Top Flite Giant Corsair ARF Disappeared.
Reply
Old 06-09-2012, 04:09 AM
  #351
JKreitz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Top Flite Giant Corsair ARF Disappeared.
DLE 55 as well
JKreitz is offline
Old 06-10-2012, 11:28 AM
  #352
n8622t
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DA60 on this bad boy...22X12 three blade 7900rpm static....try to keep up fellas.
n8622t is online now
Old 06-10-2012, 02:11 PM
  #353
handyman 220
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Always on your six.
handyman 220 is offline
Old 06-13-2012, 06:48 AM
  #354
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like the gear is out.
http://www.modelairplanenews.com/blo...-corsair-gear/
BarracudaHockey is online now
Old 06-13-2012, 07:29 PM
  #355
Chris Nicastro
Chris Nicastro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: n8622t
Sounds like a Reno Racer!
Lets see vids and pics when you get there!
Chris Nicastro is offline
Old 06-17-2012, 02:53 PM
  #356
bushong572
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been working on my Corsair for a few days now and have some questions:
The Robart mains will not install because the air nipple at the back of the cylinder hits part of the retract pocket. Has anyone else noticed this? I'm surprised I have to modify the wing to fit retracts the plane was designed for.
Also, any ideas how to cover the gap between the fusealage and the horizontal stab filler block? I'm really not happy with the way it looks. I originally thought I could monokote over it before I realized the filler piece is fiberglass.
Is anyone else working on this plane.....................this thread seems to be going VERY slowly..................[&o]
bushong572 is offline
Old 06-17-2012, 03:09 PM
  #357
MaJ. Woody
MaJ. Woody's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought one of these but due to lack of time (working on other projects) I have asked a friend to do this build for me. He is an expert builder and will incorporate mods such as a fuse hatch for the switches and fill valve, fully functional main gear doors via air cylinders, extended tail wheel for better ground clearance and appearance and improved method for operating the tail gear doors. He has not mentioned any problems so far in the assembly of this plane but I will post some pics when I get the plane returned to me.
Dom
MaJ. Woody is offline
Old 06-17-2012, 03:24 PM
  #358
masteromodels
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have just finished one for a friend and I had no major problems with the build. Their may be some minor problems with the kit but all in all I would rate the kit as excellent. Another fiend of mine just finished his and he claims the same results as mine.
thanks bob
masteromodels is offline
Old 06-17-2012, 05:14 PM
  #359
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am almost done with mine... Just some cowl adjustments, balance and it is otherwise ready.... here are some pics..
ID:	1773156   Click image for larger version
ID:	1773157   Click image for larger version
rcsportflyer26 is offline
Old 06-17-2012, 05:19 PM
  #360
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
couple more.... Also have to finish painting the cowl underside. I realize it is far from scale but I just wanted to have some fun with this one an make it a little different.
ID:	1773159   Click image for larger version
ID:	1773160   Click image for larger version
ID:	1773161   Click image for larger version
ID:	1773162   Click image for larger version
ID:	1773163   Click image for larger version
ID:	1773164   Click image for larger version
ID:	1773165   Click image for larger version
Old 06-17-2012, 05:24 PM
  #361
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW, for anyone interested in buying one. If you are/near central Fl, Bob's Hobby Center has two of them left. Also have mains and tailwheels.
Old 06-17-2012, 05:27 PM
  #362
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check it again, there should be NO reason to have to modify anything if using the Robarts. You have to push the retract unit towards the leading edge until it contacts it. That way the nipple will not hit anything. It is close but no contact.
Old 06-17-2012, 06:06 PM
  #363
bushong572
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all of the replies..............I guess this thread just needed a kick- start.
Old 06-17-2012, 07:30 PM
  #364
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you'r right.... Its time for some action pics and post flight reports... hopefully vids also.. Let's see them!!
Old 06-17-2012, 08:07 PM
  #365
booker-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Someone asked about wheel size. I have 5 inch mains and they work fine. The wheel doors are a tight fit when closed but they do close completely. The retracts should work fine with no modification.
If for some reason the end air nipple on the retract cylinder is pointing toward the wing, just remove the cylinder mounting pin from the retract and rotate the cylinder 180 deg, remount the pin and you’re good to go.
booker-RCU is offline
Old 06-18-2012, 01:42 AM
  #366
telejojo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Without reading the whole thread what weight are these when done?
telejojo is offline
Old 06-18-2012, 07:48 AM
  #367
Capt G
Capt G's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's how they make the main doors work on the BH Corsair. It's essentially the same way TF has done the tailwheel doors.
Capt G is offline
Old 06-18-2012, 01:46 PM
  #368
bushong572
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would someone please measure from the firewall (not the spacers) to the thrust washer. I'm installing a DA50 and it does not give any measurement in the instructions. It just tells you to use the DLE standoffs and 3 spacers. I don't know what the length of the DLE standoffs is. I don't want to find out I have a problem when I try to install the cowl.
Also it looks like the cowl does not overlap the fuse.....is this correct???
Can someone help me out here......Thanks
Old 06-18-2012, 02:01 PM
  #369
Capt G
Capt G's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dle standoffs are 68mm -I am just starting the install.
Capt G is offline
Old 06-18-2012, 02:12 PM
  #370
bushong572
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you..................my DA standoffs are 65mm.
I wonder if I should use an extra (4 total) spacer.
Old 06-18-2012, 03:40 PM
  #371
Capt G
Capt G's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My manual says to use 3 of the supplied spacers for the DLE 55 but after I got the engine hung it looks like it might stick out too far forward. I notice that the dummy radial might protrude somewhat so we will see. Right now using just one spacer looks better. Any input from thaose who are done?
Capt G is offline
Old 06-18-2012, 05:38 PM
  #372
rcsportflyer26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also thought the same thing about the dummy engine but it has since grown on me. I ended up using the three spacers as per the manual. I had to work quite a bit for the dummy to fit forward enough but i got it.
Old 06-22-2012, 10:16 AM
  #373
Warbird Man
Warbird Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone gonna do a separate build thread on this one?
Warbird Man is offline
Old 06-24-2012, 06:04 AM
  #374
bushong572
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What happened to everyone?????????
Any flight info?
Old 06-24-2012, 07:58 AM
  #375
bladebender
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
rcsportflyer26 just would like to find out what kind of paint and color are you using on the bottom of your plane. shure looks nice to
bladebender is offline
Reply
Display Modes
