If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 21 of 37 FirstFirst ... 11192021222331 ... LastLast
Results 501 to 525 of 919
  1. #501
    Join Date
    May 2008
    East Hartford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Top Flite Giant Corsair ARF Disappeared.
    It will be awhile before I get to assembling mine.The retract he sent me installs without any mods to the existing formers in the ARF I was told. The retract is powered by a retract servo for actuation, another servo is used to lower and raise the tailhook. I wish I had seen the tailwheel sooner also, as I had already bought the robart tailwheel along with the main gear when I bought the plane.
    Do it right the first time, or not at all!
  2. #502
    Join Date
    Apr 2002
    Yorktown, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Same question dont see any electric motor.
    Tony
  3. #503
    Join Date
    May 2008
    East Hartford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tailwheel uses a standard retract servo to operate.This also allows it to retract at a scale speed. I'm sure you could also install an air cylinder for operation. I'm not sure where it would be mounted in the Corsair ARF as I haven't really looked into building the kit.
  4. #504
    Rocketeer10's Avatar
    Join Date
    Jan 2003
    A salty piece of land, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I been speaking with Earl Aune for a while and he has his TW gear now as a drop in for the TF Corsair. I have one but will fly a little more before replacing the old Robart unit. it is lighter than the Robart unit so will require removing some nose weight!
    By the way, the Corsair flies great! Here's my first test flight: http://www.modelairplanenews.com/blo...ir-arf-wvideo/
    GY
    Gerry Yarrish, Senior Technical Editor, Model Airplane News & Electric Flight
  5. #505
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maiden flights today at last. NO issues! The Robart electric gear worked perfect. If you have the TF P-40 you already know how it flys. Tracks great. Suggested low rates were fine.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1794729   Click image for larger version.
ID:	1794730   Click image for larger version.
  6. #506
    Join Date
    Aug 2003
    Waukesha, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Capt. G.
    Pic's look good, glad to hear it flew well. How did the gear doors work? It looks like a pretty simple installation, just curious how they're holding up?
    John
  7. #507
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The tailwheel doors are fine - no issues. As to the main gear doors, i couldn't make them work right with the electric gear no matter how i adjusted them so i finally just removed them. They might work ok with pneumatics though. Not noticable except on the ground.
  8. #508
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's my contribution to the tail wheel door saga.
    I used carl goldberg 90 degree mounting brackets, a robart scale wheel 2", and a couple of great planes ball links GPMQ3840.
    I attached the mounting brackets to the electric tail wheel assembly and used epoxy to attach them to the doors.
    See attached photos
    Regards
    Steve
ID:	1794845   Click image for larger version.
ID:	1794846   Click image for larger version.
ID:	1794847   Click image for larger version.
ID:	1794848   Click image for larger version.
ID:	1794850   Click image for larger version.
ID:	1794851   Click image for larger version.
ID:	1794852   Click image for larger version.
    Team Clamtown
  9. #509
    oriole's Avatar
    Join Date
    Oct 2002
    Eldersburg, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What are you gentlemen using to secure your full body pilots in the cockpit?
    Thank you,
    Oriole
  10. #510
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oriole
    I generally use Silicone clear, it lets stuff move a bit without breaking loose.
    Steve
    Team Clamtown
  11. #511
    Join Date
    Jun 2003
    Midland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    alb1661...........How do you like the TF Thunderbolt?
    I'm just finishing one up.
    Any tips or suggestions?
    I have about 12 flights on my Corsair now...........I'm very happy with it.
  12. #512
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bushong572
    Flys like a trainer,great plane...........enjoy
    Steve
ID:	1794940   Click image for larger version.
ID:	1794941   Click image for larger version.
ID:	1794942   Click image for larger version.
    Team Clamtown
  13. #513
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone had an issue with the rudder.
    By pushing I can move my rudder about 1/8 inch at the neutral position with the receiver on. When I installed it I made sure to epoxy the arm inside the rudder.
    It seems that the design of the rudder control arms at a 90 degree angle is causing this
    If this movement is normal please advise
    Steve
    Team Clamtown
  14. #514
    Join Date
    Jun 2003
    Midland, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I noticed this also, it is in the design of the rudder linkage. I owned a H9 Giant Cessna with the same design. It had even more play. I flew it for 2 years with 0 problems. I have quite a few flights on my Corsair (with many high speed passes) and haven't had any problems yet.
    I don't like it either, but I don't think it will cause any problems.
  15. #515
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Bushong572
    I think its a lousy design also....When I fly it I'll pay close attention to the rudder functionally
    Thanks Again
    Steve
    Team Clamtown
  16. #516
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rudder has worked fine. I did wick thin CA in the hole to harden it before i glued the rudder on. Here's a couple pics from today - thanks Hellcat 716.
ID:	1795545   Click image for larger version.
ID:	1795546   Click image for larger version.
  17. #517
    MaJ. Woody's Avatar
    Join Date
    Apr 2003
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have 23 flights on mine now.....full throttle most of the time and zero rudder issues. It is a sloppy design for sure but so far it is working out OK.
    Dom
    Maj. Woody Out!
  18. #518
    Join Date
    Sep 2004
    Manahawkin, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Capt G and Maj Woody for your input
    Steve
    Team Clamtown
  19. #519
    tlroliff's Avatar
    Join Date
    Aug 2002
    Milwaukee, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Word of caution to those with electric retracts. I was working on my Corsair last night and accidently plugged the tail wheel into a channel on the control box that was jumpered for the "Type 1" actuator. Didn't realize it until I had cycled the gear maybe 4 or 5 times and the tail wheel quit. Apparently that is all it takes to damage the actuator becuase it only moves about 3/4 inch in either direction now. The motor was warm to the touch and if you got real close it smelled too. I just simply got the tailwheel lead crossed with one of the mains and wasn't careful enough to double check. STUPID STUPID STUPID! [:@]
    Apparently the mains will work on the Type 2 setting cause I didn't notice anything abnormal in it's operation.
    I will be contacting Robart today. It doesn't look like there is any trick to replacing the actuator so I will just have to suck it up and buy one since Robart surely isn't going to cover that under warranty.
    tlroliff
    P-47 Thunderbolt Brotherhood #17
  20. #520
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Anyone having issues with thier wing mounts? I have heard there is a potential problem with the wing and fuse which can lead to failure in flight. Has anyone made any mods to this area to strengthen it and can you post photos or info if so?
    Like a midget in a urinal I knew I had to stay on my toes...
  21. #521
    Hellcat716's Avatar
    Join Date
    Sep 2003
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There is absolutely no problem with the wing mounting. You just need to remember to use the supplied screws to secure the wing. I hate rumors. Everything is fine, my opinion.
  22. #522
    karl hibbs's Avatar
    Join Date
    Jul 2002
    spanaway, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Its no rumor.
    "The democracy will cease to exist when you take away from those who are willing to work and give to those who would not."
    -- Thomas Jefferson
  23. #523
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    want to tell us all what you're talking about?
  24. #524
    Join Date
    May 2008
    East Hartford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    + 1 [X(]
  25. #525
    karl hibbs's Avatar
    Join Date
    Jul 2002
    spanaway, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I tried telling what happened but got told I didn't know what I was talking . I am trying to get the owner of the plane to come on here and explain . I know of 2 that have had stab flutter, on top of the wing problem that makes it interesting.
    -- Thomas Jefferson
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
