Do you know the dimensions of the ZDZ 80 inline twin?
Hello, I am looking for the distance centre axle to top cylinder on the ZDZ 80 Inline Twin.
If you go here
http://www.troybuiltmodels.com/categ...s-Engines.html
Then, as far as I can see, they say 120mm for BOTH 100cc and 80cc.
I hope this is not true.
The ZDZ homepage doesnt tell me any more either.
Anyone out there who can tell me the distance axle center to top of cylinder of the ZDZ 80 Inline Twin?
If you go here
SC
RE: Do you know the dimensions of the ZDZ 80 inline twin?
Kenneth,
You probably saw this at Troy built but their quote is:
"The ZDZ 80R2 uses the same crankcase as the ZDZ 100R2 in drawing on the left and all dimensions other than cylinder width would be the same."
That being the case cylinders would stick out of your 109 just like the 100 does on mine.
Forest
Forest
Aha, okay, that means there is no incentive in getting a 80cc instead of a 100cc.
Thanks Forest. I got it.
