Source for Scale Accessories
My Feedback: (82)
RE: Source for Scale Accessories
WWI instrument sets are available in 1/3 scale, 1/4 scale, and 1/5 scale.
For 1/3 scale go to link:
http://www.iflytailies.com/store/ins...cale-warbirds/
item# 3110 USA, 3111 Great Britain, 3112 German, 3120 French.
For 1/4 scale go to link:
item# 4110 USA, 4111 Great Britain, 4112 German, 4120 French
For 1/5 scale go to link:
item # 5110 USA, 5111 Great Britain, 5112 German, 5120 French
My Feedback: (82)
ORIGINAL: zipnz1
Is there any chance any more styles of 1/3 WWII gauges other than japanese will be available in the future?
Are there any plans for 1/6 scale instruments.? The reason I ask is that for twin engine bombers 1/6 scale is still within a reasonable wingspan. Plus with all the 1/6 scale pilots out there there is some interest. I look forward to your reply.
Tero T in Toronto
Tero T in Toronto
#31
My Feedback: (82)
1/6 scale instruments for WWII US and Great Britain are available here:
#32
Great Thanks!
What do the instrument bezels look like. Are they round or do they have four hole flange plates? Thanks again. Superb service.
Regards Tero T in Toronto
#34
My Feedback: (82)
current 1/6 and 1/6 scale instrument sets include the round bezels as shown in the first picture below. The sets will be upgraded in the future and include the round bezels and square plates as shown in the other picture
#35
My Feedback: (82)
Clear Canopy Material available now:
This clear canopy material is very well suited for making your own canopy. The material is 1mm thick and allows application for most common canopy types.
Outstanding UV-resistance and may be easily put into shape when subject to heat.
In order to avoid scratches, this material comes with a protective cover on both sides.
Size: ca 620mm x 400mm (24.4in. x 15-3/4in.)
Thickness: 1mm
Thickness: 1mm
#39
My Feedback: (82)
Here is the full range of gun sights, available in 1/4 & 1/5 scale - in order of appearance:
UK - used on later versions of Supermarine Spitfire
Germany - This gun sight was used in Fw190, Me109, Me262, and many other German WWII aircraft
UK - compass Spitfire
US - P-51 gun sight, also referred to as K-14
UK - used on earlier versions of Spitfire and Hurricane
US - was used prior to the use of the K14 gun sight in US aircraft such as the Corsair and P-47
All gun sights come painted and assembled (only glass piece may need to be glued on).
#40
My Feedback: (82)
1/4 Scale Universal Controls WWII Germany - Includes items shown in picture. Come assembled and painted:
#42
My Feedback: (82)
Special hinge Z-318 for retract doors available: http://www.iflytailies.com/store/retracts-wheels/
The rubber hinges may be glued with thick CA. This will create an extremely strong bond and can be completed within seconds. The rubber material will still be elastic after years of use. This product impresses with ease of use and reliability.
Dimensions: 150mm x 30mm x 0.9mm
#43
My Feedback: (82)
Instrument panel kit for [link=http://www.iflytailies.com/store/instruments/1-3-scale-civilian/]SIAI Marchetti SF-260[/link] by Composite ARF available now. This kit includes the instrument panel, a set of instruments, control elements, screws, drawings of the panel, and detailed instructions.
Total width: 13-1/8in. / 33.3cm
Total height: 7in. / 17.8cm
Instruments come assembled. Panel comes painted and pre-cut and has been prepared for instruments. You only need to paint the non-gray switches and glue instruments to the panel.
#44
My Feedback: (82)
New product: [link=http://www.iflytailies.com/store/instruments/1-3-scale-civilian/]1/3 Scale WACO Instrument Set[/link]
Includes 12 assembled instruments, 10 assembled and painted switches, and one set of navigation instruments. Items also available separately.
#46
My Feedback: (82)
ORIGINAL: JGrc
Do you have an instrument panel for the Fliteskin 1/5 scale Ta152? http://fliteskin.com/Ta152page.htm
JG
JG
A) Use our 1/5 scale Fw-190 instrument panel kit (also available ready made). But you would have to confirm that it will fit:
Total width: 19cm / 7.48in.
Total height: 13.7cm /5.4in.
Some trimming might be necessary.
B) If you want a custom panel, you would need to send me the outline of the panel, including the max. width and height. We could then provide you with a quote.
#47
My Feedback: (82)
Our [link=http://www.iflytailies.com/store/instruments/1-5-scale-warbirds/]1/5 scale P-51 instrument panel[/link] (available as kit or ready made) will fit the P-51 made by Composite ARF with some minor trimming.
Side panels, gun sight, seat, control stick, pedals, pilots available, too.
#48
My Feedback: (82)
Available soon: 1/4 scale and 1/5 scale P-47 cockpit. Available as set and or individual parts; kit or ready made. Please use [link=http://www.iflytailies.com/contact/]the Contact Form[/link]if you have questions
#50
My Feedback: (82)
US, German, and British side panels available now. These come painted and with rivets:
http://www.iflytailies.com/store/ins...-blank-panels/
