If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 66 of 140 FirstFirst ... 1656646566676876116 ... LastLast
Results 1,626 to 1,650 of 3476
  1. #1626
    ram3500-RCU's Avatar
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: CARF F4U-1 Corsair build thread
    As for other mod parts. Anything is possible. It just takes time, and in spite of submitting many requests for more, I still only get 24 hrs / day like everyone else.
    Even with three of us working on this stuff, it takes an amazing amount of R&D to get things off the ground. Pun intended.
    The passion we all have in common for making our creations realistic and special is the driving force, not the money. That is for sure.
    Cheers,
    Gary P. / use Steel Powder for ballast not lead. PM me for more information.
  2. #1627
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In post #1575 I explained what we switching we put in the bottom hatch. Here is an explanation of what I use the top hatch for.
    http://www.youtube.com/watch?v=49hub3Gtlws
    Cheers,
  3. #1628
    Join Date
    Mar 2005
    AIX EN PROVENCE, FRANCE, METROPOLITAN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Gary
    I just looked at your hatch video on YouTube.
    I notice that you have a onboard fuel pump.
    Is it necessary to use a fuel pump with a Moki250 ? Did you install that after copping with issues ? In that case , what is the brand you use ?
    Best regards
    Stan
    http://smallplane.free.fr
  4. #1629
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: STAN-CAUSSEL
    Hello Gary
    Best regards
    Stan
    Hello Stan. IMO, yes, the pump is very good insurance for a very expensive engine and usually airplane as well. I didn't wait till I had issues. I followed the recommendations of some very experienced Moki users like Scott Prossen.
    Here is a link to the one we use, and that is recommended by most Moki dealers and users.
    http://www.ibcinyourc.com/store.php/..._radial_engine
    There are other sources, but the price is pretty good in this link.
    You will see easier starting, excellent midrange and smooth transition throughout the throttle range, and about 300 more RPM using the pump. The internal pump on the Moki is marginal at best, and subject to clogging if the vent line is not maintained. This is no longer an issue using the external pump.
    I mount the pump on the bottom of the tank. This way it is gravity primed, and primed in an instant. It only has about a 4" supply line to it, and it is all down hill.
    I would not run a Moki without one. Opinions vary.
    Cheers,
  5. #1630
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Regarding the cable that I use for the operational cowl flaps, it is the Sullivan stock #514. It is 48" long, 122cm, steel cable with nylon housing. I use this for all cowl flap installs.
    Cheers,
  6. #1631
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would like to wish everyone a happy and safe 2013.
    Cheers,
  7. #1632
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ram3500-RCU
    Gary,
    Happy new year to you and the family, hope it's a good one for you...
    I need to pick your brain about lighting on Zombie, i will send you a PM..
    Jimbo
    Ultra Sport Brotherhood #92
  8. #1633
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same to you Gary! Look forward to your contributions here in 2013.
    Casey
    Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft, BestPilots.com
  9. #1634
    saramos's Avatar
    Join Date
    Dec 2003
    Northridge, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Happy New Years Gary!
  10. #1635
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a look at our new exhaust.
    The mounting bolt hole is not pictured. It will be at the base of the opening in the longest pipe.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1837630   Click image for larger version.
ID:	1837631   Click image for larger version.
    Cheers,
  11. #1636
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another CARF with operational cowl flaps. The cowl is mounted to the new cowl ring I made. The mounting brackets CARF gives you ARE NOT THE CORRECT RADIUS. You need to lesson the curve on the three mounting brackets for them to fit the radius of the ring, and keep the curve of the cowl consistent. I'll post a picture of this later. You don't notice this so much till you cut the flaps off the cowl. The cowl is much more flexible without them.
    On this next operation, I don't find the manual to be very helpful.
    I now choose to mount the cowl first (learned this the hard way), then the engine. This way, you can easily center it in the cowl. It is very tight with the Moki engines, and it must be centered or you will be poking lifters through your cowl. I get the stand-offs for the engine made to establish the 2.5 deg right, and .5 deg up thrust. They give you dimensions in the manual to locate the center of the bolt pattern, but they don't tell you how long the stand-offs need to be to accomplish the thrust angles they want. I'll post that later as well. I make temporary stand-offs out of 1" dowel, then when I have everything aligned properly, I use these for patterns to make the permanent ones out of aluminum. After this is done, it is just a matter of moving the engine around in the cowl to align the exhaust ports and center it. Once this is accomplished, I remove the cowl, mark the stand-offs on the fire wall, and drill the holes.
    Something else on the engine bolts. You will find that is is difficult to get the long bolts in from the front due to all the piping on the Moki. I have found it easier to run the bolts out from the inside, and use nuts on the engine. You can very easily get a wrench in from the side to tighten them.
ID:	1838756   Click image for larger version.
ID:	1838757   Click image for larger version.
    Cheers,
  12. #1637
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BTW, this build will have electric gear (plug-in wings, so no electric folding wings), operational cowl flaps, electric canopy, gun system with sounds and gun flash, nav and formation lighting, and my top hatch with gas cap release. She is powered with a Moki 215 and one of those wonderful Solo props. We have a closed air system on the main gear doors only. This is completely in the wing. For this reason, I think I will use my linkage system to control the tail gear doors. No air in the fuselage that way.
    Cheers,
  13. #1638
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tight fit on the Moki. Less than 1/4" clearance for the rocker set screws.
ID:	1839118   Click image for larger version.
    Cheers,
  14. #1639
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The bolt coming from the back of the firewall. These are temporary bolts. The permanent ones will be hardened and had self locking nuts.
    The three stand-offs for this Moki 215 are 1 1/2", 1 15/32, 1 7/16.
    Cheers,
  15. #1640
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is the cowl / flap ring that mounts to the front of the fuselage. The V groove gives room for the front of the flaps to retract into. They would bind otherwise, because I mount the hinges 1/8" back from the front of the flap so you don't see the hinges, as on the full scale.
    Cheers,
  16. #1641
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are the cowl mounting brackets in place. I use blind nuts the protrude through the bracket. This offers an alignment guide for easy installation. The bolts are installed from inside the open cowl flaps. Much easier than trying to install them through the front with the baffles in place.
    These will get a little glass, Hysol and some Steel Powder for permanent installation.
ID:	1839127   Click image for larger version.
ID:	1839128   Click image for larger version.
    Cheers,
  17. #1642
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for all your work , Gary
  18. #1643
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wow, another build!
    Sweet!
    Those stacks look great Gary.
    Casey
  19. #1644
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No problem Stan. Our original estimates for shipping the first lot did not account for shut downs at the end of the year. Shipping will begin Monday, but i do have your request noted. It will ship for delivery on the 17th.
    Sorry about my in box. I will look into that.
    Gary
    Cheers,
  20. #1645
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: glazier808
    Wow, another build! *
    Sweet!
    Casey
    Yea, almost CARF central here.
    Cheers,
  21. #1646
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BTW, the next exhaust we are coming out with is for the P-47.
    Cheers,
  22. #1647
    astrohog's Avatar
    Join Date
    Dec 2001
    Bellingham, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is your timeline on the P47 exhaust? I am assembling mine now for a springtime (whenever that is around these parts!) maiden, think you'll have them available in the next couple months?
    Regards,
    Astrohog
  23. #1648
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: astrohog
    Regards,
    Astrohog
    The R&D is done on the Corsair exhaust. Fixtures are made, and they are in production.
    We will be working on the P-47 in the coming weeks. They will be sized for the Meister and a little larger for the CARF. I hope to be able to offer smaller ones for the Ziroli and Yellow as well.
    Eventually, I would like to offer exhaust for all the Meister and CARF war birds.
    Cheers,
  24. #1649
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: astrohog
    Regards,
    Astrohog
    Which P-47 are assembling?
    Cheers,
  25. #1650
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Parts that make up the scale exhaust. All stainless.
    Those cones are machined from solid bar stock.
    Cheers,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
