If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 14 of 37 FirstFirst ... 4121314151624 ... LastLast
Results 326 to 350 of 919
  1. #326
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Top Flite Giant Corsair ARF Disappeared.
    anyone looked at the main gear doors and figured out how to make them operate?
  2. #327
    tlroliff's Avatar
    Join Date
    Aug 2002
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not yet. Was pleased to find the inner doors are included. It looks like there are pockets for hinges on the doors and the wing but it will take some engineering to figure out the linkages.
    tlroliff
    P-47 Thunderbolt Brotherhood #17
  3. #328
    Join Date
    Sep 2002
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Look on the back of the new Model Airplane News issue.
  4. #329
    Join Date
    Aug 2002
    Tarzana, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm just starting to work on the wing and I am considering making it a one-piece unit since I have the room for transportation and I don't trust that the constant on and off of the panels won't get sloppy. Anybody want to comment on the plusses and minusses of this strategy?
    Mike in L.A.
  5. #330
    Join Date
    Apr 2002
    north port, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I 'am also building one for a friend and I 'am making this a 1 piece wing. other then transportation which I have no problem with, I do not see any other advatage . The less pluging in and out and extra pluging of extension wires I always felt that there was a chance for a problem. i have had that happen to me twice before on a byron P*51 with the 2 piece wing , I was tugging at the extention on the wing panel to plug into the extension in the middle wing and sure enough just as I was about to land I lost airleon control and when I picked up the pieces I found the plug had come out of the receiver . I stayed in long enough to have a full flight but as soon as I droped the gear and made my turn douwnwind it failed. I also had another but that is also another story .
    bob
    p40bob
  6. #331
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The only thing you missed on the plug in wing thing Bob is that it is a Top Flite design...but if you like the single wing thing thats ok too. To alleviate your plug problems, just use Deans mini connectors and you wont have that problem, or what I use, the little plastic servo connector clips, they also work very well.
    Jimmy
    "Go low if you wanna make a show"
    P-40 Brotherhood #49
    Jimmy
  7. #332
    Join Date
    Apr 2002
    north port, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The problem is not with the servo extensions but where the servo connects into the receiver , that is where the tugging trying to connect the servo extensions wind up pulling the plug from the receiver and you will not be awhare of it. I use the plastic connectors on all my servo connections, but there are none for the connector to the receiver. You have to be very carefull not to pull to much when connecting the outer pannels.
    thanks bob
    p40bob
  8. #333
    tlroliff's Avatar
    Join Date
    Aug 2002
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A trick taught to me by a fellow club member that works really good: Use dental floss or a similar "waxed thread" type stuff to cinch the connectors into the reciever. A little thin CA to stiffen up the first half inch or so makes it easy to thread "thread the needle" between the wires at the connector, run it around the RX a couple of times, knot it and then CA the knot. They pretty much can't pull out if you do it right.
    tlroliff
  9. #334
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I like it so far but Hey, where's my seat?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1769435   Click image for larger version.
  10. #335
    Jeremy_D's Avatar
    Join Date
    Feb 2005
    Central Coast, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do any of the lucky guys who have this already also have the TF P47? I was wondering if it is similar in size ie Cowl and fuse diameter?
    Cheers
    Jeremy
  11. #336
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The new electric Robart gear set for this plane are due mid June according to Tower. Thats the mains and tail electric retracts. Problem is they cost as much as the arf, pretty much. The regular air set is much less expensive still so you do have the choice. Even at dealer cost they are expensive I think.
    Air Mains - ROBQ1655
    E Mains - ROBQ1656
    Air Tail - ROBQ2230
    E Tail - ROBQ2231
    Like a midget in a urinal I knew I had to stay on my toes...
  12. #337
    sgrady's Avatar
    Join Date
    Jun 2011
    Saint John, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOW 1
  13. #338
    Join Date
    Aug 2003
    Waukesha, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't know how you figure that the Air System is that much cheaper than the Electric. Looking at Tower, the Electric vs. the Air is about $107.00 more, but when you factor in the Air Control Kit for $73.00 and a servo to control it, it's almost a wash. At least for me, it's a no brainer, not having to deal with the air and all the issues that come with it, I'm going Electric. My 2 cents.
  14. #339
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Having used some of the plug in electric retracts in smaller projects, I have to think there's nothing easier.
    Every year I covered Top Gun, guys were having more issues with retracts than engines, radios and everything else combined.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  15. #340
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Easy fix...mount a zip tie near proximity of the RX and route all wires through before connecting to the RX...then zip em up.
    Jimmy
    Jimmy
  16. #341
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Robart is offering electric conversion kits. Should be available for the 148s this summer.
  17. #342
    Join Date
    Jun 2003
    Midland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Would someone pls take some measurements for me............
    diameter of the main wheels.........is there room in the wheel wells to install larger?
    length of the outer wing panels and width (at the widest point)
    width of the assembled cockpit and height from seat bottom to headrest (I have a pilot I'm hoping to use)
    tlroliff's Avatar
    Join Date
    Aug 2002
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jeremy_D
    Cheers
    Jeremy
    Not sure about the exact cowl and fuse diameters but I bet they are close. I fly with a guy who has the Tarheel Hal P-47 ARF and I do know the Corsair fuse is considerably which along with the three piece wing was important for me because the P-47 won't fit in my vehicle.
    tlroliff
  19. #344
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Outer wing panels are 27 1/2" long and 17 3/4" wide. Supplied scale-like wheels are about 4 1/2" and you might be able to use a 4 3/4 - 5" wheel.
  20. #345
    Join Date
    Jun 2003
    Midland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply.............now if someone could measure the cockpit I would appreciate it.
  21. #346
    Join Date
    Aug 2003
    Waukesha, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey, Has anyone looked into or for that matter had any luck with the Electric Gear Door Motors from Lado?
    Here's the link to them: http://www.lado-tech.net/en/e-doors/...door-20mm.html
    Just wondering,
    John
  22. #347
    Join Date
    Jun 2007
    sterling heights, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Guys
    Another tip for not yanking plugs out of the RX is to use a little shoe goo on the plugs once they are in the RX. Like a little shoe goo bridge between plug and RX. Heli guy showed me this and I do it now with everything.
    The nice thing is when needed, it peels right off
    Just thought I'd share
  23. #348
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When you own all the other stuff, like I do, then its more expensive to buy electric. If you dont then maybe its a wash for you.
    Looked at the invoice and shipping alone for my kit was $90!
    I found a Saito 300 twin dual carb and spark so thats going in instead of the OS 55GT. I just couldnt stand to see the engine stick out of the cowl bottom. The Saito will sound really good and pull this one around nicely.
    Who's using what engine in their Corsair?
  24. #349
    tlroliff's Avatar
    Join Date
    Aug 2002
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DLE 55 here
    tlroliff
  25. #350
    Join Date
    May 2008
    East Hartford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DLE 55 also.
    Do it right the first time, or not at all!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
