New Hanger 9 P-47 30cc and electric friendly
#176
My Feedback: (22)
RE: New Hanger 9 P-47 30cc and electric friendly
Hey Ron - I'm currently trying to install my rimfire 50cc into the plane. However I'm having trouble getting the motor to clear the dummy radial. Is it ok to push the prop backplate up with some kind of shim?
Well I may be the wrong guy to ask I wanted to get my dummy engine to clear... so to do that I use a collet on the already long hacker motor shaft. This caused a viberation and broke my motor mount in flight. What is did now was mod the dummy engine and push my motor out more. This will stop the viberation and help CG.
So what ever you do don't push it out to far and cause a viberation. It still looks ok and will be functional
#177
I was wondering if that was the cause! I've heard those mounts aren't very good. But that explains it on the first flight.
I don't need to extend the shaft at all....so that's good. Just need to push the prop backplate up about 5/8 inch or so. Hopefully I can find a spacer at OSH or home depot.
#178
My Feedback: (91)
Hey guys...
I have an untouched Dynamic Balsa cockpit kit for this model that I'm not going to use. PM if you are interested... they are $90 new and I'll sell mine for $75 shipped.
Curt
Curt
#179
My Feedback: (22)
Finally got some really good flights with this bird.... had a perfect day with 5 flights.
This thing flies so nice!! wow... so easy to land I can't believe it
It's like a trainer
I'm very happy with her now that I have it all sorted out,,,
It's very fast at full power with the Hacker A60-16L on 12s with a 20X15 prop
I'm getting a 5:30 flight time with a couple go arounds left in the pack.
I fly most of the flight a couple clicks above half power looks nice and scale... couple burner passes, loops and verticals then land
Love it!!
It's like a trainer
Love it!!
#181
My Feedback: (22)
Hey Casey,
Sorry no video... my flying buds went to a meet. So I didn't bother bringing out my camera.
I'll try and get some soon.
This is such a sweet heart of a plane to fly I really can't believe it..... it's like a piper cub to land, it's a no brainer and I havn't flown in a month so I was rusty.
#182
My Feedback: (91)
ORIGINAL: Ron101
Hey Casey,
Hey Casey,
I'm almost done with mine... I get caught up with little details!
How did the aluminum doors hold up?
Curt
#184
Glad to hear it Ron. Mine is coming along nicely. I'll start to add details once I've flown it. But at this point I just want it in the air.
What did you end up doing to the extended motor shaft?
#185
My Feedback: (22)
I ended up moving the motor forward and getting rid of the collet and running the stock hacker way.... all is good now
#186
Finally flew mine! Ron isn't joking... this is one nice flying bird. I flew it with a rimfire 50cc on 12s5300. Prop was a 20x12. I'll be increasing capacity to at least 6600mah. But all the vendors I like seem to be out!
With the rimfire and 5300 batteries I didn't need any nose weight. It balanced right at the rearward cg recommendation in the manual. The motor is without question overkill as I didn't even get over 1/2 throttle but it should provide lots of spirited flying.
#188
Hey Ron do you have any photos of how you set up your Hacker and the dummy mod needed to push motor futher out instead of using the collet? I'm putting the A50 16L in my TF .60 and since I want a giant EP I've been following the H9 P47 threads. It's a hard choice between the TF and the H9, and even the the H9 is slightly smaller I've pretty much made up my mind that H9 will be my choice when the time comes.
#189
My Feedback: (22)
If going with electric giant scale P-47 to me the Hanger 9 wins hands down
It's so much lighter and has that huge hatch on top to get packs in and out
The hidden hinges on the flaps are also much cooler, also the top flight has always had a funky canopy shape
with that said I had the 60 sized TF P-47 setup on e- power and it was a really nice flyer... but this larger hanger 9 is the cats meow! can't wait to long many flights on it this spring. I'm already thinking about adding a lighting system and make the bombs drop.
As much as I love Hacker motors since you have to use a front mount on them ..... in hindsite I would go with a rear mount motor in this one. Axi, Power 160, Scorpion... but this is my flyer so it is what it is. The mod was hack a big hole in the dummy engine
I ran out and snapped a picture , it's hanging on my wall so kind of hard to see. But all setup it's really not that bad.
#190
I'm wondering, could have you shortened the shaft and still used the collet to reduce the vibration that broke the motor mount and not have had to mod the dummy ?
#191
Hi Everyboy,
I am new in the Forum and have read this thread with great interest! Just got my hands on a Hangar 9 P-47 Bubbletop Kit, will pick it up today....enough time to build before the season starts. Funny thing is that Horizon Hobby offers the Kit in Switzerland, but NOT the Robart Retracts and the optional parts....my dealer is in a discussion with the Swiss Affiliate of Horizon.
Looking at the ideal E-Configuration at the moment, planning 10s or 12s, currently my choice would be:
- Scorpion SII 5525-210 (210 )
-2 x 5s Lipo 4500 mAh 30C
-Prop 20x13 Meizlik Carbon
Hearing about having to add weight at the front my question: how much weight did you have to add with which configuration?
I will add a Benedini Souns System 50 Watt at the front, another 10 ounces...
If still much weight would have to be added, I probably will go with 12s and a heavier motor, too.
Kind regards from Switzerland
Peter
#192
My Feedback: (22)
Hey Peter,
Welcome to RCU
With the Hacker A60-16L and an ICE 160 up in the nose and my 12s 65c 5000 mah packs pushed to the firewall I had to add 12oz up front
I've read that the stock setup needs a pound... So I would just check the weights and buy a motor and sound system that will require no weight up in the nose. I'm very happy with my power, it's to much really. But I'm going to setup a throttle curve with a high and low rate and can have a turbo switch that way
hope that helps some
Welcome to RCU
#193
Thanks Ron!
Wow, that`s MASSIVE.......if I calculate the weight of your power configuration, it comes to about 106 ounces (ECalc), which is already 21 ounces above the weight of my config with the Scorpion.......so I would have to add incredible 35 ounces of weight. Benadini System with speaker(s) is about 11 ounces, still 24 "to go"...
May be I'll go with the much heavier Axi 5345HD/14 (225), 20 x 11 Mejzlik Carbon on 12 s /5000 mAh....about same weight as yours, 4265 Watts of electric Power (thrust 543 ounces, more a 3D configuration than a warbird config...), but flight time may be a little too short (4.8 minutes average). Should then exactly add up to correct CG with Benadini Sound System, at least in theory.......
Anyway, I love this great airplane kit, quality and degree of preparation is simply outstanding. I had the chance to get the kit frome someone in Germany who had wone it in a lottery of the German RC Association (DMFV), but plane was to big for him - phantastic deal for both of us!
Hopefully soon a beautifulP-47 in the Swiss Sky!
#195
So this is my Configuration (attached)
I went finally with the new Axi 5345/16 HD 195 kv, 22x12 Mejzlik on 10s (2x 4500mAh 30c), ESC Castle Ice2 120 HV, optional change to 12s possible later with smaller prop.Matches nicely and motor alone is almost 1Kg in weight, round 2800 Watt with the Configuration, if not enough 12s will increase it.
Kind regards
Peter
Kind regards
Peter
#199
My Feedback: (22)
I just went through it and got her ready after winter
I also made a nice set of aluminum gear doors after the stocks failed on the first flight
I plan to fly her this week and will bring the camera, if someone is at the field that can help me I'll try for a video
keep you posted.... I have 5 or 6 flights on this plane and it's pure joy to fly, really easy to fly
#200
IL
going back to the motor mount question, why not use spacers to get the motor so the can is front not back? Forgive me if this is a stupid question. I have converted H9 P-47 .60 and the P-51 1.50 V2 and did that with the p-47 and used the Hangar 9 motor mount for the P-51.
