If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 40 of 140 FirstFirst ... 3038394041425090 ... LastLast
Results 976 to 1,000 of 3476
  1. #976
    saramos's Avatar
    Join Date
    Dec 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: CARF F4U-1 Corsair build thread
    If you have problems opening the zip file, let me know and I can burn an uncompressed disk.
    A question of curiosity, are you going to make any of the flap sytems functional for the flap gap doors, oil coolers and intercooler?
  2. #977
    ram3500-RCU's Avatar
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: saramos
    I think we will be OK on the disk, but I'll let you know Scott.
    No plans on the above at this time. Maybe later. However, I think you will be happy with the oil coolers themselves, and the ducting next to them. Something very exciting going on with those. They will look very full scale when done.
    Cheers,
    Gary P. / use Steel Powder for ballast not lead. PM me for more information.
  3. #978
    saramos's Avatar
    Join Date
    Dec 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds interesting. I'm looking foward to seing what you come up with.
  4. #979
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: saramos
    Another new team member and Corsair specialist is working on them. Should be very realistic looking. There will still be room for the gun speakers behind them.
    Cheers,
  5. #980
    Join Date
    Jan 2002
    san diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gary, Is it possible to avoid an air system for the main gear doors?
    Time flies like a brick thru the window of life.
  6. #981
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MANFRED
    Yes MANFRED. We believe it is. I'd like to use electric gear doors on a future one. But on this Corsair, we are out of time, and the air cylinders are more scale looking anyway, and can be mounted in a very full scale looking manor.
    Because we only have (4) small air cylinders for the doors, we are using just two small air tanks. The air system will be a closed one and contained in the wing. We expect a nice tight system.
    Cheers,
  7. #982
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More gear door work. I got the inside rivets done and then did the outside ones in the aluminum.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1729387   Click image for larger version.
ID:	1729388   Click image for larger version.
    Cheers,
  8. #983
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    After a conversation with Mitch, I decided to turn the motor around on the canopy drive, in order to reduce some binding I was having.
    I had a piece of carbon fiber tube just the right size to slide the motor in as a mount. Then I cut a slice of 3/4" aluminum bar stock to make the piece for jack screw to run in.
    Just a crude experiment to see if this solves the binding.
ID:	1729390   Click image for larger version.
    Cheers,
  9. #984
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As work continues on the sliding canopy, I found that the marks molded into the fuselage for the rear rails are not to my liking. They are too low and at the wrong angle. I laid out mine disregarding the factory lines. I also found that the panel lines that the factory marks keyed off of are not quite the same on both sides.
    With my marks triple checked, I cut the homemade rails in. I then epoxied the rails in the slots. I am using a flat head machine bolt, with a jam nut tightening it to the canopy. Then a self-locking nut will be screwed onto the inside, which will run in the rail. This will give the scale look on the outside of the canopy. I'll drill a hole behind the rail so these can be inserted, then I'll screw a plate on to cover this. The full scale has this look.
    I was going to use brass for the doubler on the inside of the canopy, but then thought of using some carbon fiber and found that the pieces that you cut the main gear doors are perfect for this. I cut this to shape and was able to drill and tap it with 2-56. Works great.
    When working with composites, we don't throw anything away till we are done building.
ID:	1729887   Click image for larger version.
ID:	1729888   Click image for larger version.
ID:	1729889   Click image for larger version.
ID:	1729890   Click image for larger version.
ID:	1729892   Click image for larger version.
ID:	1729893   Click image for larger version.
    Cheers,
  10. #985
    Join Date
    Jan 2005
    San Diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lookin good Gary,
    Here's a web site you may know about allready www.bentwings.com. It has some oustanding photo documentation of a full scale restoration.
    ____________AIRSPEED IS LIFE_____________
  11. #986
    Join Date
    Nov 2008
    vorselaarantwerpen, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi there, Bruno again. I got the wing fold pices back in the wing and i am verry happy that i let them treated whith the Surlon k surface,the are now scratch free and selflubricating making a verry big diference in moving,the are going verry smooth now.I als put the microswitches on.In picture one the wing is in its down position and the safety hook is closed.The microswith on the safety hook switch on the wing tip nav light as soon the hook is closed.In picture to the wing is in its up position firmly lockt buy the one piece machined hook on the hinge point.The microswitch on top is preventing the safety hook servo to move before the wing is in its full down position.The one one the bottem swithc the wing tip nav light on again when the wing is nearly in its full up position.The system ( small wing doors-safety hook servo-hydraulic valve servo ) will be driven by a projet sequenser.
ID:	1729941   Click image for larger version.
  12. #987
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: pappy 883
    Lookin good Gary,
    Thanks pappy. Yes, I had seen that site. I like seeing pictures of the airframes stripped down. That is very reveling for hatches and fasteners, for example.
    Cheers,
  13. #988
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: henderyckx bruno
    Looks impressive Bruno. Thanks for sharing.
    Cheers,
  14. #989
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BTW, I tape up the inside of the canopy so that, as I grind the bolts down smooth on the inside, the hot metal 'dust' doesn't pit the inside clear plastic. Learned that the hard way once.
    Cheers,
  15. #990
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my March issue of the British magazine Model World today, and was pleasantly surprised to find a nice picture of our BIG HOG #1 in it.
    Of course, thay haven't seen "all out" yet, have they.
ID:	1730110   Click image for larger version.
ID:	1730111   Click image for larger version.
    Cheers,
  16. #991
    saramos's Avatar
    Join Date
    Dec 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Congratulations!
  17. #992
    Join Date
    Jan 2005
    San Diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'll bet that made you very proud. Those Brits take they're scale stuff very seriously.
  18. #993
    Join Date
    Jan 2002
    san diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This may be the answer to the gear door question http://www.lado-tech.net/en/e-doors/...door-20mm.html
  19. #994
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MANFRED
    I have looked at those.
    Actually, D&L is working on liner output devices for gear doors as well. I'll be testing some of those when they come available.
    Cheers,
  20. #995
    saramos's Avatar
    Join Date
    Dec 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  21. #996
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: saramos
    Here's another route:
    http://www.emsjomar.com/SearchResult.aspx?CategoryID=18
    I had not seen those. I wonder if they have them for the higher torque servos as well. Looks like the ones shown are just for the standard power servos.
    Cheers,
  22. #997
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got some pictures of the canopy work to load.
    I had to go back to the drawing board on my first mount for the front. It didn't offer enough articulation as the canopy of the Corsair tilts back slightly as it slides open. The ball link is the way to go, but I was still able to use it without the non-scale looking nuts on the outside of the canopy.
    The idea I had for the rear track worked great, and is nicely adjustable. A scale cover will go over the back of the track eventually, and cover the insertion hole for the anchor bolt.
    Note, if the CARF marks for the rear rail were in the scale location, the canopy would mount perfectly. One needs to make the adjustment, and it all works great with no mounting brackets showing, per full scale.
ID:	1730459   Click image for larger version.
ID:	1730460   Click image for larger version.
ID:	1730461   Click image for larger version.
ID:	1730462   Click image for larger version.
ID:	1730464   Click image for larger version.
    Cheers,
  23. #998
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Note, with the canopy in place, the Down & Locked system works good, as long as it is held in place. I'll address this tonight. I have had it sliding open and closed with no binding.
    Cheers,
  24. #999
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: pappy 883
    Yes, they do like their giant scale over there, the reason I subscribe to that magazine. It had good coverage of those huge planes they build.
    Cheers,
  25. #1000
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The wing work continues with the lighting fabrication and installs, then the gear and doors go back on, with the scale air cylinders being mounted as well.
    Cheers,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
