Reload this Page >
Evolution 7 cylinder 260cc radial engine - Operation and maintenance
Reply
Old 06-06-2016, 06:42 PM
  #401
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by F4u5 View Post
James, while I appreciate your resourcefulness, and talent.....and believe me I do apreaciate your info, I just disagree that for a $3k+ engine, we modelers should have to rebuild it. I did replace all of the clips on the rocker arm shafts, as you say, but I do not plan to disassemble the engine for internals. Nonetheless, I now have issues with the brass fittings that retain the cam rod lifters. This appears to be another poor mfg area. You really should have at lease 2D thread engagement into aluminum, and the 2 of mine that stripped out, I just don't see that amount of engagement (not close). I have the skills to pull this engine apart and go thru it, but, for me, I will send it back to Horizon and make them sort it out. If the engine does not run satisfactory, live and learn, I will simply move on to a 2 cylinder opposed. This experience has convinced me that radialsare not worth the hassle. Best of luck to others runnings this engine. Too bad,because when it is running, it is running good and strong.
Jeff
Hi Jeff,
Don't get me wrong, mate, I totally agree with you that you should not have to "fix" a $3k+ engine. If my engine was still in warranty, and/or I lived closer to Horizon HQ, I too would have sent mine back. However, I did not have this luxury. I had the engine sitting in a box for the first 6 months or so after purchase. And during the last half of the warranty period I didn't have much flight time on the engine, and none of the issues had appeared at that stage. So my only choice was to either send it back for repair at my own cost, or repair it myself. I chose the latter. I guess it all depends on what you want out of a model airplane. To me a horizontally opposed twin 2-stroke engine is the last thing I'd want to strap to the front of my model, especially a radial engined airplane. The sound would be terrible! However, that is just my opinion. Everyone is entitled to their own, of course.
I hope you have some luck with Horizon, as they are a great engine when they are running well.
Regards,
jymster is offline
Old 06-07-2016, 05:17 AM
  #402
F4u5
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm with you James I love the 260 when it's running. I am more of a daily flyer so the opposed 2 strokes are dependable. You have been great help. My engine is on its way back to Horizon so I hope it works out as it looks like it was made for my corsair.
Jeff
F4u5 is offline
Old 08-24-2017, 04:52 PM
  #403
2wingsonly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by jymster View Post
G'day Jeff,
That is a real bummer, mate. I can understand your concerns and I agree that there seem to be some serious quality control issues at play here. We've not had as many issues as you've had, but we have had a few. I think the main difference is that we diagnosed the problems quickly and sorted them out early. We now have very reliable engines. Whilst I agree that it is not something we should have to fix ourselves, here in Australia we unfortunately don't have the convenience of being able to send the engines back to Horizon easily, and so can not easily just pop it back for repairs. And now that our engines are out of warranty we have no choice but to be resourceful ourselves. To be fair I also note that there are many unhappy Moki radial owners as well, albeit for different reasons. I think a big part of the issue is that radials just need a lot more maintenance and work than single or twin cylinder engines. It is the nature of the beast, I'm afraid. The full scale engines are no different.
However, these engines do have some quality control issues that can easily be sorted out, with a little bit of knowhow. Below are my two recommendations to anyone owning an Evo 260, to make it a reliable and long lasting engine:
1. Replace all internal circlips (con rods) and external e-clips (rocker arm pins) with quality clips. The stock cir clips are made of inferior steel and are libel to eventually stretch and come off during running of the engine. When the external e-clips come off you can lose a rocker arm assembly. When an internal circlip comes off it can go right through the engine, score the cylinder bore and jam open one of the valves. Can make a real mess if not diagnosed early. Best to replace them all as early as possible.
2. Check all valve guides for fit tolerance. We had 1 or 2 cylinders that threw pushrods, but after checking the valve guides we found that they were sticking open, hence pushrods fell out. We've since honed the pushrod guides, simply my attaching a cordless drill to the valve stem and rotating in and out for several minutes, and haven't had a problem since.
These seem to be the two most common issues with these engines, and something that Horizon should definitely be looking into fixing at a factory level. Apart from these two issues the quality of the engines has so far proved to be excellent. My mate Craige has now clocked over 200 flights on his 1/3 scale Sopwith Triplane with the Evo 260. That's a pretty good advertisement right there. However, he did perform the two recommendations above very early on, and now has relatively trouble free running of this engine.
Can anyone tell me the size of the circlips? I would like to source them before I pull mine apart.
2wingsonly is offline
Old 08-24-2017, 11:34 PM
  #404
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2wingsonly,
To be honest I can't remember the sizes, but the easiest way is to remove the old e-clips and circlips an take them to your local bearing or hardware store and get the matching sizes.
Regards,
James.
jymster is offline
Old 09-24-2017, 03:30 PM
  #405
amilcar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can somebody tell me if there are spare parts for these engines the 77 and 33 cc glow? sure they look cool but if something brake like the carburetor or anything else were do I get parts for it?
thanks,
amilcar is offline
Old 09-24-2017, 03:41 PM
  #406
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks,
Yes, you can get the major parts from Horizon (probably all parts if you contact them), but you can also get them direct from UMS in India - support@umstech.in
jymster is offline
Old 09-25-2017, 01:44 PM
  #407
amilcar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks I'm still deciding between this evolution 77 radial and the 3cly saito 60cc gas ..they are about the same price but I want a problem free engine ...,again thanks for the reply
amilcar is offline
Old 09-25-2017, 05:41 PM
  #408
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had over 100 flights with my Seidel UMS 7-70 (predecessor to the Evo 7-77) before the circlip on the crankshaft failed. There was also a little bit of wear on the cam ring, but apart from that I've had no other issues with the engine. It started and ran as well as any O.S. or Saito engine I've owned. My only recommendation is to replace all circlips with better quality ones from the outset. And just make sure you do regular maintenance as you should with any engine.
jymster is offline
Old 09-26-2017, 05:49 AM
  #409
amilcar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes,u see I'm looking at santo page and for the 3 cly they have almost every replacement part for their engines and then i'm looking at evolution and they have no many parts for their radials ,,still I like more the radial 7 cly and i'm goin to use the engine of choice win a fokker eindecker proctor I'm building ,the plans recommends the zeidel and with this engine the plane will balance perfectly and will fit perfectly .
amilcar is offline
Old 09-26-2017, 06:20 PM
  #410
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, you can only see the major parts on the Horizon or Evolution websites, however I believe you can get any part you like from Horizon or Evolution, you just have to ask for them. Otherwise you can get all parts from UMS in India direct. See the attached parts list I got from UMS when I ordered spare parts for my Seidel 7-70.
Attached Thumbnails EVOLUTION GLOW RADIAL ENGINE EXPLODED VIEW.pdf
jymster is offline
Old 09-26-2017, 07:32 PM
  #411
amilcar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool ,thanks for the info I think i'll go with the evolution 77 for my eindecker
amilcar is offline
Old 12-17-2017, 12:04 AM
  #412
dgiokas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone have info on why Horizon has discontinued carrying the Evo 160cc, or if the other radials will also be discontinued?
Also, is there another source for parts? UMS India website does not really have any parts list available.
dgiokas is offline
Old 12-17-2017, 08:48 AM
  #413
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Who knows why Horizon does anything???
There is a company in Germany that carries parts. UMS has parts as they make the engines.
I would suggest you contact them for any thing you may need now or in the future. Whey I bought my engines from UMS/horizon I also ordered some spare parts like push rods, cam pins etc. Things you might lose and need.
BobH is offline
Old 12-17-2017, 09:20 AM
  #414
amilcar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just ordered some parts for my 7-77 just to have extra rockers and so on and chatting with one of the horizon hobby representatives I ask if they are planing on discontinue the 160cc radial and the answer was no !! he told me that they will be around for a while ,who knows ,if its true or not .
I told him that I hope will not be the same like with arf planes that u have to buy two one just for parts because then there's not parts nowhere ,not like he care but I express my concern is not like I can come up with $1300 extra to buy another one to have it just in case .
Now I asked the guy if they are the only ones that sell parts for the radial engines and he told me yes ,,but somebody posted a contact info place here in this forums where i think that they sell parts for them not only rockers most of internal parts too ,if u go to horizon they only have a few things from the engine to sell ..anyway i did not even started mine yet ,and I hope that by tacking care of it I'll have it for long long time with no problems
amilcar is offline
Old 12-17-2017, 09:56 PM
  #415
jymster
My Feedback: (9)
jymster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dgiokas, here is the UMS India parts list for the EVO 260 and 160, they have all parts available. I would presume Horizon are just out of stock, but who really knows. It is still listed on the Evolution Engines website.
Attached Thumbnails EVOLUTION PETROL RADIAL ENGINE EXPLODED VIEW.pdf
jymster is offline
Old 12-18-2017, 05:08 AM
  #416
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Itís difficult to say whether 160 parts will be available. The HH site says backorder. I just had the cam block replaced on my new 160 last week and went through three ignitions in November as well. I spoke with the mechanic that did the repairs on each occasion. He told me that the 160 is discontinued and there were no more ignitions available for replacement. He also didnít know whether parts would be restocked for the 160. I discovered from UMS that the 160 pushrod problem has been resolved by replacing the aluminum tubes with stainless steel. The HH mechanic was not aware of that either. So, HH apparently doesnít keep any of their people informed of what is going on with product they sale to us...I sure donít want to deal with UMS (India) directly
n8622t is offline
Old 12-18-2017, 09:27 PM
  #417
dgiokas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Official response from Horizon re Evo 160...
We do not have any information regarding retailers that may or may not still be selling this engine. Evolution has discontinued production of that engine, with no provided information as to why. Seems this is just one that ran its course and was not replenished.
You can still find some parts available at this link in the parts and accessories section.
https://www.horizonhobby.com/7-cylin...ngine-evoe7160
Kind Regards
Todd Product Support
Horizon Hobby, LLC
dgiokas is offline
Old 12-18-2017, 09:28 PM
  #418
dgiokas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Duplicate entry.
dgiokas is offline
Old 12-19-2017, 06:46 AM
  #419
n8622t
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kind Regards
Horizon Hobby, LLC
there ya have it....no help and no info
n8622t is offline
