mark 6 1/2 to 6 5/8 aft of the wing saddle btw. Total all in weight about 50 lbs. But for maiden I will bolt on another pound to be sure.
txcnguy is offline
Old 10-22-2017, 07:09 PM
  #3615
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
​​​​​​The CG should be 6 1/2 to 6 5/8 aft of the front of the wing saddle
​​​​​​"The CG should be 6 1/2 to 6 5/8 aft of the front of the wing saddle" . Gary, That puts the CG at the recommended location according to the manual. I thought you said in an earlier post that that Dino recommended that it be moved aft. At one time you quoted 3/4 inch in front of the gear door opening on the bottom. So, now are back to factory? Thanks, Dave
LtMash1A is offline
Old 10-22-2017, 07:16 PM
  #3616
ram3500-RCU
My Feedback: (221)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gary.
Understood. My comment was more directed at the guys who balance with the gear down, then misslocate the CG point, and swear that no additional nose weight is needed. Extra heavy Batts, and no cockpit detail, will make a difference.
Thank you for all your posts. This is important stuff.
Old 10-26-2017, 01:19 PM
  #3617
Greg Wright
Greg Wright's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been told that hot soapy water is the only thing that will really remove the mold release agent from the parts.
It is kind of impervious to any of the harsher chemicals like (wax/grease remover and paint reducers) as it withstands the spraying of the gel coats and paints used in the molds.
If you don't get all of the release agent off before you either sand or use scuff pads on the surface. All you will do is push it deeper into the surface creating more problems for the paint to adhere.
Greg Wright is offline
Old 10-26-2017, 03:24 PM
  #3618
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Greg
LtMash1A is offline
Old 10-27-2017, 03:37 AM
  #3619
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Greg
Old 10-29-2017, 09:55 AM
  #3620
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After painting and pulling the paint mask, they leave a sticky residue. Anyone else have this problem and know what to use to remove it?
LtMash1A is offline
Old 10-29-2017, 03:46 PM
  #3621
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WD 40 will remove the sticky stuff. So will Label removers etc.
BobH is offline
Old 10-30-2017, 04:00 AM
  #3622
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These will remove the paint also!!
Old 10-30-2017, 04:08 AM
  #3623
Greg Wright
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never had this issue with the adhesives on the paint masks.
It sounds as if the adhesive on the material, isn't capable of standing up to the reducers/thinners in the paint.
Again i would try the hot soapy water trick as any chemical might remove the paint from the surface and you don't want that to happen.
Old 10-30-2017, 05:42 AM
  #3624
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Remove the paint? Not in my experience. Yours must be different.
BobH is offline
Old 10-30-2017, 04:10 PM
  #3625
LtMash1A
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what I ended up doing. WIPEOUT, by High Teck Ind. It's a solvent used to wipe off finger prints and oils off primer before painting cars. I'm sure there are a lot of different brands of the same thing. I got it from the automotive paint store. I had some around because I use it for painting the plane right before the first coat of paint or primer.Thanks for the help.
LtMash1A is offline
Contact Us Archive Advertising Cookie Policy
