CARF F4U-1 Corsair build thread
#551
My Feedback: (221)
RE: CARF F4U-1 Corsair build thread
Here is the how the wings look when against the stops Mitch adds at Down And Locked. They are at a very good looking angle, and very even.
Now, they do not pinch the hinge door in the center, or the front hinge area, as you can see. They now have a hard stop to go to.
#557
My Feedback: (221)
PLEASE HELP. I had to share the last of my Micro Balloons with Brian. I used to buy a 12oz bottle at the local hobby shop for less than $3. Apparently, Prather is no longer selling these. Any of you out there have a good source for Micro Balloons? Looks like another building supply I will need to turn to the internet for. This sucks.
#559
Gary, Found it...........
http://www.rcscalebuilder.com/forum/...6&PN=1&TPN=138
Here is where he gets it,
http://www.fiberglasssupply.com/Prod...s/fillers.html
Merlyns starship page 138
Here is what merlyn suggests,
The mix ratio is about 3-4 to 1 by volume. You need to mix enough balloons so that a glob will not fall off of your mixing stick, but you still want the mixture to have a glossy look when throughly mixed.
#563
My Feedback: (43)
I bought from http://www.aeromarineproducts.com/ the last time i needed micro ballons and milled fiber. $16.00 for a half gallon bucket seemed reasonable.
#564
My Feedback: (221)
Thank you guys.
I could not believe the price jump at the LHS. Last time I bought it, it was $2.89 for 12oz, and now they want $5.00 for 4oz!!!!! Ridiculous.
I did find some at Tower Hobbies last night and ordered it because it was so much less than the LHS. But these sources you guys have are much better still.
Wayne, this is a great resource. http://www.fiberglasssupply.com/Prod...s/fillers.html
They have all kinds of additives including Milled Fibers, for making strong fillets on glue joints.
I saw some interesting material from West Systems as well, that I'm going to try.
Thanks again for all the posts guys.
#566
My Feedback: (221)
It looks like some of the challenges for the Prince family in 2012 are already taking form. This little guy is back in the hospital having a bone biopsy, an MRI, and getting the cast back on. His little leg is broken again, and now there is real concern. Mom and Dad spent last night at the hospital with him. He was on a Morphine drip. []
#570
My Feedback: (158)
ORIGINAL: ram3500-RCU
Thank you guys.
Thank you guys.
I'ved used West Systems 410 filler for years,, IMO it's the lightest and most sandable filler on the market, not very expensive either
http://www.westsystem.com/ss/410-microlight/ some example of me using it in this thread http://www.rcuniverse.com/forum/m_10852874/tm.htm
Should be on the shelf at any Marine products store, like West Marine,
I get home on the 4th, I can send you some to try if you can wait that long
good luck
#571
My Feedback: (221)
ORIGINAL: scale only 4 me
Gary,
good luck
Thank you guys.
Thank you guys.
good luck
I'll look for the 410 around hear.
Safe journey home my friend.
#573
My Feedback: (221)
Slight delay on that video. Found a small problem, but we came up with a simple fix. With the wings all glued up, and even with the updated hinges on the leading edge, the top skin hits then. To the extent that a notch is necessary. We decided to simply add a piece to the fixed side, to mirror the notch on the outer panel. When down, it will not be noticeable, and no complicated movable cover will be needed. You have plenty of material to do this from pieces you have already cut out. Never throw this stuff out till you are done building.
We'll have that video in a day or so.
I picked up the blue nav light Brian made up for atop the aft fuselage. Need to get that installed before the cockpit goes in. The one in the tail is easy to get to from the tail doors, and can go in later.
Here are some pictures of the top and rear nav lights, and the boost tab I referred to in an earlier post.
#574
My Feedback: (221)
#575
NC
Gary I will send up a prayer also I sure hope he gets better cause you aren't getting any younger and we are gonna need the next generation of fliers pretty soon. Be sure when you read bed time stories to him that you mention Down and Locked in subliminal ways so as to ensure that when he is older he becomes as good a customer and friend as you and Brian. lol Mitch
