CARF F4U-1 Corsair build thread
#126
RE: CARF F4U-1 Corsair build thread
Well, I thought the same thing. I was expecting to only need 5 lbs. I see Gary only needed 4.5. I am going to double check it again before I add the lead permanently. I measured it 6.5 inches from the leading edge at the root of the wing closest to the fuselage. That is what I read from a previous post. Please POP UP is I am wrong on the location. I was use my eyeball to check level.
Vern
Vern
#127
ORIGINAL: ram3500-RCU
Looks like you are making real progress Vern.
Here is link to a video that captured my bouncy landing. I know now how to land her. The second landing was perfect.
www.youtube.com/watch?v=qgO2A059mkg The Corsair starts at 3.42 into the video.
Vern
#128
Well it is ALIVE !! The Moki 250 started way easier than I had thought. I had way mor trouble starting DA-100 engine than the Moki. She sounds great.
[link=http://www.youtube.com/watch?v=UPthS0mIsMg]Youtube Moki startup[/link]
for some reason the HD video would upload abut i could not get sound. So I posted a great sounding crappy video.
I did check the CG again. I ran a small rope between the wing and fuse. I got the same results and need to add the 10 lbs of lead. My CG spots are 1/2 inch in front of the spar. I also measure about 6 5/8 inches from the leading edge back.
It is what it is I guess.
Vern
Vern
#129
My Feedback: (221)
ORIGINAL: wayne d
Hey Gary,
I get you another set of blades before Monster Planes. Just wanted to let you know I have not forgot you.
Hey Gary,
Thanks pal.
#130
My Feedback: (221)
ORIGINAL: vfrank59
The video was great to watch. I sure would like to see your HD version when you get the disc from you buddy.
Vern
Vern
I hope that watching my mistake will help you with your maiden. As you can see, simply adding power and aborting the landing would have been the better thing to do.
#131
My Feedback: (221)
ORIGINAL: vfrank59
Vern
Vern
BTW, we have a 50oz tank on board. Way more than we need for a 12-15 min flight.
1st flight we landed with 3/4 of a tank still on board.
2nd flight we still had over 1/2 tank.
Also, all the stand-offs for the engine are different lengths to achieve the thrust angles called for in the manual. These also seem to be very good.
#132
My Feedback: (221)
ORIGINAL: vfrank59
Vern
Vern
#134
My Feedback: (221)
ORIGINAL: wxman2
What diameter of the 3-blade prop are you using with the Moki 250?
I was going to cut the pitch back a bit to get more RPMs because we are only around 3400 on the ground, then I spoke with Götz Vogelsang, and he explained that the engine should tack at no more than 3600 on the ground with this Solo Prop, because of how it unloads in the air. So I left it at 17". I believe the engine can safely be leaned a bit now, so I'm sure we will have the 3600 next time out.
#135
My Feedback: (52)
We have a 32" Solo, set at 17" pitch.
ORIGINAL: wxman2
I was trying to figure out what Solo prop to use with a Scale Wings LA7 with a Moki 250 and this is great information. I will go with 32"...
John
#136
My Feedback: (221)
ORIGINAL: wxman2
Thanks Gary,
I was trying to figure out what Solo prop to use with a Scale Wings LA7 with a Moki 250 and this is great information. I will go with 32''...
John
We have a 32'' Solo, set at 17'' pitch.
I was going to cut the pitch back a bit to get more RPMs because we are only around 3400 on the ground, then I spoke with Götz Vogelsang, and he explained that the engine should tack at no more than 3600 on the ground with this Solo Prop, because of how it unloads in the air. So I left it at 17''. I believe the engine can safely be leaned a bit now, so I'm sure we will have the 3600 next time out.
ORIGINAL: wxman2
John
BTW, I have 2 sets of CARF carbon fiber 32" Solo blades if any one is interested. The guys I talked to recommended the wood ones to save the crank in the case of a prop strike. I really think that is a remote possibility at best now, but I'll stick with the wood ones anyway.
If anyone wants the CF ones, just PM me. They are new and without any graphics.
#137
My Feedback: (221)
BTW guys, here is where Brian is getting all our 'Festo' fittings you will need for the wing (the plugs in different sizes come in exceptionally handy for bleeding the system), air cylinders, and more. Very cool stuff and a great selection.
They ship FAST!!! Great customer service as well.
www.shulmanaviation.com/index.php
Check out the little air gauges. Very accurate and they fit in a giant scale instrument panel. We have one on our accumulator.
#138
Cool video Vern. It is amazing how easy these engines start. You using the pump?
ORIGINAL: vfrank59
Vern
Vern
Yes, i am using the pump. I have the pump ignition connected to a smart-fly optic kill switch. Both go on and off at the same time. I could not believe you can lflip the prop with just 2 fingers. It is great.
#139
I believe I set my solo prop at 18 pitch. I have not tach'ed mine yet, cause I cant find it in all the stuff around here. I feathered it all the way , one direction and the counted the turn to get Max pitch. I then turn it half way back to Center. It lined up on the Zero mark. I then added more pitch. 13 ticks on the dial. Does this seem to be the correct procedure. the instruction were not clear to me.
thanks,
vern
thanks,
vern
#140
My Feedback: (221)
ORIGINAL: vfrank59
thanks,
vern
thanks,
vern
#141
Wayne Fussel (owner of Solo Props) is a friend of mine. He explained that the zeroing tic on the dial is not correct. You need to get them flat, then just count the notches as you rotate the dial. They are correct for each inch of pitch.
ORIGINAL: vfrank59
thanks,
vern
thanks,
vern
Roger that. I will find my Tach and double check everything on the prop.
thx
#142
My Feedback: (221)
ORIGINAL: vfrank59
thx
ORIGINAL: vfrank59
thanks,
vern
thanks,
vern
thx
I was told that you can tach higher on the ground with a conventional prop due to the fact that it unloads less in the air because of the varied pitch on the blades.
#146
Here are the two pump systems we have. Both new. The first is the 08 vintage that did not work. The second came with the kit we purchased this year. They did some work on it.
Well, the pump I have looks like the older one. That may explain why mine seemed a little slower than yours. Mine is working fine and wings are taking about 10 to 12 sec. for up and down.
I found my tach. and got the prop adjusted. I am now getting 3600 rpm. I only ran it there for about 5 secs. that was close enough till it breaks in. I am getting 800 rpm for idle. Sounds great. The electric fuel pump works fine. fine tuning the idle and max requires fine adjustment. plus or minus 1/8 in turn is either to rich or too lean. it transitions great.
Well ,last item is adding the lead. I figure 5 lbs glued in and the other 5 1/2 lbs in little removable bags just in case it is too nose heavy during the maiden.
vern
#147
My Feedback: (221)
Sounds good Vern.
On the pump, the accumulator looks the same. They made a nice aluminum bracket to hold them, and the motor looks different on the new one. Maybe a bit faster.
One more thing to check. We noticed just tonight that one of the pins on the front of the wing was loose. It was beginning to get pushed in. Not good. Loose this and the wing falls off. We glued it in good. This is the ARF version. Might want to check yours if it is the ARF. The left one seemed OK.
#148
Sounds good Vern.
Sounds good Vern.
Ok, I will keep an eye on it. One thing about these awesome projects is preventive maintenance. 90% of it is prep work in the shop and then the other 10% is easy. Good lesson for all of us to be meticulous of our pre-flight so everyone can enjoy watching and flying.
Time to break out the top flight mustang and give her heck prior to flying the corsair.
Thanks for all the great help.
Vern
#149
My Feedback: (221)
So true Vern. Noticed that the doors were not totally shut on the tail when we went to put her in the trailer Saturday, so we investigated it right there and found that the stop screw had backed out and actually fell out as we lowered the tail gear. Something else we had not installed, and had no lock tight on it.
Fixed.
Fixed.
#150
Fixed.
Fixed.
Yep, We gotta check every screw and nut. I was running the main gear up and down and the right main wheel and axle fell off. I pulled both set screws. drilled a hole in the axle and then inserted the set screws with purple loctite. That would have been embarrassing on landing. I will check all the other screw on the mains and other things that was assembled by others.
