Midwest AT-6 Overhaul
Reply
Old 12-19-2016, 11:55 PM
  #101
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by smkrcflyer View Post
I'm assuming the sealer can't be water base or it could cause warping?
Correct
Chad Veich is offline
Old 12-20-2016, 06:50 AM
  #102
pacoflyer
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have also used "Final Net" hairspray which is lacquer based I believe.
It does a nice job of sealing the wood prior to glassing, is easy and quick.
paul
pacoflyer is offline
Old 03-09-2018, 08:12 AM
  #103
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fiberglassing of the wing went well. It was much easier then plastic covering. The fiberglass conformed to the surface much more then I through it would. After I put the primer on I noticed some low spots that Ill need to fill before the next coat of paint goes on. What do you guys use for filler over fiberglass?
ID:	2258634   Click image for larger version
ID:	2258635   Click image for larger version
ID:	2258636   Click image for larger version
smkrcflyer is offline
Old 03-10-2018, 05:50 AM
  #104
pacoflyer
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
smk,
You might try the Evercoat line of fillers.
They are easy to use , dry pretty quickly and sand very smooth..
You can find them at most auto parts stores.
paul
Old 03-10-2018, 11:53 AM
  #105
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The best filler I've come across is a simple mixture of Acetone and glazing putty (I like the Bondo brand stuff). It fills like a good high-build primer, sands even easier, and is much cheaper. A couple of coats of that sanded off, and then one or maybe two coats of filler-primer and usually more than enough to get a glass smooth surface.
Old 06-24-2018, 04:40 AM
  #106
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Took 3 years but the AT6 is back on its wheels. Still have a bunch of things to do. Replaced the g26 with a new DLE30, this took about 1.4lbs off the nose. Also replacing the batteries and fuel tank. Hope to get it in the air by the end of the year.
Old 06-24-2018, 02:15 PM
  #107
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You will probably be putting that back in some form. The airplane is notoriously tail heavy, although less so if you ignore Midwest's recommended balance point and instead balance at about 28% of the total wing area.
Old 06-24-2018, 02:22 PM
  #108
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My plane was nose heavy and could not get it to 28%. So at least now when or if I have to add weight I can move it around to get the correct cg.
Chad, Do you what the total weight of your plane is without fuel?
Old 06-24-2018, 04:11 PM
  #109
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I never accurately weighed my airplane Steve but it was about 17 pounds on the fish scale, so give or take half a pound.
Old 06-24-2018, 04:25 PM
  #110
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Chad that gives me a target.
Old 07-05-2018, 08:18 AM
  #111
smkrcflyer
smkrcflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the t6 fully assembled. Total weight is 14.2 lbs. CG at 5.5 inches back is good, no extra weight is needed. I do have one question. What part of the plane do you use to look a level? I checked both horizontal stabilizer and on the wing between the wheels.
