ESM 50cc ME-109
Reply
Old 01-08-2012, 10:17 AM
  #451
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ESM 50cc ME-109
Glazier, great information. What about color schemes?
Ramstein44 is offline
Old 01-08-2012, 10:25 AM
  #452
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's one last one of G2's, this is all that I have that might interest you, I think...I'll check some more books that I have and see what I can come across, but most of them are either about JG54(GREENHEARTS), or the 109F though I believe.
I'm glad to be of help!.
Casey
glazier808 is offline
Old 01-08-2012, 11:03 AM
  #453
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have found a couple of color period photo's of a G6 and a G14 both with "erla" hood and "tall" tail. I'll post those in a bit as I have to run an errand for the wife.
Casey
Old 01-08-2012, 02:08 PM
  #454
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here ya go...(just the lower picture)I'm afraid that may be the extent of what I have on the "tall" tail and "erla" hood 109G's
Casey
Old 01-08-2012, 02:14 PM
  #455
glazier808
glazier808's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my guess is that the last pic is a G6 due to the tail wheel(not a "tall tail"), but I could be incorrect.
Casey
Old 01-08-2012, 04:47 PM
  #456
HoundDog
HoundDog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a sign up
HoundDog is offline
Old 01-08-2012, 05:01 PM
  #457
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
started on Tys cockpit and hatch mounts
ID:	1711684   Click image for larger version
ID:	1711685   Click image for larger version
ID:	1711686   Click image for larger version
ID:	1711687   Click image for larger version
n8622t is online now
Old 01-09-2012, 05:36 PM
  #458
tdog65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Started on the fuselage,4"swb bellcrank tied to  a swb 3 1/2" double horn with
4-40 turn buckles and ball links. JR 8411 servo 6 volt. Kevlar pull pull and
aeroworks 1 1/4 horns all for rudder only. Found an issue if I may share
with the rudder and elevator system
tdog65 is offline
Old 01-09-2012, 05:47 PM
  #459
tdog65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Slide both aluminum tubes thru fuse,then invert the plane and strap the main
wing tube to a set of saw horses with the main tube level,I used an incedence
meter.Prop the tail up between the cockpit and rudder so the thrust line is level,
basically will look like inverted level flight.
tdog65 is offline
Old 01-09-2012, 06:02 PM
  #460
tdog65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check the elevator wing tube for level,again an incedence meter.Mine was off
2 1/2 degrees. I can move my whole rudder by pulling up and down on the
elevator tube with ease, at least 3-4 degrees either way. While doing this I
payed attention to inside the tail wheel hatch area and noticed the fiberglass
flexing where there should be a rudder post and also on the whole bottom
section of the elevators
tdog65 is offline
Old 01-09-2012, 06:09 PM
  #461
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hummmm!
Old 01-09-2012, 06:17 PM
  #462
tdog65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I removed what i would call F7,tailwheel former.Needle nose pliers and
really no effort.Incedence went to 3 degrees.Will fab a new F7,and add
cloth and resin to strenghthen whole rear end.
    sorry so lengthy on this,maybe save flutter or tail gear issues
                                                          Tim
tdog65 is offline
Old 01-09-2012, 06:43 PM
  #463
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Out of curiosity, I placed mine all together all to find out that the diameter of the horizontal stabilizers dowl hole is much larger then the metal dowl. Placement should be interesting. Wouldn't it be nice if these parts were somehow checked for quality prior to packaging! I gues these kits are like a box of chocolate...
Old 01-09-2012, 08:31 PM
  #464
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ram my esm tigercat stabs were the same way.....I wrapped the tubes with masking tape to center the fit and ca the tape....not saying this to be the fix but it worked
Old 01-09-2012, 10:05 PM
  #465
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
God stuff. I'll give it a go.
Old 01-10-2012, 07:53 AM
  #466
Sonny.C
Sonny.C's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm almost to the point of fastening the horizontal stabilizers to the fuse. The alignment dowel holes are drilled and the dowels epoxied into to both stabilizers. What would be the correct incedence position for the stab?
Sonny
Sonny.C is online now
Old 01-10-2012, 07:56 AM
  #467
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The manual doesn't mention any so I would assume other then doing it per the manual to just make sure there the same and straight. Worked for me on my Dora. I wouldn't complicate this anymore then I'd have to here.
Old 01-10-2012, 02:25 PM
  #468
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ram I'm ready to start cutting the canopy frames ....what woods and sizes do I need
Old 01-10-2012, 03:04 PM
  #469
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry for the delay, I thought I'd have more time with your p40 progression. I used 3/32 for the top portion of the frame that curves. I used .030 styrene to overlap all parts. Light ply, 3/32 is used to reinforce the front of the canopy. The clear plastic is .030. On top and .040 on the sides for strenght. It's rock solid when completed. I have the parts sitting here which do you no good but ready to ship out later today. The temps are traced so cut along the inside
Old 01-10-2012, 03:22 PM
  #470
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sending the specs to your email.
Old 01-10-2012, 04:33 PM
  #471
tdog65
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sonny .C
              Correct incedence would be  0  degrees with the thrust
               line at zero.Just like your other planes,I checked your
               dossier and you have very nice planes. The issue I have
               with mine is a=a on the main wing tube  but b does not =b on the stab
               and the tailwheel former is not 90 degrees with the thrust line.further
               inspection  found  thin glass moulding allowing to much flexing as well.
               just a heads up for anyone that actually measures  this arf
        thanks
        Tim
tdog65 is offline
Old 01-10-2012, 05:52 PM
  #472
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ramstein44
Thanks Ram...Im just waiting for Robart to send the replacement parts for the gear...brand new gear by the way, but she is all ready for the maiden.
Old 01-10-2012, 06:08 PM
  #473
Ramstein44
Ramstein44's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet! I'm considering the ESM version after I get the raiden!but I still want the dornier for my fleet to be complete.
Old 01-11-2012, 06:34 AM
  #474
Sonny.C
Sonny.C's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Tim,
I'll double check the incedence of the tail feathers and be sure its correct before epoxying them to the airframe.
My assembly progress so far:
The assembly of the cockpit kit is moving along and about ready to paint. Will make a small servo tray for the elevator and rudder servos set low in the fuse so the cockpit floor will clear.
Decided to go with Shinden retracts instead of Sierra (because Lenny had a set ready to go), and they have been shipped and on their way to Texas.
Still no freakin spinner available from ESM here in the states. Grrr
Went to test fit the engine mount cylinder. It took a lot of sanding to get that baby into the fuse.
Still plugging away....
Good luck with your build!
Sonny
Old 01-11-2012, 05:58 PM
  #475
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah Ram that would be a great thread to follow Got some wood rails glued in so maybe get hinges in tomorrow
Reply
Display Modes
