CARF F4U-1 Corsair build thread
#876
My Feedback: (221)
RE: CARF F4U-1 Corsair build thread
Gave some attention to some surface detail. Although CARF molds many details into the glass, they need work. The panel line are very close, but some of the hatches are missing, and of the ones that are there, most are the wrong size and shape. They all have the wrong fastener pattern as well. This is true of every inspection disk as well. They all have 4 instead of 3 screws.
I'm sanding all the disks to remove the molded fasteners so I can change them. The hatches will all be fixed as well. The ones that are missing are easy to add. I'm going to use Meister micro piano hinges to simulate the full scale ones. I'll cut a slot and slip them in, but most will not operate.
I made patterns for the hatches I'll cut from aluminum. The lines show how far off the factory CARF mold is.
#882
My Feedback: (221)
Here is the hatch on the bottom of the wing. Inside will be the air valve for the main gear doors (the only air on the plane), the arming switch form the wing fold, charging jacks, the equalizers for the aileron and flap servos, and a disconnect so that one wing can be shut off for display purposes (one wing up and one down).
#885
CA
Have you all seen the new folding wings for Comp ARF that the guys at Down and Locked did?
http://www.youtube.com/watch?v=Yj2GG...ature=youtu.be
They did this for my freinds plane. He just got it back from them last week. Pretty cool!!
Jeff
Jeff
#886
My Feedback: (221)
ORIGINAL: jmohn
Jeff
Jeff
I'm sure many conversions for Down & Locked will follow, and we could not be happier for Mitch and has team. I believe this mod will eventually become factory standard. I see no reason for it not to be at some point.
The discussion between Brian, myself, and our team owner the other evening, at plant 1, was whether we feel confident enough to fly the Corsair with just the electric system holding the lock in place. We would never have flown #1 with the factory hydraulic system alone. As most of you know, we employed a mechanical locking bolt on that system when flying. We installed the same system on this plane, even with the electric mod. We feel that it would be virtually impossible for the electric wings to come unlocked in flight. However, bumping the switch would cause instant unlock, bending of the jack screw, folded wings, and likely a total loss of the airframe. Ultimately, the decision whether to unfold and go or not will be with the owner. We have the ability to lock them for flight. If the switch would be accidentally flipped with the locks in place, the control box will instantaneously 'see' the load and shut down the motors right away, with no damage.
#888
My Feedback: (221)
ORIGINAL: jmohn
Yeap, it works great and is much more reliable than the standard setup.
Great job!
Jeff
Great job!
Jeff
http://www.youtube.com/watch?v=vOnX7Xbit4A
#889
My Feedback: (221)
I'd like to share these micro hinges from Meister. They are dead ringers for the ones used on many full scale aircraft, and just the right size for this scale.
I slotted the fuselage and inserted them in the closed position. They are not operational, but could very well be used that way.
Then I made the hatches from Flight Metal. Flight metal is good for this because it is thicker than most other brands, and makes nice hatches. This is the only thing I use Flight Metal for now. If you don't want to wait the weeks and weeks it can take to get Flight Metal, go to one of the big box stores and get good old HVAC tape. It is also a good thickness. Some brands have their company logo inked on the tape, but the brand 'Surtape' does not. It is clean aluminum foil tape.
I then used a ball cutter in my Dremel to counter sink the #1 screws and installed them in scale locations.
I also covered the tail gear doors with Aerofoil.
#892
My Feedback: (221)
Here are the starboard side hatches.
First, the slots cut for the piano hinges.
Interesting, but one of my most liked resources, Bert Kinzey's 'F4U Corsair in detail and scale' has the hatch for the tail wheel arresting gear oleo (the one in the lower middle) on the wrong side, in the 3-views.
#896
Gary; the work you're doing is OUTSTANDING!!! I'm following it from the first day and I can say that every day's post is really inspiring!!!!
Thaks for sharing!!!
Guille
Guille
#900
My Feedback: (221)
ORIGINAL: wayne d
Post 894
round covers are on the vertical stab
post 895
round covers with screws are on rudder. There also appears to be some sort of round covers on the vertical stab also where the X is painted.
Post 894
post 895
I wish CARF had concentrated on getting the panel lines right, with the proper spot weld and rivet detail (something then did fairly well), and left the hatches and covers off for the builder to add in the correct size, location and shape, depending on the model.
They did a good job on the round covers on the tail with respects size and location. Most of the other hatches and covers are not correct.
