Reload this Page >
Spitfire Brotherhood (All Spitfires Welcome)
Old 01-17-2015, 03:40 PM
  #3776
WarbirdPilots
My Feedback: (209)
Hey Guys it Adam from Warbirdpilots.com
I just wanted to correct and add some weight information about my pilot figures. I now have new cotton filled wire frame bodies for my line of Pilot Figures. The 12" Tall 1/5~1/6 Scale Pilot figures are only 5 - 6 ounces, and the 15" Tall 1/4.5~1/4 Scale Pilot Figures are only 7 - 8 ounces. The original plastic figures I used to carry were approximately 8 - 10 ounces.
So I have been able to shave another 2 - 5 ounces of weight off the figures. They still look exactly the same with all the same great individual clothing and equipment, just now even lighter.
I have attached a picture of the 12" Tall 1/5~1/6 Scale WWII British RAF Pilot sitting on my scale, so you can see the weight. I hope this helps clear up any questions or concerns about the weight of the figures, and shows you that you can get an incredible looking full figure pilot without the extra dead weight.
Adam Martin
www.warbirdpilots.com
Old 01-17-2015, 03:49 PM
  #3777
Eddie P
Eddie P's Avatar
Originally Posted by ForcesR
Some Spitfire pilots did indeed fly with an open canopy
Roger
Thank you Roger!
Originally Posted by perttime
It looks nice.
Actually, it seems that taking off and landing with canopy open was - and still is - standard procedure with Spitfires and Seafires. Watching some images or videos should confirm it.
I've only seen one Spitfire fly "live" (Mk.XVI) and the pilot took off and landed with canopy open.
Excellent, even more of a reason to make an operable canopy. Thank you for the info!
Adam Martin
Thank you Adam! That's great information and all I needed to hear. Currently budgeting for one of your pilots for sure, I like the light weight option you have. PS how much weight does the moving head option add? Cheers-
Old 01-17-2015, 04:27 PM
  #3778
piperjon
piperjon's Avatar
Originally Posted by Eddie P
What's the weight of your pilot (if you know off hand)? (for my 1/6 (1.5.5) 81" span H9 Spitfire Mk IX). Trying to keep her light but I can't resist a good quality pilot in there. Will probably take out any structure under clothing and replace with carved foam to keep it light. It's gonna be E powered so I will try to save weight aft of the CG where I can.
On a side note has anyone got a good source for a scale tailwheel assembly for a 1/5 or 1/6 scale Spitfire? I might just fabricate something but it would be interesting to know what's available too.
PPS - Edit
Does anyone have a good idea as to weather Spitfire crews often / sometimes took off or landed with the sliding canopy open (like some pilots of other aircraft sometimes did)? Trying to decide if it is worth the trouble of making a servo operating canopy.
HiEddie,
My pilot is only 203 g's which is okay for me and that is fully dressed with parachute. 12" high. The only trouble with the canopy open is it may come off while flying your spit. Unless you make sure it is built really good and strong. If the wind gets under it it will surely go. I have see a few mustangs land with out the canopy. So make sure you can make it nice and strong.
John
Old 01-17-2015, 04:51 PM
  #3779
piperjon
piperjon's Avatar
PPS - Edit
Hi Eddie,
I just checked the weight of my RAF pilot 7.16oz. But I am going to take off his gun belt and map wallet. make sure you check your pilot dress as some are not what they used.
also the tail wheel is from sierragiant.com here is a picture they show on there site. hope it all helps. John
Old 01-17-2015, 05:45 PM
  #3780
Eddie P
Eddie P's Avatar
Thanks Piperjon! All good stuff. The tailwheel looks nice, I'll have to check the dimensions. My Spit is really closer to 1:6 scale (1.5.5 to 1), might make it a requirement for me to fabricate something. It's very close to the Brian Taylor one, so anything that works on a BT Spit will "just about" work on the H9 Spit.
Old 01-18-2015, 10:03 AM
  #3781
WarbirdPilots
My Feedback: (209)
Hello Eddie P,
Thank you for the question. I use the original hollow plastic bodies for the moving head figures. The original hollow plastic bodied figures with all the gear and clothing on were 8 ounces. I crack open the bodies and remove some of the plastic frame work and install a Hitec HS-55 Servo which runs up to the neck joint with a very short dowel. I then close up the body and the servo in enclosed in the figures upper chest. You have no idea it is a servo operated figure except for a wire coming out his "3rd point of contact", ie: butt.
That wire goes directly into the fuselage and can be y-harnessed with the rudder. Because I remove some of the frame work in the body when I crack it open, the servo doesn't add any weight. So the Moving Head figures weigh only 8 ounces.
I added a link to one of my customers videos. He installed the moving head 12" Tall 1/5~1/6 Scale WWII British RAF Figures in his Hangar 9 30cc Spitfire. It is the perfect size and looks great with the moving head.
https://www.youtube.com/watch?v=cQiiJLW7K0E Thanks,
Adam Martin
Old 01-18-2015, 08:26 PM
  #3782
Eddie P
Eddie P's Avatar
Thank you Adam, it looks and sounds great. Will be ordering one.
Old 01-21-2015, 06:08 AM
  #3783
Bumble.bee78
Hi I am looking to add wing cannons, guns to my CARF spitfire. Can anyone reference me where I can find them.
ID:	2065910   Click image for larger version
ID:	2065912   Click image for larger version
Old 01-21-2015, 07:29 AM
  #3784
radfordc
My Feedback: (14)
radfordc's Avatar
You apparently need the guns to shoot down enemy seagulls!
Old 01-21-2015, 08:15 AM
  #3785
Bumble.bee78
Yep WarBird vs. Bird
ID:	2065965   Click image for larger version
ID:	2065966   Click image for larger version
ID:	2065967   Click image for larger version
Old 01-21-2015, 08:56 AM
  #3786
UK Warbird Guy
UK Warbird Guy's Avatar
Here are few pics of a few ESM/YT 89" 50cc Spits I've built over the past few years. Mine is the Recon Pink one and I've also put in a link to the YouTube video of her finally flying...
https://www.youtube.com/watch?v=lLvxMPvzprI
ID:	2065970   Click image for larger version
ID:	2065971   Click image for larger version
ID:	2065972   Click image for larger version
ID:	2065973   Click image for larger version
ID:	2065974   Click image for larger version
ID:	2065975   Click image for larger version
ID:	2065976   Click image for larger version
ID:	2065978   Click image for larger version
ID:	2065979   Click image for larger version
ID:	2065980   Click image for larger version
ID:	2065981   Click image for larger version
ID:	2065982   Click image for larger version
ID:	2065983   Click image for larger version
ID:	2065984   Click image for larger version
ID:	2065986   Click image for larger version
ID:	2065987   Click image for larger version
Old 01-21-2015, 10:55 AM
  #3787
gary mark9
Bumble.Bee you can make cannons out of drumsticks
Old 01-21-2015, 11:04 AM
  #3788
rcgeorge29
My Feedback: (15)
what's the approximate scale of the CArf Spitfire BB78?...A guy in the UK made mine for my ESM Spitfire, but it's only 1/6th scale. I'll try and dig up his info for you...maybe he has larger.
cheers
Rob
Old 01-21-2015, 11:53 AM
  #3789
ForcesR
cheers
Rob
rcgeorge29, Mike Skingle makes 1/6, 1/5 and 1/4 scale cannons and other accessories for the Spitfire. Here is the link to his site in the UK. BB78, Mike is a great guy to deal with, before he takes your order you have to make a promise that you will send photos of your Spitfire after installation of his cannons etc. Well at least that is what I had to do Lol!!
Roger
http://www.wsbudesign.f9.co.uk/acces...ns-cannons.htm
Last edited by ForcesR; 01-21-2015 at 12:12 PM. Reason: addition of 29 to rcgeorge
Old 01-21-2015, 12:05 PM
  #3790
rcgeorge29
My Feedback: (15)
Yup, that's exactly who it was Roger....thx
Old 01-21-2015, 12:55 PM
  #3791
UK Warbird Guy
Hahahah well done guys... Mike is a mate of mine and we actually set out with him moulding them and me selling them at the shows and via the website you found....which is out of date
.. Mike does indeed still make them and they are the ones I used on the Pink and Silver Spits in the pictures above.
Not sure if the Prices are still up to date but I do know he still does them.
Any issues getting hold of him come back to me here and I will see what I can do for you.
Wayne
Old 01-22-2015, 04:54 AM
  #3792
Bumble.bee78
Thanks to all for there suggestions! I contacted Mike Sikingle last night. I am going to order the 1/4 cannons.
Old 01-24-2015, 05:28 AM
  #3793
WARBIRDRCER
My Feedback: (22)
WARBIRDRCER's Avatar
Spitfire Brotherhood Update, we now have 248 in our squadron.
Welcome to the Spitfire Brotherhood
246.Oakey
247.Elcorro
248.piperjon
Start Date: 12-28-2011
Current Date: 01-24-2015
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
64.mad web tv scientist
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
129. Seamus OLeprosy
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
138. Scratchbuilder46
139. jchtr3a/John Harrigal
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
146. Michel Gravelle
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
189. DavidAgar WA, USA
190. David’s Dad (In Memory and Honor of his service to Freedom)
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
196. rupa Switzerland
197. Phantom pty Panama
198.GWarden
199.CNY_Dave NY, USA
200.Rebel Flyer MN, USA
201.Alex A&MMODELS FL, USA
202.sparky4lawndart CA, USA
203.Owl NC, USA
204.Jim Branaum TX, USA
205.speed20
206.Maverick47 CO, USA
207.patrnflyr TX, USA
208. Sean Curry FL, USA
209. K5054 Ottawa, ON Canada
210.XTRA230 Australia
211.Mpizpilot NY, USA
212.nayo
213.THEJADEGROUP IN, USA
214.Hawk131
215.karel47 Belgium
216. MarkJ59
217.ArmourGod
218.warbirdmustang KY, USA
219.nigeh-2013
220.Ram-bro NE, USA
221.DocYates AL, USA
222.Scratchie MN, USA
223.trisdisp57 NY, USA
224. TuskegeeCO, USA
225.Spadkun Japan
226.Scott Douglas United Kingdom
227.TerryW MI, USA
228. KittyKatjazAustralia
229.chandley43231 OH, USA
230.w1nd6urfa EllinikoAthens, Greece
231.DraganRi Rijeka, Croatia (Hrvatska)
232.takiss Greece
233.goalie40 Calgary, Canada
234.sfI
235.gary mark9 OH, USA
236.iceaxe Australia
237. Sisu KS, USA
238. SewerdudeIN, USA
239.Ram-bro NE, USA
240.sopwith flyer
241.bpoates25 FL, USA
242.rcmichael CO, USA
243.dionysusbacchus TX, USA
244.Tomtomas Denmark,Skandinavia
245.EagleDriver1988
246.Oakey Australia
247.Elcorro Canada
248.piperjon Australia
If you would like to join the Spitfire Brotherhood please send me a PM here from RCU, or just make your request on this thread. I will track and assign you a number.
Never can tell when you may run into another Spitfire Brother some where, so join now.
Old 01-24-2015, 08:01 AM
  #3794
Eddie P
Eddie P's Avatar
Please add me to the Spitfire Brotherhood list... H9 30CC Mk IX, should take flight this spring. I've had a MkI in the distant past, but sold it. 10 years ago I'd have been building from plans, something like a BT. Years from now, when I have more time again to devote to the extremely enjoyable art of building from basic material, I'll be doing plans built once again. I still scratch build but I can only do one of those projects every 3 or 4 years or so and I am in the middle of one now so my Spit had to be an ARF if I was to have one at all. There is a fortune of great information and motivation here in this thread, thanks to all of you.
Old 01-24-2015, 05:19 PM
  #3795
WARBIRDRCER
My Feedback: (22)
Spitfire Brotherhood Update, we now have 249 in our squadron.
246.Oakey
247.Elcorro
248.piperjon
249.Eddie P
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
198.GWarden
203.Owl NC, USA
205.speed20
212.nayo
214.Hawk131
215.karel47 Belgium
216.MarkJ59
217.ArmourGod
219.nigeh-2013
220.Ram-bro NE, USA
225.Spadkun Japan
227.TerryW MI, USA
228.KittyKatjaz Australia
232.takiss Greece
234.sfI
237. Sisu KS, USA
238.Sewerdude IN, USA
239.Ram-bro NE, USA
240.sopwith flyer
245.EagleDriver1988
246.Oakey Australia
247.Elcorro Canada
249.Eddie P NV, USA
Old 01-24-2015, 05:34 PM
  #3796
piperjon
piperjon's Avatar
Thanks for adding me. cheers John
Old 01-24-2015, 06:22 PM
  #3797
WARBIRDRCER
My Feedback: (22)
Spitfire Brotherhood Update, we now have 251 in our squadron.
246.Oakey
247.Elcorro
248.piperjon
249.Eddie P
250. UKWarbird Guy
251.rcgeorge29
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. CAPT John
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
184. LKruse
185. Flyfast1
186. mpro326
187. oldtimer4759
188. AZThud
191. Capt G NV, USA
192. GregorB
193.KaP2011
194. Hawkflyer
195. taygher
198.GWarden
203.Owl NC, USA
205.speed20
212.nayo
214.Hawk131
215.karel47 Belgium
216.MarkJ59
217.ArmourGod
219.nigeh-2013
220.Ram-bro NE, USA
225.Spadkun Japan
227.TerryW MI, USA
232.takiss Greece
234.sfI
235. garymark9 OH, USA
237. Sisu KS, USA
239.Ram-bro NE, USA
240.sopwith flyer
245.EagleDriver1988
246. OakeyAustralia
247.Elcorro Canada
249.Eddie P NV, USA
250. UKWarbird Guy United Kingdom
251.rcgeorge29 Canada
Old 01-24-2015, 09:19 PM
  #3798
Elcorro
Elcorro's Avatar
Thank you for adding me to the Brotherhood! ��
Old 01-24-2015, 11:15 PM
  #3799
kittykatjaz
kittykatjaz's Avatar
Hi Guys,
The Pica Spitfire wing repair and retract shifting is going along well.
I have added the two spruce wing spars which has increased the wing strength substantially. I also shifted the retracts on the mounts and made longer oleo legs. Then made up some spacers and raked the gear forward.
All up I have shifted the wheels forward 1.5 inches which on the tail lift test has made a remarkable improvement on the angle where the nose wants to drop. The longer legs have also made this Spitfire look much nicer on the ground as it always looked a little short and stubby on the grass.
Am really looking forward to landing this plane without it wanting to go on its nose.
Jaz
ID:	2067497   Click image for larger version
ID:	2067498   Click image for larger version
ID:	2067499   Click image for larger version
Old 01-26-2015, 09:25 PM
  #3800
jet22b
jet22b's Avatar
Hello Brothers and Sisters;
Phoenix Model is coming out with a very nice Spitfire at the end of next month!! Look like a good fun plane to have!!
Not much info from Tower Hobbies, but they do have a video of it in the air.
I put one on back order and will be going with a OS 51AX in the nose.
http://www3.towerhobbies.com/cgi-bin...7&I=LXEMWS&P=K
Sonny
aka
jet22b
