If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 201 to 225 of 284
  1. #201
    darren763's Avatar
    Join Date
    Jul 2002
    Mpls, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ESM Mitsubishi J2M3 Raiden build
    Very nice job. I've enjoyed watching the build....Keep up the good work. What is the actual wingspan and length of the fuse?
    Darren
    That's not flying, that's just falling with style!
  2. #202
    Sessholvlaru's Avatar
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: darren763
    Darren
    Thank you for your compliment. Funny you should ask because I never bothered to measure it. Actual wingspan is 82" and the length is 73" including the spinner.
    When you stare into the abyss, sometimes the abyss stares right back into you.
  3. #203
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    More cockpit progress. The headrest is built as-is from Ty with some holes being drilled into the sides to match the real deal. The canopy framing is scratched out from some more sytrene. The headrest also needs some support pieces as shown in this shot of Chino's Raiden.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1722838   Click image for larger version.
  4. #204
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The radio box you get with the cockpit kit is generic and not the right size or shape for the Raiden. I did use it as a base though to build my own box. I used the extra knobs Ty gives you with the kit along with some more styrene and pins to get this.
    I didn't want to go too nuts weathering it...I'm not sure how often someone would be messing with it?
  5. #205
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are the radio box hold-downs. I made these from some carbon rod and styrene. I also separated the rear portion of my canopy and cut the opening in the top so that the radio mast can protrude.
ID:	1724365   Click image for larger version.
  6. #206
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is the headrest/rear canopy support and the canopy which is cut for the mast. When you cut the canopy it leaves the rear section with no frame on its front edge. I plan on using some of the extra canopy that you cut away to form the front frame.
ID:	1724367   Click image for larger version.
  7. #207
    Idigbo's Avatar
    Join Date
    Feb 2004
    Barrowhill, Staffordshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That cockpit is coming on great, the radio pack looks superb. Neatly built and finished.
    Ian.
  8. #208
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I was trying to get the Raiden ready for the WRAM show this weekend, but I dragged my arse too much and it won't make it. I visited the show today and the Raiden would have really shined there. Oh well.
    So I spent time weathering the fuse and setting up the sliding canopy in a way similar to Ian's. The Raiden canopy uses four separate rails, one in the front and one in the rear, both sides. I got the rear rails and rods sliding pretty fluidly. I still need to mount the fronts and then glue the canopy in place.
    All that is really left after that is to make gun ports, then panel line and weather the wing.
    The cockpit kit is nearly done and glued in place. I still need to fabricate the armored glass panel that was behind the gun site. I used the finishing resin trick to make instrument lenses in the dash, which I think needs a but more distressing to match the rest of the cockpit.
    My major gripe with this ARF is that the gear mounts were not squared to each other. I had to remove one lamination's worth of ply on one side in addition to washers to get them even and so that the gear doors will sit flush. On that note, both of my gear doors were warped, one worse than the other. Wetting and weighing them down helped, but I think I will end up laminating some thin plywood to the insides as they are flexed against the warp to straighten them. That or just make new ones.
ID:	1731475   Click image for larger version.
ID:	1731476   Click image for larger version.
ID:	1731477   Click image for larger version.
  9. #209
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is my first attempt at weathering and I think it is coming out fairly good. My process is to go over all of the panel lines with a charcoal stick, then wiping "with the wind." Next comes in several sizes of silver pens and markers. The horizontal stab had panel lines drawn on with pencil. Charcoal powder mixed with water makes for good "streaking" stains on the panels. Some 0000 steel wool also gives some interesting effects, especially on the tail feathers, since they were fabric on the actual plane and tended to discolor/weather differently than the metal bits.
  10. #210
    Join Date
    Jan 2002
    san diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Japanese had really crappy paint
    Time flies like a brick thru the window of life.
  11. #211
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MANFRED
    Lol. Is that a compliment or an insult?
  12. #212
    Join Date
    Jan 2002
    san diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you tell me
ID:	1731624   Click image for larger version.
ID:	1731625   Click image for larger version.
  13. #213
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MANFRED
    you tell me
    I wonder if it was crappy paint or the salt air? Both maybe?
  14. #214
    Join Date
    Dec 2001
    Litchfield Park, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Sessholvlaru
    ORIGINAL: MANFRED
    you tell me
    I believe it was the decision to forego the use of primer near the end of the war.
  15. #215
    Join Date
    Jan 2002
    san diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It was their decision to forego self sealing fuel tanks and pilot armor that really screwed the pooch for them.
  16. #216
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got a new pilot today from my buddy Dean at Aero Accessories. He had one 1/5 scale Japanese pilot left from a now defunct UK manufacturer.
    This guy fits way better than the 1/6 scale G.I. Joe figure and it about 1/10th the weight since he is mostly latex. I can also use most of the 1/6 scale guy's gear including his Japanese sun bandana.
ID:	1736392   Click image for larger version.
  17. #217
    Join Date
    Jun 2006
    RIVERVIEW, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Impressive work, when I see builds looking this good I always feel so ashamed to bring my warbirds to the field...
    Kevin
    When you\'\'re not in the Fasst lane you can always depend on JR to Feel the Difference...in your wallet...
  18. #218
    dgiatr's Avatar
    Join Date
    Jan 2009
    petralona, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Idigbo
    Mine balanced with no lead. The battery is above the fuel tank which is just forward of the CofG. My spinner backplate is pretty heavy though. From memory, mine is balanced further back than the book says too. In flight, its a bit nose heavy, so I may remake the backplate a bit lighter. When inverted it needs a good squeeze of down elevator. Very very safe on stall too. Have you glued your tailplanes on yet?? I hope not since I have a recommendation. Since my flutter issues (completely my fault I must add) I found the need to replace the tube between the tailplane halves. It had fractured inside the fuselage. The repair was easy, I simply sleeved the inside with another ali tube, with a carbon tube inside that. When I put the model together, I was a bit unsure of that huge span tailplane on just one ali tube. The tube probably would have been fine in normal use, but my self induced flutter incident must have frightened it slightly!!! I've had the model out a few times since and it is rapidly becoming my favourite flier.
    Ian.
    Hi! i want to ask all of you who had fly esm raiden how much <> weight did you add to the nose in order to balance that model, how does it fly with the recomended cg, whats the total weight of the model;
    i really want to know because in my plane i had to add 3,5 kgr!!!!!!is that possible please tell me its not true!!
    whats the recomended cg in your manual;
    Thanks! (i am looking forward for your answer before my maiden flight)
  19. #219
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well finally an update. Got my electric retract upgrade boards from TBM and installed them. Easy to install but in my application I needed 8 new screws for the retract motor backplates as the new backplates use larger screws. They probably should have been included with the kit, or at least let me know that I might need them.
    Total time lock to lock is now a scale 14 seconds.
    [youtube]http://www.youtube.com/watch?v=n4FgPqA3P-Y[/youtube]
  20. #220
    Idigbo's Avatar
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hows progress Sess?? I've put some panels and weathering on mine now, all onto the standard finish with petrol proof ink and paints.
    Ian.
ID:	1768620   Click image for larger version.
ID:	1768621   Click image for larger version.
ID:	1768622   Click image for larger version.
  21. #221
    glazier808's Avatar
    Join Date
    Mar 2009
    Honolulu , HI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    looks really great Ian. You really have that chipped paint look down. What's the process?
    Casey
    Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft, BestPilots.com
  22. #222
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Idigbo
    Ian.
    Not too much, still need to weather the wing. Your wing great, I would also love to know how you did yours (especially the large silver patches). I posted these pics before, my fuse looks similar to yours.
ID:	1768672   Click image for larger version.
  23. #223
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Time to revive this thread. After failing to get the plane ready for WRAM 2012 I decided to get it ready for WRAM 2013. 400 projects had gotten in the way and I hadn't done much with the plane.
    Getting back to it with a vengeance now.
    The gear doors, as mentioned before, were both warped. I put them in my bathroom sink under maximum hot water while reshaping them and it seemed to work. I siliconed on the door mounts and fitted and epoxied the doors on to those.
    What you see here is a few hours worth of weathering. Next is to mount the drop tank which will help cover the non-scale plastic belly pieces.
  24. #224
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    To make the gun blisters I used, of all things, the corners of CyA bottles. They're just the right shape.
  25. #225
    Join Date
    May 2006
    West Caldwell, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aaaaand all done and displayed at WRAM.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
