If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 23 of 37 FirstFirst ... 13212223242533 ... LastLast
Results 551 to 575 of 919
  1. #551
    Chris Nicastro's Avatar
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Top Flite Giant Corsair ARF Disappeared.
    Well we are talking apples and oranges if we dont know how they are built even though its an ARF. Mine was done by the book so far as the tail is concerned. From what I see so far its not airworthy and thats my only point.
    I flew a DC-3 with some play in the rudder that turned to major flutter at a certain speed.
    I wouldnt be surprised if the characteristic tail wag people talk about with Corsairs is just attributed to poor rudder set up.
    On a side note I removed the small strips of ply the keep you from getting a hand in the forward compartment to install the fuel tank and engine mount hardware. This area is a pain to access.
    On the wing mounting Im thinking of adding wood to the fuse mount and taking a closer look at the wing bolt areas as this is where John had his come apart.
    Like a midget in a urinal I knew I had to stay on my toes...
  2. #552
    karl hibbs's Avatar
    Join Date
    Jul 2002
    spanaway, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I guess I could have sprinkled a lot of sugar on it for you bushong572.
    "The democracy will cease to exist when you take away from those who are willing to work and give to those who would not."
    -- Thomas Jefferson
  3. #553
    oriole's Avatar
    Join Date
    Oct 2002
    Eldersburg, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks like Tower just knocked off $20.00
    Currently listed at 729.99
  4. #554
    Join Date
    Mar 2009
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi everyone, just got the ARF and wanted to know if anyone has used a G62 for a motor and what you thought? Thanks!
  5. #555
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are a few links to short videos I made of the tail installation.
    Is this what any of you are seeing in your builds?
    http://youtu.be/xvKYXnu3SZ4
    http://youtu.be/R3rFasa2Ftg
    http://youtu.be/wkYf9XfzdwY
  6. #556
    splitzed's Avatar
    Join Date
    Oct 2005
    Vancouver, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had a look at your videos that is alot of play, what is happening? is the torque rod moving around inside the surfaces or is it flimsy hardware or what. I am just about to order one of these but this makes me a bit nervous
    Remember Taxiing always leads to flying!! & what goes up must come down.
  7. #557
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well the torque rods are epoxied in the LE of their respective surfaces so there is no play in the wood. The elevators are easy to twist so you know what will happen in flight is they will twist from the inner part out to the tips under load having less effect towards the outside edge. The rudder will not center period. The metal in this kit is low grade and NOT music wire as it should be. Its easy to bend and all the torque rods and linkages from the servos are made of the same material, It would be OK for a 60 size plane but not for one this big.
    The long linkages from the servos placed forward in the fuse should be a carbon arrow shaft or similar and then have epoxied music wire ends. Instead these soft steel wires run the whole distance. The rudder linkage is unsupported from the rear retract bulkhead to the torque rod so it flexes back and forth.
    These are fundamnetal flaws and this is not airworthy as is in my opinion.
  8. #558
    karl hibbs's Avatar
    Join Date
    Jul 2002
    spanaway, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    this is what I saw on the one that fluttered.
    -- Thomas Jefferson
  9. #559
    GaryM's Avatar
    Join Date
    Aug 2002
    Copeville, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have not had a chance to inspect one of the new ARFs, however I did build the kit about five years ago. If they used the same methods and type of torque rods I can offer a suggestion of where to look to solve some of the problem. The plastic housing used as the bearing on the torque rod is several thousanths larger than the torque rod itself. When deflecting the control surfaces look at where the rod comes out of the plastic sleeve and most likely you can watch it move back and forth. Another problem with the rudder was the L portion of the torque rod could have been left longer, that would have stabalized some of the play. And lastly one reason the rudder appears to have more play is the distance from the hinge line to the rear tip of the rudder is about twice or more than that of the elevators. This results in more distance traveled in the arc of the movement.
    I extended the threaded L portion of the torque rod on the rudder. I even removed a portion of the former so I could get as close to the fuse skin as possible. The next option may sound a little crude but it helped and has not caused a problem to date. I took some very thin K & S brass sheeting. I cut a length about a half inch long and just wide enough to wrap about 2/3 of the way around the torgue rod. I rolled it into shape, lubed up the rod and slid it into the housing creating a shim. This helped most of all.
    Good Luck
    GaryM
    Corsair Brotherhoodd # 50
  10. #560
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the tips I'll look into that for sure.
    What is the metal used in the kit you built? Is it black like music wire or is it silver like mild steel?
  11. #561
    jkeze's Avatar
    Join Date
    Jan 2002
    Canton, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I flew the plane last summer but held the speed down as I saw the elevator flutter at hi speed. This fall I cut the covering on the elevator bottom/mounted a plywood plate and recovered it. I was able to install a large CB associates Horn on the plates. I broke the white plastic wire guides free and slid them forward a few inches, punched a hole in the side of the fuse and glued the white guides through the hole and lined them up with the horn. I had to buy new 48" 4-40 rods and installed them. I had about 1/4-3/8" of play in the elevators before and now there is no slop at all. These are now done the same as the TF P-51 which have no play. I would like to try it again before winter set in here in Michigan. But I feel more confident now. My 2 cents
  12. #562
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info.
    Did you report any problems to Hobbico about your Corsair?
  13. #563
    duber3's Avatar
    Join Date
    Oct 2005
    QC, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Chris Nicastro
    I built the GS Cosair a couple of years ago (still have the plane), I built it by the manual
    and I had a lot of flutter, even at half throttle, here what I did
    as I can see, jkeze did something similar on his plane
    as for the rudder, the rudder installation on the ARF version seems to be similar to the kit
    I have play on the rudder perhaps, a little less then your's but the rudder have no flutter even on dive
    an my corsair is quite fast with a 24*8 prop on a evolution 58gx2
    hope this help
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  14. #564
    BubbasanJohn's Avatar
    Join Date
    Jul 2012
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ARF = almost ready to fix!!
    Sorry to hear hobbico service is so poor. Seems like they feel threatened by your stance of wanting to Help improve the product. Maybe all they cAn deal with are refund requests.
    Could be a cya situation where these issues were know, supposed to be corrected but never addressed and if acknowledged would lead to a bloodbath in the department.
    I seriously had more faith in hobbico. I should NOT be surprised as I was just treated like crap by futaba on an absolutely new purchase. Never an appology or any sense of urgency on their part to rectify THEIR problem that was causing me time and frustration.
    Good luck. Do a charge back.
  15. #565
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply and yes its a shame they are taking this posture. If everyone would report the problems to them rather than just accept it as is and fix it there is a chance things can change.
    I agree it seems like more of a CYA situation because they repeat themselves like its scripted from one person to another. It seems John Smith ran into this exact same defense and only managed a swap he had to pay for at a discount. Anyway at this rate they are making less and less friends so its just a matter of time before they feel the blowback.
  16. #566
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A pic from toda's flying. All DLE 55s. No flutter and no wigwag.
  17. #567
    Hellcat716's Avatar
    Join Date
    Sep 2003
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Love my Corsair. No issues at all, flies like it is on rails. No flutter at all.
  18. #568
    Join Date
    Dec 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I guess I was risking my very life flying in the same sky today with two poorly designed and constructed TF Corsairs, especially since they have many flights on them. It's a wonder they didn't blow apart in midair...
    Oh, well.
    Old Dawg, owner/flyer of the checkerboard Corsair
  19. #569
    Join Date
    Oct 2005
    Coeur d'Alene, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Are all 3 built exactly to the manual with the provided ARF hardware... No modifications?
  20. #570
    Join Date
    Jun 2004
    WILLIAMSTON, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Do you have play as shown and discussed in this thread?
    Semper Fi
  21. #571
    Join Date
    Jun 2004
    WILLIAMSTON, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Capt G I take it that the modifications that you listed worked?
    Semper Fi
  22. #572
    Capt G's Avatar
    Join Date
    Jan 2002
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The plane flys great! I dribbled a little thin CA in the holes where the wires go in to the elevators and rudder before gluing them in. Also sealed the elevator and aileron gaps as always and added a little reinforcement to the firewall and wing holddown plate. That's it.
  23. #573
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All this plane needs is stripped, glassed, and a cowl upgrade
    "Go low if you wanna make a show"
    P-40 Brotherhood #49
    Jimmy
  24. #574
    Join Date
    Jun 2004
    WILLIAMSTON, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just some different decals and paint here and there. What cowl up grade? Brand?
    Semper Fi
  25. #575
    Join Date
    Sep 2004
    Springdale, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fiberglass Specialties is about a 20 minute drive away so I will take the original cowl and fuse to them and let them form a new cowl with open cowl flaps
    Jimmy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
