If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 187
  1. #101
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: LA7 Info / Research / Build - Scale Wings
    Here is a status update
    The real and dummy hinges are in… Have a bit of epoxy cleanup work to do on them.
    Made the oil cooler exhaust flap functional which should help with getting air out of the airframe. Should create a good low pressure area behind it to pull air out. Not exactly sure how I am going to use this right now but one thought is to link (mix) the oil cooler flap (door) to the throttle position.
    I sanded out the mold lines on the cowl today.
    Received the retracts back from Down & Locked yesterday.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1734563   Click image for larger version.
ID:	1734564   Click image for larger version.
ID:	1734565   Click image for larger version.
ID:	1734566   Click image for larger version.
ID:	1734568   Click image for larger version.
ID:	1734569   Click image for larger version.
  2. #102
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The large access door looks good when it is pulled down tight; I guess I will start with magnets to see if that will keep it pulled down and then use a standalone servo to push the door open.
    Also, here are two more shots of the oil cooler door.
ID:	1735394   Click image for larger version.
ID:	1735395   Click image for larger version.
  3. #103
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got a few things done since the last post. Installed the tail gear doors and dummy hinges in the cowl. I have been using a 3M full face mask for the dust.
    Designed the access panel and got ready to cut the CF with a 1/8 bit then realized I didn't have a 1/8 collet, so had to order that.
ID:	1737513   Click image for larger version.
ID:	1737514   Click image for larger version.
ID:	1737515   Click image for larger version.
ID:	1737516   Click image for larger version.
ID:	1737518   Click image for larger version.
ID:	1737519   Click image for larger version.
ID:	1737520   Click image for larger version.
  4. #104
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have been working on fitting a grill to the inside of the oil cooler; which still need some teaking...
    I could use some recommendations on the tail gear doors. I cannot seem to find the right arm length and/or angle to make this design work.
ID:	1738432   Click image for larger version.
ID:	1738433   Click image for larger version.
ID:	1738434   Click image for larger version.
  5. #105
    mick15's Avatar
    Join Date
    Apr 2002
    Essex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can take a picture of mine, installed by the factory and seems to work ok.
    m
  6. #106
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mick15
    m
    Thanks M...
    John
  7. #107
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am pleased with the look of the oil cooler grill now... Just need to add some dirt and grime to it and it will be perfect.
ID:	1738561   Click image for larger version.
  8. #108
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The more I use the Down & Locked converted gear the more I like it. Once I get my CARF P-47 back from Graham (Jetjockgb), I will be sending that gear to them for a conversion.
  9. #109
    mick15's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Picture of the doors you require.
    m
  10. #110
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mick15
    m
    M,
    Iwill install it the way your photo shows. Thanks again...
    John
  11. #111
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cut the access control panel out tonight along with a few other items. Almost ready to mount the oil cooler and epoxy it on.
  12. #112
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Was on the road working the last part of the week and just getting back to the LA-7. Almost have the control/fuel panel done...
  13. #113
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Worked on the frame for the control panel this evening; almost done with it. Been test fitting it as Igo...
    If I ever want or need to change the panel layout, it will be easy to remove the insert and make a new one.
ID:	1743288   Click image for larger version.
  14. #114
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Went to mount the Moki 250 today and realized that the engine standoffs are missing.
    Could use some help from ScaleWings LA-7 owners on how long should these standoffs be?
    I will email Hans at ScaleWings too...
    I have attached two photos are what they look like.
ID:	1744320   Click image for larger version.
  15. #115
    mick15's Avatar
    Join Date
    Apr 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine does'nt have standoffs, it has a built up wooden mount. The measurements will obviously be the same though, I can measure it for you but not tonight.
    m
  16. #116
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Spent the afternoon making CF parts to replace the wood ones...
ID:	1744731   Click image for larger version.
ID:	1744732   Click image for larger version.
  17. #117
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I felt like a change of pace on the LA7 assembly so I started working on redesigning the fuel tank holder and equipment tray.
    My LA7 came with only one of the round fuel tanks and it has been a pain trying to get another for a smoke-tank. So I decided just to go with DU-BRO 80oz tanks for fuel/smoke. This required a redesign of the original ScaleWings parts and I also extended the length from 200mm out to 500mm. This will allow me to mount the Futaba PSS2018 and all the other items like batteries and APS fuel / smoke pumps on this one slide out assembly.
    The first photo shows what the original holder looks like…
ID:	1745409   Click image for larger version.
ID:	1745410   Click image for larger version.
ID:	1745411   Click image for larger version.
  18. #118
    Prekin's Avatar
    Join Date
    Jan 2008
    Brno, CZECH REPUBLIC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello wxman,
    I saw the picture of the book about the La-7 and it looks, that it is in the Czech language. If you want, I can translate something for you, if you donΒ΄t have it in the English.
    God created aircraft mechanics, so pilots can have heroes too.
    Scale accessories at: www.jpwarbirds.wbs.cz
  19. #119
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Perkin,
    I may take you up on this offer... I have one MBI La-7 book that is in Czech with an English translation, but have been using Google Translator for some other Russian manuals.
  20. #120
    Prekin's Avatar
    Join Date
    Jan 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, If you will have some problem with Russian or Czech, write it here, or use my e-mail, and I can help you.
  21. #121
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finished up the 2D CNC drawing... Plan to cut this out of wood first to make sure of the fit before cuting the carbin fiber.
  22. #122
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I posted an open question about using a shaft couper here for this project:
    http://www.rcuniverse.com/forum/m_11...m.htm#11029214
  23. #123
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The top and bottom trays are built... Just need a bit of time for the epoxy to cure and will finish up the assembly in the morning.
    Plan to mount the motor tomorrow to figure out how long the standoffs need to be.
ID:	1747539   Click image for larger version.
  24. #124
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is the finished fuel/smoke tank holder / equipment tray contraption...
ID:	1747795   Click image for larger version.
  25. #125
    wxman2's Avatar
    Join Date
    May 2010
    Pasadena, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The main wheel covers that came with the plane are plastic and I started the process digitizing one of them so that I can cut it out of aluminum.
ID:	1747803   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
