If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 140 FirstFirst ... 567891757107 ... LastLast
Results 151 to 175 of 3476
  1. #151
    ram3500-RCU's Avatar
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: CARF F4U-1 Corsair build thread
    ORIGINAL: vfrank59
    ORIGINAL: ram3500-RCU
    So true Vern. Noticed that the doors were not totally shut on the tail when we went to put her in the trailer Saturday, so we investigated it right there and found that the stop screw had backed out and actually fell out as we lowered the tail gear. Something else we had not installed, and had no lock tight on it.
    Fixed.
    Yep, We gotta check every screw and nut. I was running the main gear up and down and the right main wheel and axle fell off. I pulled both set screws. drilled a hole in the axle and then inserted the set screws with purple loctite. That would have been embarrassing on landing. I will check all the other screw on the mains and other things that was assembled by others.
    Embarrassing, and costly.
    Cheers,
    Gary P. / use Steel Powder for ballast not lead. PM me for more information.
  2. #152
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: glazier808
    You're becoming quite the embassitor of giant scale sir!
    Watching with envy
    Casey
    Casey,
    you can say that again!!!!!!
    Gary,
    I would just like to take the time to share my opinion as well..
    You sir are a wealth of knowledge and your kind enough to share it.. We have a lot of guys with egos bigger then their head in this hobby, but you do not fall into that group.. You posting that vid of you first landing mishap is proof as to what type of person you are, most guys would have kept that one to them self.. You showed it and talked about it, which will help many others not make that same mistake, good stuff in my book... I have learned a lot from you and even though we never met, I consider you a friend.. I'm am very much looking forward to sharing a flight line with you next year my friend, your first class all the way.......
    Jimbo
    Ultra Sport Brotherhood #92
  3. #153
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Mustangman40
    Watching with envy
    Casey
    Casey,
    Gary,
    Jimbo
    Praise from my peers is the most appreciated by me. I don't take it for granted or lightly. Thank you so much for the kind words. I'm very glad to help my fellow friends any way I can.
    As for this giant Corsair and planes like it, the investment in time and money is considerable, as all of you well know. It hurts me to see one of these giants go in. I have learned a lot from my fellow modelers that has helped me model these giants safely. I enjoy returning the favor when ever I can. It is very gratifying to hear that we are doing some good. Thanks guys for saying so.
    Cheers,
  4. #154
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We have decided to stay home this week end after all. We wish all the flyers happy landings at Muncie. See you next year.
    We will be tearing down the Corsair for paint, and getting some work done on the other airframe. The wing needs a lot done to it before it is ready to install the electric gear.
    We will be posting pictures of the kit build as it goes along. It will be different from the ARF we have in many ways. Electric gear (still air on the doors), electric wings, Sliding canopy, more scale cockpit, full lighting system, aluminum foil covering on the whole plane, working cowl flaps, and much more. Fun stuff.
    Cheers,
  5. #155
    Join Date
    Dec 2010
    Mt Morris, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looking forward to following along, post away............
  6. #156
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Vern our corsair took less than 5 lbs to balance, I would recheck yourself before test flight that sounds like alot of weight to me. We have the 215 Moki on ours and I believe it may be a bit lighter than your 250. Good luck Mike
    \"No hanger Queens\"
  7. #157
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: luckyb001
    I set my cg marks 6 1/2 inches from the leading edge closest to the fuselage. I placed my CG machine right next to the fuselage and my eyeballs say the plane is level. Does this sound like I have the CG marks correct? The wing fold aluminum mechanism is just behind my CG marks by 1/2 inch.
    I have not added the lead yet.
    Vern
  8. #158
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vfrank59
    ORIGINAL: luckyb001
    Vern
    Your gear should be up when balancing. Is it? Also, if you used two servos on the elevators, you will need more nose weight than we did. 1oz in the tail = about 4oz in the nose. Wew don't have a tail hook installed either.
    The 6 1/2 to 6 5/8 in is what we used as well.
    Cheers,
  9. #159
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vfrank59
    ORIGINAL: luckyb001
    Vern
    Yes, I have the gear up when balance was checked. I do not think it makes a difference but I also had it upright when I balanced the plane.
    What I have is for large air tanks in the fuse behind the cockpit. I have a full detailed cockpit and a pilot. the pilot weighs about 4 oz. The 4 air tanks weigh 6 oz total. So at 10 oz , I would not think it would take an extra 5 lbs of lead.
    Vern
  10. #160
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Our plane was balanced according to the compartment manuel and it flys perfect not sure y you need so much weight.
  11. #161
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am seriously thinking of getting 3 postal scales and doing it the calculated math way of determining where the CG currently is without any lead in it. I have read the math should work out the same for RC as it does for my 47 Stinson.
    Vern
  12. #162
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have two elevator servos and a tail hook. How r u balancing the plane. I have a system where the plane is suspended in the air by a harness and leveled as a pointer comes to the cg point on the plane when the balance is correct. This system has not failed us and we have balances many large planes this way. Not trying to be a no it all but done want your plane to get damaged. Has anyone had to add this amount of weight. Mike
  13. #163
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    While running the Moki 250 for the first time. I notice the idle screw with the spring under it was still in place on the engine. Did you guys remove the idle screw completely like We do on most RC gas engines?
    Vern
  14. #164
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I removed mine
  15. #165
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: luckyb001
    I am using the EZ balancer [img][/img]
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  16. #166
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I borrowed that same balancer from a friend to balance a 3W P-51 and found it to be very inaccurate. I would use a different method and see what result you get.
  17. #167
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: luckyb001
    Ok, I am all ears for ensuring a well balnced plane. Are you using the Venessa CG machine type of device?
    Vern
  18. #168
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tomorrow when I get home I will get you the info on my balance system. I'm at the fire house till _8 am.
  19. #169
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: luckyb001
    Thanks a bunch, I have read about the Vanessa machine and am having trouble visualizing the setup. So your info will help me a lot.
    Thank you,
    Vern
  20. #170
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vfrank59
    ORIGINAL: luckyb001
    Thank you,
    Vern
    Is this kind of what you are talking about ,, The Sling method?
    Vern
    [link]http://www.henrylx.rchomepage.com/Stuff/Sling.pdf[/link]
  21. #171
    Join Date
    Feb 2002
    Davie, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes that's basically it my sling and harness are a bit different. I will get you a copy of the instructions and some photos when I get home.
  22. #172
    Join Date
    Dec 2005
    buckeye, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: luckyb001
    I found this type also.
    [img][/img]
  23. #173
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vfrank59
    Vern
    I remover ours as well.
    Cheers,
  24. #174
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some pictures of our home made balance system. The plane flies well, and so do other giants we have used it on.
    Thanks for all the other posts on this. I'm always interested in how other guys do this as well.
    BTW, the white stuff is 1/2" felt Brian gets from work.
ID:	1657109   Click image for larger version.
ID:	1657110   Click image for larger version.
ID:	1657111   Click image for larger version.
    Cheers,
  25. #175
    Join Date
    Aug 2002
    n. canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vfrank59
    ORIGINAL: vfrank59
    ORIGINAL: luckyb001
    Vern
    Vern
    I think the tanks might make a bigger difference than you think. We have two large tanks in FRONT of the cockpit. No pilot in ours yet. It all adds up, but I think it may be a combination of how you are checking the CG, and the location of your components. I bet you are able to reduce the ballast by a couple pounds.
    Cheers,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
